Question about Gateway Computers & Internet
Broken screen on GatewayZX4665G computer
Computer is an all in one. Monitor took a nose dive and the screen inside the computer (not the outside glass) is broken. Computer is not a touch screen
    Sergeant:
  • 333 Answers
You will need to buy a replacement screen, it is not a do it yourself job unless you are very technical , you will need to take the computer to a service center.
Posted on Dec 05, 2014
2 Suggested Answers
  • 4234 Answers
SOURCE: Broken Elo Monitor Screen
Touch screens are even more expensive that straight LCD panels. This repair may cost more than the original monitor. Why do you need another panel? Is the panel cracked or is the touch screen portion not working correctly?
Dan
Posted on Mar 28, 2008
Lenovo g550 laptop with an external monitor would only display of broken original screen after crash dump
When the computer is starting up PRESS & HOLD the "F" key which controls the external monitor. It may be F4, F5, F6. You should get image on the external screen. Go into video properties and select dual monitors or allow computer to use external display or something like that.
Nov 19, 2014 | Acer Computers & Internet
I was playing my game today and suddenly the monitor died. the computer works fine but the monitor wont even take the picture(wont even work without being connected to computer, like it has no...
You need to check the power supply and see if the output voltage is correct, it should be written on the power supply board by the out put connector, if it is correct then it is possible that the inverter is bad.. I suspect a bad power supply.
Oct 15, 2010 | Samsung SyncMaster 720N Monitor
HP monitor going into sleep mode right after turning it on
If it goes in to sleep mode, that means that the monitor is not getting a signal from the computer.
The things to try (from simplest to most complex) are:
  1. Make sure the computer is on and not in "sleep" mode -- press the "Caps Lock" key and see if it lights up the caps-lock light on the keyboard.
  2. Make sure the video cable is connected from the computer to the monitor (that the cable hasn't come loose on either end)
  3. If your monitor has multiple inputs, make sure it's set to the right (probably analog VGA or DVI) input
  4. If your computer has more than one video output (like a laptop with it's internal screen plus the external monitor) then make sure the external monitor is enabled
If none of those solve it, post a comment back here and we can dive in to the more complex tests
Sep 06, 2010 | HP w1907 LCD Monitor
Turn monitor on and the light stays yellow will not turn green and screen stays black
When it lights up the yellow light instead of the green one, that means that the monitor is not getting a signal from the computer.
Sep 06, 2010 | Computers & Internet
Lcd Screen Broken
is the display is broken or the screen is physically broken,if display is broken we can check the and isolate that some part is gone bad in the computer or the issue is with the monitor.If screen is broken physically then nothing can be done...really sorry the monitor needs to be replaced
Nov 29, 2009 | Acer AL1715 (Black, Silver) 17" LCD...
Computer screen goes blank after a couple of seconds
the back light of my hp w1907 will only come on for a second than go back off?? the rest of the monitor is working can see the image if you shine a light on the screen ..any help??
Comments: Oct 26, 2009 - so this monitor was not in warranty so i took it apart i found a wire broken off one of the backlight bulbs, ( be very carefull the bulbs all four of them and the lcd screen are very very fragile ) so i soldered the wire back on and put it back together and rechecked it it has been working like new
Nov 24, 2009 | HP w1907 LCD Monitor
My power light is on but the monitor is black. Is
your moniter is not broken your moniter's data cable is not correctly pluged.
Jul 30, 2009 | Dell E173FP 17" LCD Monitor
Blue tint on monitor
If you mean you can still see your screen and everything on it, but everything is very blue, then check your video cable from the PC to the monitor.
It will have a broken wire inside and is a common problem. Just wiggle it around in a circle and it should come good. Hold it in that position with something until you can replace the cable.
Apr 18, 2008 | E-Machines eMachines Monitor E15T4
Broken LCD
To me it looks terrible and have no idea to repair it. I don't think you can fix it. How did get the screen broken? I used to repair a monitor from Dell. The CCFL lamps inside are broken. My screen is still OK. I would suggest that a new screen is a better choice for you if you have enough budget.
Thank you
Mar 26, 2008 | Samsung SyncMaster 216BW Monitor
Monitor randomly shuts off and computer restarts
After you turned it on and the screen shut off, check the image on the screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If the computer shut down immediately after the monitor shut off, it might be because of fault operating system. Check with another monitor.
Thank you,
Mar 08, 2008 | HP Compaq FS7600 17" CRT Monitor
Computers & Internet Logo
51 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
