Question about Janome Sewing Machines
I have a a Janome 6260. The thread eVentually splits in half, then breaks. This problem is worse when I use decorative stitching
I have tried different needls and different threads with no change found.
    New Friend:
    Problem Solver:
  • 6 Answers
I'm going to guess on this one; if your stitches are even (no bunching or pulling), you might have a build up of thread somewhere in the machine. Take out the bobbin and, if possible, the bobbin casing and check for any tangled or loose threads. Second guess, check the feeder on top of the machine, thread may be working its way into and catching on that feeder... be very careful when threading through the feeder because thread will often catch. If neither of these 'fixes' work, might be time to take the machine in for a cleaning and tuneup.
Posted on Dec 05, 2014
My singer heavy duty 5532 makes a knocking noise when I use the decorative stitches
check thread and make sure thread has been in its threading slot in your bobbin case
Mar 23, 2016 | Singer 5532 32-Stitch Heavy Duty Sewing...
I have a Janome Newhome 672. Cleaned and oiled it, works great. But, the decorative stitches will not form correctly. The reverse is not engaging. How can I fix this. Also, the button hole knob h
In most cases Laurie, with decorative stitches selected some machines can't sew in reverse. Your stitch length is too long or too short to make the decorative stitches sew correctly. So many things could be wrong. I'd need more info to get you going again.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Oct 22, 2014 | Janome Sewing Machines
My top thread often begins to fray and then breaks while I am sewing
try these suggestions and see if they help
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Feb 16, 2013 | Janome 8080 Computerized Sewing Machine
Janome 6260 not stitching properly. skipping stiches on top and bunching on bottom
New needle, clean under bobbin case and look at this.......Looping thread underneath is a top thread tension issue...
I have written a 5 page illustrated Tutorial on overcoming this problem....HERE
Nov 23, 2011 | Janome 6260QC Computerized Sewing Machine
I'm using a Janome 1600 DBX on my Grace quilt frame. It keeps skipping stitches and breaking the thread. I put in a new # 16 Janome needle - made sure it was installed correctly, and tried 30 weight and...
The tension is not right and you are moving the machine to fast. Go back to your 50 weight thread top and bottom. Have you got a quilting foot on and the foot in the down position
Dec 01, 2017 | Janome 1600P-DB Mechanical Sewing Machine
The tension of thread is too loose on the underside when sewing decorative stitches
on my janome you can tighten the tension via a small screw in the bobbin housing. I would be very light handed so as not to go too tight, and usually lessening the tension on top thread is all that is reqired
Sep 07, 2010 | Janome 6019QC Mechanical Sewing Machine
How do you set the tension on a janome 6260 sewing machine?
Refer to the manual.
You turn the tension knob - the higher the number the tighter the stitch.
First, thread the machine with the presser foot up. This opens the tension control for the thread to properly enter.
Then, when you lower the presser foot, the tension control closes to the setting you have selected.
Mar 01, 2010 | Janome Sewing Machines
The bobbin thread is bunching on the under side of the fabric,. Decorative designs are close together, not like the pattern and when I use the more intricate decorative designs, they just sit in a quarter...
Make sure that you use the F foot when using decorative stitches.
The stitch balance my be off. Remove the accessory bin and you will see a large plastic screw with a + and a - and an arrow. Using a coin, turn the arrow to the center and test. Turn the arrow towards the + to stretch the pattern out.
If this doesn't work, it must me calibrated internally and requires an experience hand.
Jul 07, 2009 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
79 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
