How do I rid of odour from the machine after washing?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 25 Answers
If this is a front loading washer there are products available to clean and flush out the washer. The low water levels have been found to produce mildew odors on the high efficiency machines.
Posted on Dec 05, 2014
FRONT LOAD WHIRLPOOL WASHER SMELLS
what type of smell burning rubber or odour . if odour give it a good clean out with bleach on a wash cycle. the inner drum maybe dirty on the outside
Feb 11, 2015 | Whirlpool Washing Machines
Offensive odour
Have you tried cleaning out the filters? these get clogged up sometimes and if not maintained properly they can build up and release a pungent odour
Here is a video on youtube that wll help you if you do not know how to do this
http://www.youtube.com/watch?v=Q0TiugqnGbk
Aug 16, 2012 | Bosch Washing Machines
When I open the door of my wash machine it smells bad. What would cause this? Is there a lent trap with lent in it, causing this? If so were is the lent trap? Matag Neptune Washer.
Hi dear.I'm bit foreign to this model of Maytag.There for I do not know exactly where is the lint filter on it (Refer it's user manual)but I can help with the Bad Odour.If you are doing COLD WASH most of the time with your washer bad odour happens because of body oil & some other deposits(residue) left or sticks the drum after each wash.Cold wash cause that & if it gets worst mould problem going to start up.That's why you have to run the machine empty on Hottest Cotton wash cycle with some bleach every 6-8 weeks to get rid off residue.You'll see the difference.I hope that helps.Thanks.
Sep 02, 2010 | Maytag EPIC MFW9700S Front Load Washer
Smelly washing machine and washed clothes
This is usually because of a bacteria build up on the machine. Suggested actions: Remove and thoroughly clean the soap tray. Remove the waste pipe from the drain pipe you have it poked into and ensure that all is clean and emptied. If your machine has a filter (Usually behind a 4 inch square door on the front towards the bottom of the machine if one is fitted - this depends on the machine and I'm sorry, I'm not familiar with your madel). Finally, take 2 or 3 DISHWASHER TABLETS put them in the machine's drum and wash at the highest temperature that your machine will allow. Modern biological washing powder uses bacteria to break down and "eat" stains. Bacteria creates unpleasant odours. Dish Washer tablets and powder is designed to kill bacteria. Hope this helps
May 12, 2010 | Washing Machines
Foul odor is coming from Washer-Dryer. What can the problem be?
We've got a video that you might find very helpful. This video will run you through thoroughly cleaning your washing machine to rid it on any fusty foul odours:
www.twitter.com/espares
Mar 10, 2010 | Maytag LSE7806A Top Load Stacked...
What do I clean my washer with in between washloads to keep it clean and smelling good using cleaners around my home?
Clean out the detergent dispenser and the drain trap first
Then
Put a strong solution of washing soda into the machine before you set it away without a load and on a hot wash (Do not put detergent in)
Let the machine do a full cycle and then leave the door open to let it dry out
You may have to do this twice to get rid of the odour
Also try using old fashioned soap powders which contain bleach and soda.
There is a bacteria build up in your machine due to low temperature washing
Sep 26, 2009 | LG WM-12230FB Front Load Washer
Odour
Throw a dish towel and a cup full of baking soda in to a 'small load'. Run it through the first wash cycle but turn off before it hits 'Spin' or 'Rinse'.
Repeat several times.
This should get rid of most odours. If no joy, repeat the process using bleach or vinegar instead of (NOT combined with) the baking soda.
Sep 05, 2009 | Kenmore Washing Machines
Samsung Front Load washer has odour
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Sep 01, 2009 | Samsung WF203ANW Front Load Washer
Rid of Mildew Smell?
Make sure there are no leaks from the machine. look behind it and check the water inlet hose and connectors for any damage. Also look under the machine for any water as this may indicate a leak from the internal hose and pipe work and / or water pump. Also check that the outlet hose is completely clear of debris and soap scum build up and check that the filter is clean.
To keep the machine clean of waste build up and to keep any bad odours away
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure monthly
Aug 22, 2009 | Bosch Nexxt 500 Plus WFMC5301UC
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
