Question about Frigidaire Washing Machines
How do i fix a frigidaire top load washer that won't spin
I was washing a sleeping blanket when the agitator started to bind up. After a few tries i turned knob to spin, the water drained but would not spin and washer shut off
  • Frigidaire Master
  • 2,210 Answers
Sounds like the bearing carrying the agitator has broken up. I think you need an appliance engineer or a good DIY neighbour to get to the problem. I take it,it won't operate when its empty of the load?
Posted on Dec 05, 2014
  • 185 Answers
SOURCE: washing machine agitator & drum spin during wash cycle
check the dogs in your agitater
Posted on Mar 25, 2008
  • 196 Answers
SOURCE: Frigidaire front load washer won't drain or spin
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
Posted on Nov 12, 2008
onthejob5130
  • 640 Answers
SOURCE: Kenmore 80 series top load washing machine won't agitate or spin
defective motor coupling,,replace..onthejob
Posted on Jan 24, 2009
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
Macmarkus
  • 2605 Answers
SOURCE: Frigidaire affinity front load. Starts
Welcome to FixYa.
Based on what you've described,...you likely need a door lock/switch assembly.
The door latch is likely the single most common fault (which prevent's any spin, and consequently drenching wet clothing at the end of the cycle) with the frigidaire/electrolux built washer's, aside from pump's being obstructed.
I think it fool's many people because the lock indicates it is energized on the panel, however the built in "monitor" switch inside the assembly fail's. I do see a lot of these particular machine's...unfortunately.
You should be able to purchase one at most local brick & mortar stores or on-line part's depot's such as "searspartsdirect.com" "repairclininc.com" to name a couple. They usually sell for about $50 or so, part # 1531974 ( # at repairclinic.com ) and are relatively easy to replace. It should resemble the image here...
As for replacing said switch, There are a couple ways to access it, through the top and squeezing your arm down the front or the way I prefer, remove the front bellows spring/retainer.
1) **unplug the washer from the wall...safety first of course.**
2) Remove the spring, get it started where the spring is located with a small screwdriver. Once you`ve got the spring/retainer off ( it comes off and on pretty easy by hand ) pull the gasket/bellows back away from the cabinet.
3) Undo the two screws holding the switch to the cabinet, pull the switch out ( there is just enough slack in the wires so don`t pull too hard ) and swap the wires from the old assembly to the new one and you`re in business.
4) To put it back together, just reverse the removal procedure. The trickiest part is the retainer. Rap the retainer around the boot leaving the spring for the last...and make sure the spring is located at the 6 o`clock position...usually. Just wherever it was initially.
Let me know if you need further assistance going forward or if my instructions are not clear.
P.S.
There is a slim chance of a faulty motor or motor control board, but that would not be where I would direct you to start...those are exceptions rather than the rule.
Thank you for visiting FixYa today. Good luck.
Regards,
Macmarkus :)
Posted on Dec 12, 2010
Kenmore 400 washer
Try redistributing the blanket evenly around the agitator.
Jun 11, 2017 | Washing Machines
Frigidaire Fex831cs Top Load Stacked Washer won't agitate
I worked on one last week which was completely dead. Some wires were cut. Took a few pics: Laundry Center repair
Service manual
Jun 21, 2012 | Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Will not agitate or spin, does fill with water. Just happened. GLWS1233A Frigidaire top load
I replace a new solenoid, I started to get my cold water but then, I replace a new lid lock and it stop agitating. Could you please help me.
May 16, 2011 | Frigidaire GLWS1233A Top Load Washer
Kenmore Series 80 top loading washer that doesn't spin or agitate
Unplug machine, remove water pump and motor, behind the motor is a coupler, take broken parts to your local appliance parts store. Costs 16 bucks, replace the broken parts with new ones, reassemble machine. Never ever do a blanket/comforter in your machine again!!
Mar 31, 2009 | Kenmore 24032\24036 Top Load Washer
Frigidaire GLWS1339CS Top Loader, Won't Spin
Smoke usually means a major overheating of a belt or agitator transmission, get this checked before trying to run it again,
Jun 25, 2008 | Frigidaire GLWS1339CS Top Load Washer
Loud clicking noise - wont agitate or spin
I had the same clicking noise. Turned out to be the coupling between the motor and transmission. A $15 plus 1 hour labor fix
Nov 10, 2007 | Kenmore 22422 Top Load Washer
Frigidaire washer won't agitate
Probably a stripped gear in the transmission.
Jan 28, 2007 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
42 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
