Question about Hitachi 42HDS69 42 in. Plasma Television
My hitachi tv is dead
I took it apart and checked everything on it and in it, I also cleaned it everything seen to be OK, its got power but no lights anywhere.
    Top Expert:
  • Hitachi Master
  • 74,136 Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Dec 05, 2014
My hitachi LE42H508 still wont turn on after replacing power board. Power cord has power coming in but still nothing. No noise lights. Help
Your main board is probably dead and is not allowing the power supply to power up from standby mode. I have seen a few of these TV's fail recently and was able to fix them by replacing the eeprom on the main board.
Jul 23, 2016 | Hitachi Televison & Video
Hitachi 1350 projector dead, no power. cleaned everywhere, changed the bulb, nothing I do gets power into it.
I assume the projectors are of similar age and have similar useage history? Not certain why they would fail together, but the most probable cause is faulty switch mode power supplies. The electrolytic capacitors in these supplies a relatively short working life, especially when installed in high temperature environments - like a video projector. new caps in the supplies may be all that's required to solve the issue. If you have other similar projectors, they may well be approaching the same problem.
Any reasonably competent TV repair tech should be able to check the supplies for you, and repair them if found faulty :o)
Apr 05, 2014 | Hitachi PJTX100 Multimedia Projector
Iput in new lamp 25 days ago as working good. now when i t/on tv. It comes on for about 20 sec @ then t/off for aout 20 sec. By it self. and keeps repeating on/off/on/off/on/off picture @ sound ok.
The lamp of course would be logical to suspect---the only suggestion I have as have seen this before is some of these sets if enough dust inside will do this---seen ones that would play twenty minutes and either shut off or off and on.
Seen dead ones also where dust on the fans slows them just a little-set monitors things like that===usually we take back off and set outside with a air compressor and clean all air channels out (air gets taken in from front area and exits rear).
It at worst will rule this possible solution out and at best may resolve the issue. Seen say fifty or more sets where after cleaning with air (no matter how clean the house is it may look like a dust storm when you air it out) the issue was gone.
One even had golf ball sized white spots in picture--dust inside the two month old set's light engine.
Good luck and I hope it helps as it cannot hurt.
Jun 13, 2012 | Hitachi Televison & Video
Model: Hitachi P50a402 plasma TV blinking blue light upfront but no TV signal or boot screen. Openned the unit and tried to get readings on power supply board, it seems I do have 3 and 5V but not able...
Did your already check your H- out section. This happen when your TV at protection mode. Its mean it detect defective parts inside the unit. Isolate the H- out power and open the TV Then check voltage if there's power reading meaning that the H- out section have problem.
Aug 12, 2011 | Hitachi P50A402 50 in. Plasma TV
I have a 61 inch rear projection TV. When moving we took the back off of the TV so that we could navigate it up the stairway to my new apartment. Once in the apartment we plugged it in and it wouldn't go...
Check ur power source?Yes,wait like about an hour later for the tv resetting back to it factory setting.Recheck all connections inside of the tv for loses or untighten connections?Make sure all connections are tighten and no damage to all the PCB boards tries again tv should work now.
Jan 14, 2011 | Hitachi 61SWX10B 61" Rear Projection...
Hitachi 42PD7200 Plasma TV gone dead
this problem is from smps power supply of your tv circuit, may be power capacitor may be short , power transister may be short pls check some spair of power supply
Apr 06, 2010 | Hitachi 42HDT79 42 in. Plasma Television
My TV 50ux58b hitachi is dead not Power
hello. sorry it took so long to get back to you. well. the first thing to do is to check the fuse. did you.?
Jul 03, 2008 | Hitachi 50UX58B 50" Rear Projection...
I have the light engine, can i fix it?
ok, i have fixed it. you have to take the whole thing apart and just switch it out. took me about 7 hours, almost everything comes off the tv. pull off the entire screen and box. then take off the back metal frames. unplug about 8 wires and swap it out.
May 20, 2008 | Hitachi 60V500 60" Rear Projection...
No power
How many led lights are showing in back of set/ Hitachi, has a way of telling what is wrong by the numbers and sequence the lights give off. Most of the time it's the convergence going bad. You should have seen some colour distortion before set wet out.
Sep 04, 2007 | Hitachi UltraVision 55HDS52 Television
Hitachi 50ux58b
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Jan 02, 2007 | Hitachi 50UX58B 50" Rear Projection...
Hitachi 42HDS69 42 in. Plasma Television Logo
142 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
