Lipi 2280+ printer head suaitable for 2265
Is lipi 2280+ suaitable for 2265. and printer head is too hot and not firing.
5 Suggested Answers
  • 169 Answers
SOURCE: i need to know proper
The Reference Manual for the 2265 on the Dascom web site should show you how to repalce the ribbon;
http://www.dascom.co.uk/documentation/serial-matrix/61-t2265.html#176
Posted on Dec 15, 2009
MUKHTAR
  • 2017 Answers
SOURCE: pin not firing
It is hardware problem which is very difficult it is better if you can call to the service engineer.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Feb 20, 2010
SOURCE: tally 2280 printer givesw printhead hot error
wants one printer head tally 2280+ at lucknow please tell me dealer at lucknow
Posted on Jan 21, 2011
SOURCE: i have problem with lipi
LIPI PRINTER T 6050 PRINTERHEAD PRICE
LOGIC CARD PRICE
REPLACEMENT LOGIC CARD PRICE
RIBBEN CARTRIDEV PRICE
LOGIC CARD MAXIUM REPAIRE PRICE
Posted on Mar 27, 2011
LIPI 2265 printer showing hardware alram 0578
with out having all the numbers from your error code on the screen (most needed is the number ini the lower left) it is impossible to decode or decide what is wrong with your printer. more info is required. do not replace your logic board or your print cables. (rookie)
Oct 22, 2013 | TallyGenicom 2265+ Matrix Printer
Hi There. I have Tally T2265 Serial Matrix Printer. It shows "Hardware Alarm & Check Ribbon Error" after printing 2 or 3 pages. Sometime it prints 7-8 pages and sometime it prints 2-3lines...
The check ribbon message on the 2265 indicates the printer is detecting problems with moving the print head. You have ruled out the ribbon as being the cause of the problem by using ribbons from another printer.
Before suspecting other components check the printer model, if the printer is a 2265+ check to ensure the correct ribbon is used. Note the ribbon for the 2265+ is different to the 2265 ribbon. The 2265+ has a ribbon sensor to detect the ribbon moving. If the printer is a 2265+ the part number for the ribbon should be 062471.
If the correct ribbon is used the problem could be the timing strip which could be dirty or warn. Try cleaning this and check for damage.
The problem can also be caused by a dirty or lubricated carriage shaft, the carriage shaft should be clean and dry running - Keep clean of any type of lubricant.
The problem can also be caused by the timing station on the carriage, the carriage motor.
Mar 10, 2011 | TallyGenicom 2280 Matrix Printer
I have problem with lipi t6050 printer head allinmnet plese send me how to allin head of the printer
LOGIC CARD PRICE
Dec 18, 2010 | Tally Line Matrix T6050 Printer
AGA ERROR IN TALLY 2265
either your aga motor is bad or your board set is bad. Turn unit on watch the printhead while opening the cover. The printhead should move back and display "cover open". When you close cover the printhead should move closer to paper. If not bad aga motor or bad board set.
Dec 15, 2010 | Tally Dot Matrix T2265C Printer
My printer Lipi 2280+ printing properly with 15*12 and fanfold 8.5*12 paper,but when i am using paper width slighly smaller than it less than 8.5 width printer gives paper with error>kindly suggest
You see the "Paper Width Error" on the 2280+ because the print job being recived by the pritner is wider than the physical paper which will cause the pritner to print on the platten, in order to rectify the problem.
  1. Ensure the print job on the system is less than 8.5 inches wider
  2. Perhaps move the paper in the tractors to the right
  3. Disabling the Paper Width Sensor will clear the error but may cause the printer to print on the Platten which may reduce print head life, the Paper Width Sensor can be disabled in the following way;
    Start with the printer Powered OFF
    Hold Down the ONLINE button and power the printer ON keep ONLINE held down until you see ASCII80 ASCII136 on the top line of the display
    Press the button under NEXT repeatedly until you see APW on the top line of the display
    Press the button under APW
    Set APW = OFF
    This will disable the APW sensor and you will not see the Paper Width Error
Dec 08, 2010 | TallyGenicom 2280 Matrix Printer
Pin not firing
Thanks.
Have a good day.
Feb 20, 2010 | Tally Line Matrix T6215 Printer
Tally t2265 'check ribbon' hardware alarm... carriage moves ok, 2 new ribbons ...that came from other machines,,,, ribbon drive seems fine, could it be encoder strip??? please help!
Befor suspecting other components check the pritner model, if the printer is a 2265+ check to ensure the correct ribbon is used. Note the ribbon for the 2265+ is different to the 2265 ribbon. The 2265+ has a ribbon sensor to detect the ribbon moving. If the printer is a 2265+ the part number for the ribon should be 062471.
If the correct ribbon is used the problem could be the timming strip which could be dirty or warn. Try cleaning this and check for damage.
The problem can also be cused by the timing station on the carraige, the carriage motor.
Jul 03, 2009 | TallyGenicom 2280 Matrix Printer
Tally 2280 printer givesw printhead hot error
Is it a + version, with an Ethernet board included? These were known to cause such errors, seamingly not related at all. Try replacing the Ethernet board, or at least pull t out and disable to try.
Feb 14, 2009 | TallyGenicom 2280 Matrix Printer
Lipi 6306 Line printer
i want to knwon the which operating system supports the lipi tally genicom line printer model 6306
Oct 16, 2008 | Office Equipment & Supplies
51 people viewed this question
jasbo
jasbo
