Question about Dryers
Dryer that wont stop tumbling
The dryer will not stop tumbling ever unless I open the door. Even if NONE of the cycles are selected and the dryer is not heating for a cycle; if I shut the door, the tumbler starts. How do I stop this?
    Master:
  • 706 Answers
Well we know the door switch is functioning properly so that usually just leave a timer issue.
Posted on Dec 05, 2014
exspert
  • 55 Answers
SOURCE: Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Posted on Jan 24, 2008
  • 7 Answers
SOURCE: Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Posted on Jan 21, 2009
SOURCE: whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
My dryer is not heating, where is the cupling at in the dryer i have it open tho
Posted on Feb 02, 2009
dragonsthatk
  • 547 Answers
SOURCE: Frigidaire affinity dryer doesn't have heat but it tumbles, stops
clean air duct
Posted on Mar 13, 2009
  • 6 Answers
SOURCE: dryer runs then stops after short periods (5-10 mins)
THere maybe a thermal limit sensor gone bad. Keeps the dryer from over-heating. Located behind rear panel on most and mounted on the heat tube. Verify with volt/ohm meter if possible
Posted on Jul 30, 2009
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
Dryer still tumbles even when door is open. It will turn of and stop when i turn it manually to off
The door actuator mounted on the door or the switch mounted on the dryer is missing or broken. The dryer is supposed to stop if the door is opened. Replace the door actuator or the switch.
Mar 03, 2015 | Dryers
MED9700SQ dryer sensor light comes on but will not run
I have the same problem with the same model Maytag dryer. I called a repairman and paid a hefty service charge and the repairman found that the electronic control board needed to be replaced. This particular part (Part #8558455) costs between $250 and $350. Evidently there are many people with the same problem.
Feb 02, 2013 | Maytag MED9700S Electric Dryer
Tubmble dryer wont turn
Sounds like you have a bad idler and/or belt.
May 31, 2012 | Fisher and Paykel Dryers
I have a fridgedaire front load dryer (Model AEQ6700FS0) and it will start up, run for about 30 seconds and then it stops tumbling and the 3 lights on the far right (drying, cooldown, extended tumble)...
This is just a guess in a way, as I don't have specific knowledge about your particular model, but could it be a wrinkle prevention feature? I know some dryers have a feature which will cycle the dryer on for an occasional short tumble if the regular cycle ends and the clothes have not been removed. Opening the door might be all it takes to cancel the function.
Jun 30, 2011 | Dryers
Dryer wont tumble
i think the belt is slipping bad on your dryer,,
what puzzels me is you say you can here the motor hum? is it a hum? or a buzz?? if its a buzz then its more likley to be the motor as its past its best and it needs if it needs a new motor as well, it would work out cheeper to buy a new tumble dryer
Nov 16, 2009 | Dryers
Fisher ED56 dryer wont turn off!
HI, this will occur if the timer control module or control board has failed. replacing the timer or control will fix this issue.
thank you,
vijay (vote for me)
Sep 24, 2009 | Fisher and Paykel Dryers
Kenmore dryer wont stop, just cycles through all the setting
Replace the timer if it continues through and past a timed cycle.
Aug 03, 2009 | Kenmore 62802 Electric Dryer
Dryers Logo
129 people viewed this question
Top Dryers Experts
