Question about Sewing Machines
Feed dog dial disappeared into machine. Cannot adjust feed dogs.
I went from free motion back to straight stitch, turned machine off and on, changed stitches sewed.
Tech it to a sewing machine repair guy
who will fish the control back out and remount it
Posted on Dec 05, 2014
  • 8 Answers
SOURCE: Dropping Feed dogs on kenmore model 19233
Remove extension table/accessory box by gentle pulling it away from machine. You are left with just the free arm. In the back of the free arm, lower left corner, you will fine the feed dog lever. Push the leaver to the right to lower the feed dog.Instructions for lowering and raising the feed dog are on page 48 of your owner's manual. Good luck!
Posted on Jan 01, 2008
  • 201 Answers
SOURCE: Free Motion Sewing - Jams
I don't have a solution, but wanted to remind users of this machine that it does not do the proper free motion action until you reach a certain speed. This information is on page 26 of my manual (older machine, so page no. might have changed with newer manuals). You can stitch at the lower speeds, but it does not "hover" and allow you to move the project swiftly and smoothly.
If you can sew regular sewing without thread/bobbin issues, then it is probably something to do with how you have set/threaded/used the free motion to cause the stoppage. Make sure you have a sharp (i.e. new) needle of the correct size for your thread, that the bobbin thread is the same weight thread as the top thread. Turn on the Needle Down button. There is a Free Motion setting in the Set menu, but I have no idea what it does. I turn it on anyway, just in case! What foot are you using? If you don't have one of the free motion feet (there are quite a few to choose from!) use the embroidery foot (small clear plastic one).
Pam
Posted on Apr 15, 2008
RickE1
  • 202 Answers
SOURCE: Bernina 1008 feed dog problem.
Your machine needs oiling. The feeddogs are stuck. Could be in several places. You would have to remove the back and side covers to get to what needs cleaning and oiling. Especially behind that knob. Just removing the covers is a job so I can't recommend you do this unless your trained. But you can try. Don't forget the screws beneith the machine. But really, there is too much behind the handwheel for a novice to deal with. Maybe see if you can just let some sewing machine oil just run down behind the feedog knob and work it alot.
Good luck.
Posted on Feb 07, 2009
  • 3 Answers
Pull out the removable table and you will see the drop down feed dogs switch lever behind the back of the machine. Move that lever to the left or right to have feed dogs go back to normal sewing mode OR for embroidery mode.
Posted on Mar 07, 2009
SOURCE: singer stylist sewing machine 534 is not stitching
Feed dog drive gear(2) are plastic and are probably stripped. Always replace them in pairs. While you are at it replace both hook drive gears as well. It will run as good as new.
Posted on Mar 28, 2009
Adjust from free motion to straight stitching
Change from a free-motion foot to a straight stitch or zig-zag foot. Raise the feed dogs. Adjust the width and length stitch selectors to your preference.
Aug 26, 2017 | Sewing Machines
Adjust presser foot from free motion back to straight stitching
You need to change the presser foot to one used for straight stitch or zig-zag. The foot for free motion quilting is too short in height to connect with the feed dogs.
How to adjust feed dog
Are you asking how to raise or lower the feed dogs? If so, there is a dial somewhere on your machine that does that. It's usually explained in the "darning" section of your manual.
If you are asking how to lengthen the stitch, that setting will increase the distance the feed dog makes with every backward/forward motion which moves the fabric through the machine faster. Look for the stitch length instruction in your manual.
If you want to actually adjust the feed dogs (ie how far up they rise, etc.), that should be done by a technician as special tools are required to set it properly.
Apr 09, 2016 | Sewing Machines
Just wanted to check troubleshooting ideas on the feed dogs. They seem to be engaged but not running fabric through when sewing
Check that the stitch length is set to make ~10 stitches per inch. This stitch is long enough to actually move the fabric. If the stitch length is set too short, the fabric will stay barely move and the needle will stitch almost in place.
Check that the feed dogs have not been dropped for darning or free motion quilting. In this position, they do not rise and are, therefore, unable to contact the fabric to pull it through the machine.
With the presser foot raised and using no fabric, hand rotate the handwheel and watch if the feed dogs actually drop down below the needle plate, move toward the front of the machine, then rise above the needle plate, and move toward the back of the machine. If the feed dogs are moving in this manner, then they are functioning properly.
Is there lint or gunk stuck in the feed dogs? This will restrict the ability of the feed dogs to grip the fabric.
Are the feed dogs worn? Are the little teeth worn so there are no sharp points?
What type fabric are you using? If it is very light-weight or slick fabric, the feed dogs will have a difficult time gripping the fabric. Most machines have a presser foot pressure adjustment so that more pressure is applied between the presser foot and the feed dogs. Consult your Owner's Manual. The adjustment is usually a dial either on the left side of the machine, on the front of the machine located above the needle bar, or on vintage machines it is usually a skrew located under the top lid above the needle bar.
Mar 26, 2016 | Husqvarna Sewing Machines
How do i lower the feed dog for free motion sewing??
Oooh, consult your owner's manual. Frequently, industrial machines are limited in their capabilities so your machine may not have the feed dog lowering ability. Some other domestic machines without the capability can use a plate to cover the feed dogs while free motion quilting, but that probably wouldn't be a good thing to try if your machine is not made for sewing without the feed dogs in use.
Nov 05, 2015 | Juki DDL-5550 Industrial Straight Stitch...
Does this model have a feed dog that can be lowered for free motion quilting?
    A set of feed dogs typically resembles two or three short, thin metal bars, crosscut with diagonal teeth, which move back and forth in slots in a sewing machine's needle plate. Their purpose is to pull ("feed") the fabric through themachine, in discrete steps, in-between stitches.
    Feed dogs - Wikipedia, the free encyclopedia
    https://en.wikipedia.org/wiki/Feed_dogs Wikipedia
Oct 25, 2015 | Sewing Machines
Fabric does not feed through machine
When you sew the machine must be set at the correct settings. If your machine won't straight stitch, turn it off at the power point and then turn it back on. Most machines reset to the default straight stitch setting. Secondly when you sew the presser foot must be down. This engages the "feed dogs" or the triangular looking "teeth" below the presser foot. As you sew, the feed dogs grab the two layers of fabric pulling them through, the thread above (spool) and the thread below (bobbin) meet to form the stitch. Finally, maybe fiddling around with dials and settings you may have dropped, or disengaged the feed dogs. Check with your manual on how to re-engage the feed dogs. Hope this helps and happy sewing. Remember, when all else fails..... read the manual.
Mar 11, 2015 | Brother XL-5700 Mechanical Sewing Machine
Which foot do I use for quilting
a quilting foot or buy one with a round hole in it great
Mar 09, 2015 | Sewing Machines
I have husqvana designer 2 , my problem is after I have been doing stipling on my machine I cant get it back to other sewing it keeps telling me to put on a q foot which I dont have .How do I get it off...
have you lowered the feed dogs to do the stippling ie free motion embroidery??? If so you will need to renage the feed dogs, usually a slide at the front of the machine base or at the back of the free arm.
I would suggest taking off the foot, putting on the regular sewing foot, checking that the feed dogs are engaged, setting it back to a straight stitch setting. Then turn it off, wait 30 seconds and turn it back on and see if this resets it to normal stitching mode.
Sep 14, 2011 | Sewing Machines
Material doesnot move forward when stitching
there is a couple of things to check:
What stitch length have you got the machine set to? Should be 2.5 for a normal straight stitch - how you set this will depend on the make and model but most machines have some way to adjust the stitch length and width.
Or are the feed dogs lowered? this is sometimes a slide or button on the front base of the machine, sometimes a slide at the back of the free arm, again, it varies between machines. You may need to refer to your machine's manual to establish how this is controlled - you lower feed dogs for things like free motion embroidery so if your machine is computerised with lots of stitches it may even make this adjustment automatically when you choose a free motion embroidery stitch. If that is the case then changing it back to regular straight stitch should return the feed dogs to normal function.
If you raise the pressure foot, and manually turn the flywheel towards you through a couple of stitch sequences can you see the feed dogs raising and falling? If you can't see this happening at all and you are sure that the feed dogs are engaged then it is possible a drive gear in the free arm has failed in which case, you'll need to take the machine to a serviceman.
Jul 12, 2011 | Sewing Machines
Sewing Machines Logo
54 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
