Question about B&K AVR-307 Receiver
I the person with the B&k 307 that buzzes when turned on. I hook the ground wire up to copper pipe and i still got the buzzing sound. what else could be wrong
Can it be a short somewhere and how would i find the short or what the problem is?
Power Supply Capacitor is blown, you need to replace it.
Posted on Sep 24, 2015
    Master:
  • 373 Answers
Some components inside the amp will cause an output buzz when they fail. Time to take it in for service.
Posted on Dec 18, 2014
2 Suggested Answers
SOURCE: i have a b&k 307 that's makes the buzzing noise. How can i check the fault/short in the receiver.
Your ground it not ok
Posted on Dec 03, 2014
How do i ground it
If your home has copper water pipes, then run a wire to the closest pipe and clamp it right to it.
Dec 03, 2014 | B&K AVR-307 Receiver
My line 6 spider jam buzzes in all amp models. I tried a reset with no luck. Sound almost like a blown speaker but that is not the case. All recording play perfectly.
Sound like an open ground wire on the output jack. The buzzing is usually due to this ground problem. check all wiring to the output jack.
Nov 08, 2014 | Audio Players & Recorders
I have a kicker impulse ix702 that keeps blowing its fuse when I turn it on.
Take a volt meter, put it on continuity, cross it between the battery and ground term. on the amp and make sure you get no buzz, now cross it with the remote term. and make sure no buzz. Make sure the only thing hooked up is the battery and ground then take a wire and cross it between the battery input and the rem. to turn it on and see if it blows. Make sure all other cables are removed.
Sep 04, 2011 | Kicker Car Audio & Video
The 3 front speakers have started to buzz. When I unplug them in moves to the rear 2 speakers. I orginally thought it was the speakers so I got new ones, same problem. Not sure if it is my reciever getting...
This is a grounding issue either between pieces of equipment or inside the receiver itself.
There are other possible causes, but this will almost always be a grounding issue.
I recommend unplugging everything and hooking it up piece by piece till the buzz return to isolate the issue.
IE - start with nothing but the receiver and speakers hooked up. Turn on the radio. If the speakers buzz, the receiver has an issue and needs to be repaired or replaced.
If there's no buzz, hook up the DVD player. If the buzz returns, there's some issue between the DVD and the receiver....
If the buzz hasn't returned, hook up the.....<insert name of next piece of equipment here>
you get the idea.
Feb 21, 2011 | Audio Players & Recorders
I have a Pioneer Gm-x722, and i hooked it up to 2 6x9 speakers and two 6.5" speakers and I get a buzzing sound, how to I clear up the buzzing?
try grounding the shield of the rca cables and see if the buzzing goes away. if so you have a bad ground to the rcas either in the deck or the amp. grounding the rca cable shield should take care of the problem.
Mar 26, 2010 | Pioneer GM-X722 Car Audio Amplifier
Noisy/buzz
Usally a ground loop isolator will fix that problem. It plugs into the RCA's between the radio and the amp.
Try to reground the amp in a different spot.
Or run a refrence ground from the deck to the amp next to the remote turn on wire. (still keep your main amp ground hooked up)
DO NOT run your power wire next to the RCA's, that will induce a field which in turn can cause that buzzing sound.
Jun 03, 2009 | Crate SPA1600 Power Amplifier - SPA Series...
Amplifier is buzzing when i plug in my les paul but ok with other
Several things to try:
- Probably already have, but another guitar cord.
- Ground switch on the amp?
- I had an older guitar that buzzed due to the pickups. While touching the strings, all was well - I was acting as the ground then. The ground wire broke, so it buzzed no matter what. The ground wire ran to the metal bridge.
- Play louder than the buzz! :)
Mar 23, 2009 | Epiphone Les Paul 100 Electric Guitar
Buzzing from speakers
sounds like a capacitor is taking a long time to do it's job. You might want to see how much it would cost to repair.
Jan 13, 2008 | Audio Players & Recorders
No sound at all
The jumpers are there to connect the preamp section to the power amp section and are required for the receiver to opperate properly. Make sure the receiver is set to the proper input, in this case: CD. If there are A/B speaker connections, be sure the receiver is set to match the connectors you're using. If there is still no sound, profesional service will be required.
Sep 26, 2007 | Yamaha DSP-A1000 5-Channel Amplifier
Speakers making loud buzzing noise
From your alternator, Make sure none of your RCA's are near a power wire, check your grounds as well.
Jan 09, 2007 | Pioneer TS-D690R Coaxial Car Speaker
B&K AVR-307 Receiver Logo
127 people viewed this question
Top B&K Audio Players & Recorders Experts
shaun taylor
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a B&K Audio Player and Recorder Expert? Answer questions, earn points and help others
