Question about Humidifiers
Do you have a replacement impeller for your 1.2 gal table top humidifier? model # 1du2234-um
I need a new impeller.Mine is very noisy!!Thanks.
2 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: Hi, I lost the directions
tap water is fine to use.
Good Luck And Please Rate FixYa!
Posted on Jan 07, 2009
Fan makes noise
Not sure how long you have had this humidifier. If the motor is getting louder it probably needs a new motor. It is possible if it is making a fan blade noise that something is hitting the fan blade. If that is happening try to open enough to see if the fan blade (impeller) is being impeded.
Mar 27, 2012 | Humidifiers
Have two Hunter humidifiers - model 34357-about 5 years old #1, fan just quit running. All else seems normal. #2, Unit starts running and then stops with the humidity reading at max. Since the...
This is the manual for your de-humidifier. It lists the part number for the power and fan control switch and it states they have a 5 year warranty.
http://www.hunter-humidifiers.com/manuals/34357.pdf
This is their link for support:
http://www.hunterair.com/suppo.95rt
They have a msrp on the unit at 84.95. What I wuld do is definately check into the warranty ting with them and I'm sure you could probably salvage one ot of the two units. Replacement parts may not be cost effective. You can test the motor from #1 in #2 and, if it runs, you know it has to be a switch or a start capacitor, etc. I guess it all depends on how much tinkering you want to do. I would think there is a good chance there is a wiring diagram for the motor somewhere inside the case or on the motor. Good luck.
Dave
Jun 05, 2011 | Hunter 34357 Humidifier
It blows air, but no moisture comes out or is used from cannister. where could the problem be?
You need to add salt. I'm not sure if table salt or some other salt is best, but it requires that addition to create noticeable mist. I use probably 1 tsp.
Maybe you can answer my question. What is the model number? I've been searching for and have found replacement filters, but I'm not sure which ones to buy. Please let me know at kati.pea@gmail.com
Jan 10, 2010 | Robitussin Cool Moisture 1 Gal. Humidifier
HOW TO REPLACE FILTER #wf813
It's easy to find a replacement if you know what the model number is of the humidifier. If you do, let me know.
Dec 08, 2009 | Robitussin Cool Moisture 1 Gal. Humidifier
I have a Hunter Carefree Humidifier Plus. When I
We were having the same problem. Here is how I fixed it but its hard to explain...
I took the main white part off and laid it side ways on a table looking inside there is a tube that goes from the top towards the main fan then connects to a plastic part that is shaped like a "p" In the middle part of the "p" you an see I tiny little gear. I manually turned the gear with a paper clip a few times and it worked. I had no idea what I was doing but I was determined!!!
Dec 07, 2009 | Hunter CareFree Plus 33222 Humidifier
White dust coming out of humidifier
A concern is minerals in the water. Impeller and ultrasonic designs send these minerals into the air. If the water in your area contains a lot of minerals, you will notice them as dust. The EPA does not issue health warnings about minerals in the air, but does recommend using low-mineral water (such as distilled water) in your humidifier. Many ultrasonic models feature a demineralization cartridge that filters minerals out of the water to prevent the dust.
Good Luck
Apr 05, 2008 | Bionaire BU4000-UC Humidifier
Aprilaire 600 bypass water flow rate
The water is only dispensing over the evaporator pad while the furnace is in the heating mode. When the furnace finishes cycling the humidifier will also stop.
Mar 04, 2008 | Aprilaire 600 Humidifier
Humidifiers Logo
63 people viewed this question
Top Humidifiers Experts
Mack Baxter
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
