Question about Pentax Optio Wg-1 Series 14MP Waterproof Adventure
Kakima, thanks for the response. Pentax Optio WG-1 Total time does increase when resolution is reduced. Still the same total time with 4GB or 16GB.The manual states that the camera will record in blo
Kakima, thanks for the response. Pentax Optio WG-1 Total time does increase when resolution is reduced. Still the same total time with 4GB or 16GB.The manual states that the camera will record in blocks of 2GB. If recording stops at 2GB start again to continue recording the rest of the movie in blocks of 2GB. If true..total time will be greatly increased per # of GBs. Confusing Why did they do that? Is a video clip, one continual movie with out stopping? Thanks again Don
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
Not long ago camera's, computer's etc could not imagine a file or a memory device larger that 2Gigs. Making files in 2 gig sections was the workaround. If this is a newer model, this should not be a problem.
Posted on Feb 06, 2015
5 Suggested Answers
SOURCE: My Pentax Optio s5Z is stuck on one mode
I also had this problem. I think it is caused when the camera is turned off while in the viewing part of the camera. That is, I had gone to look at the video that I had just taken, but didn't and then turned the camera off. The camera is then as you have described it.
The only way I could get it back to normal is to connect the camera to the computer, using the cable, and download the photos and videos. When the download is complete, disconnect the camera and it should be OK.
Good luck, cheers. Phil
Posted on Oct 30, 2007
  • 102366 Answers
SOURCE: Problem with memory card
Quoting from page 107 of my copy of the manual:
"Recording can continue until the built-in memory/SD memory card is full, or the size of the recorded movie reaches 4GB."
From that, it's apparent that a 16GB card won't let you record longer videos than the 4GB card. It will let you record four such videos, however.
Posted on Feb 10, 2010
  • 25 Answers
SOURCE: I have a Pentax Optio A20. I currently user an
It will take a 2 GB card, I am using one now.
I can't tell you about a 4GB card, but that's a LOT of storage, so you probably don't really need a 4GB card anyhow???
Posted on Jun 21, 2010
SOURCE: I own a pentax camera optio s6 model with ACDSee
I am having the same problem. On the pentax site it does not list disc s-sw39. Apparently it only applies to later models. oh well....
Posted on Feb 19, 2011
What battery do I use in the Pentax Optico WGII
The Pentax Optio WG-2 takes an OEM manufactured battery or one designed for it. Google "Pentax Optio WG-2 replacement battery" or do a Amazon.com search for the same and you'll get thousands of options where to buy.
Oct 20, 2014 | Pentax Optio Cameras
How do I find software compatible with windows 8.1?
The Pentax parent company has new software that will work on Windows 8.1. You can get it here:
Ricoh Imaging Downloads Literature RICOH Imaging
Oct 16, 2014 | Pentax Optio Wg-1 14MP Adventure...
Pentax optio WG 2 water leak in battery compartment
And with rust around the seal it will leak even more. Is there no guaranty on the camera anymore? I would contact Pentax, to ask them what to do. Special when I needed the camera in a moist (under water) environment.
Jan 26, 2014 | Pentax Optio Wg-2 Gps Adventure Orange...
How do i empty memory card pentax wg-1
You can use the camera's Menu to format the memory, this will delete all your photos from memory.
Oct 19, 2012 | Pentax Optio M20 Digital Camera
Where can I download a manual for a Pentax optio wg-2
You may download a copy of the manual here.
There's also a GPS quick guide here.
May 13, 2012 | Pentax Optio WG-2 16 Megapixel Compact...
I have a Pentax Optio A20. I currently user an Sandisc Ultra II 1.0 GB card. I can't find those cards anymore. I'm not sure if the camera will support a SanDisk 4GB UltraII SDHC Card or a SanDisk 2GB...
Dec 12, 2009 | Pentax Optio A20 Digital Camera
Pentax Optio MX4 won't read my new SDHC 4gb
Does the camera work with any other card? Was the card formatted in the camera? Some cards from some manufacturers just don't work in some cameras.
Sep 12, 2009 | Pentax Optio MX4 Digital Camera
Pentax Optio 60
Largest card for the Optio 60 is 2GB. The camera is not able to take 4GB and larger SDHC type cards. If I answered the question to your satisfaction, don't forget to rate it. Thanks
Feb 26, 2009 | Pentax Optio 60 Digital Camera
your camera can only read so many partitions
( File Allocation Tables )
( partitions are sections of the total volume )
Like slices of a cake.
which equals 4 GB, total.
so it will never be able to read more than this.
Like FAT32 on a Pc, will read 32GB
but you could have a 100GB hard drive in the machine, still reads 32GB only, so even on a PC 68GB would be wasted.
The file format on the camera can not change,
So you are stuck with 4GB max reading.
Hope this halps
Regards
Richard.
Oct 04, 2008 | Pentax Optio W30 Digital Camera
Largest capacity SD card for Pentax Optio S5N
The maximum supported size is most likely 2GB SD Card. Cards with 4GB and more are following a new (incompatible) standard called SDHC (SD High Capacity), SDHC cards work only in devices specifically supporting SDHC. The Optio S5N uses the old SD standard where 2GB are the maximum size.
May 17, 2008 | Pentax Optio S5n Digital Camera
Pentax Optio Wg-1 Series 14MP Waterproof Adventure Logo
47 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
