Question about LG 42LH30 42 in. LCD TV
Have an LG #42LH30 colored stripes down left side static on right
I have just recieved tv and only plug in to see what the issue is i am thinking T-CON i have all the boards but the main i used on my own LG same model
    Top Expert:
  • LG Master
  • 74,383 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Dec 05, 2014
Mark_Webber
  • 472 Answers
SOURCE: LG RZ-26LZ50 LCD Television-Solid Black line down the right had side of the screen
It's the driver tabs that operate that section of the panel. To have them repaired/replaced can be very expensive and is normally just replaced completely as a whole panel (at least while under warranty). If it is out of warranty, then get a few quotes over the phone. This will help dramatically when you explain to your wife that you are about ot go shopping to buy a new TV.
I find things like "Have I told you how good you look today" help when this process is taking place.
Sorry for the bad news.
Posted on Apr 12, 2008
SOURCE: Red Stripe, right side
Follow-up. I found the slip on which the LG tech wrote down the part number for the board to fix the vertical red stripe. I was mistaken in my previous post. It was not the Z-Drive board. The board you want is:
X DRIVE BOARD; Part 6871QRH043A
Type in the part number in a search engine and yuo will find multiple places to purchase. Ebay may be the cheapest. That's where I got another part which got my picture back. I did not buy this part myself because now that I have my picture back, I do not want to screw it up, so I live with the red stripe.
Posted on Jun 06, 2008
SOURCE: Issue with LG Plasma tv model # DU-42PX12X
Another "same probelm"
My set has encountered this magical 50/50 split screen and it seems to be quite a problem since I am not the only one researching this issue. LG was of no use because of course it is just out of warranty. Any solutions on fixing this or am I out of money in buying a new plasma?
Posted on Nov 10, 2009
  • 131 Answers
SOURCE: red line down right and left side of 42" LG plasma.
Hello; I am John at J D Electronics in Poland, Maine. I have an LG TV that was donated to me. It is a plasma model DU-42PX12X. It had 1 inch wide red and green vertical bar on the right and a blue and yellow on the left. These bars appeared intermittently. pressing on the control board would make the bars go away. I have read many blogs on this problem and they all say to replace the control board located under that huge A / V input board ( held in by 4 screws on the large aluminum frame). The original part is # 6871QCH038A The replacement ends with a C instead of an A Aprox 90 to 135 dollars. This board is used on many different LG and Zenith models and is a HIGH failure rate part. I like to know WHY parts/boards fail and I found out why this board fails. There is a large square IC in middle of the board aprx 1 1/8 inch square. This type of IC is called BGA or Ball Grid Array. The solder connections cannot be seen , since they are under the IC . This IC was not properly soldered at the factory and that is why hundreds of these sets failed. I used my hot air soldering station on it's highest setting to heat up this IC . The IC must be directly heated from the top and some heat on the bottom of the PC Board. Liquid flux should applied to the 4 side edges of the IC prior to heating. The bars are now gone! To get to this board, remove all perimeter screws and all middle screws of the back cover. The A V board will hinge back to expose the control board if you unplug the cables to the side inputs and the one to the button board. The set will still run face down on a table with something to prop up the bottom screen so you can watch the bars. If the set was run for a long time with the bars, there will be some darkening where the bars have " burned" the screen. This is perminent, but usually acceptable.
Posted on Dec 16, 2009
toolkits
  • 1099 Answers
SOURCE: replacement screen for a LG 42lh30
hello, you can the screen from the below link. tries websites like Shopjimmy.com,Ebay.com to buy a whole screen for the replacement.
Good luck...
Posted on May 22, 2010
This is the third time I have posted question. have an LG LCD 42LH30 left side has colored stripes running down the side, I am thinking T-CON board? can some one give me an answer please @ wal5ter1999
Dec 09, 2014 | LG Televison & Video
MY LG 42LH30 goes black on half the screen after turning it on.
do any of the "techs" responding have any electronics background at all. Please don't answer questions if you have no clue. The person who said the the plasma has tiny flourscent bulbs has a drug problem. Must have gotten that answer from a comic book.
Jul 12, 2012 | LG 42LC2D 42 in. LCD HDTV
What wire colors do i connect to my old wires in my 95 dodge neon
For Dodge Neons:
Factory in-dash wire harness has 2 pc harness (black plug and gray plug).
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
Metal braid plastic connector attached to back of radio is the ground wire.
May 20, 2010 | Car Audio & Video
For the Clarion DXZ945MP CD Player for car audio, I do not know the the wire harness color wire diagram? The wiring harness on my Monte Carlo 2000 reads what color wire goes to what, on the side of the...
3amp yellow battery for deck
15 amp yellow is another battery wire
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
red accessory
hope this helps
pls rate cause people arnt rating
Nov 05, 2009 | Clarion DXZ945MP CD Player
LG screen out
Bad logic board.Always replace this along with y and z sustain boards.On some LG/Zenith sets they come as a replacement part kit.
Jan 10, 2009 | LG 50PX1D 50 in. Plasma Television
I need a wiring diagram for a Pioneer DEH-P200 CD player/reciever
Memory: yellow Power: red Ground: black
Front right +: white
Front right - : white w/ black stripe
Front left +: grey
Front left -: grey w/ black stripe
Rear right +: purple
Rear right -: purple w/ black stripe
Rear left +: green
Rear left -: green w/ black stripe
I think this is what you mean by wiring diagram, Hope it helps
Oct 17, 2008 | Car Audio & Video
Hitachi 60v500 tv has split screen with white vertical stripe down side
Good Day, poandflo;
After removing the power from TV remove the back of the TV (bottom only): Repair: Re-insert PDM connector on both Main Digital module and Drive PWB.
Good Luck, big IRISH. ps. remove cables one at a time and plug back in ensuring that they are seat properly.
Aug 08, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
LG 42LH30 42 in. LCD TV Logo
94 people viewed this question
Computer Repairing
Computer Repairing
