Question about HEWLETT-PACKARD HP G61-429WM Notebook
I have a HP G61-327CL Notebook that will not start-up. I have gone through all of the HP solutions to no avail. At their suggestion I have even replaced the Motherboard. With the battery out and the A
The full model number is G61-327CL Notebook. Product number; VMUA#ABA Serial Number; CNF94729Q2 All othe details are listed in the question above.
  • Robert McCann
    Robert McCann Jan 13, 2015
    After replacing the motherboard what was the results?
    New Friend:
    Problem Solver:
  • 7 Answers
Try this turn on the laptop. even though you don't see the screen lit up it is on. do a simple test .eject the cd tray. now that you know it is on plug the laptop power cord in. turn the laptop vertical with the laptop screen slightly open let it stand up vertical for about 1 hour or more..after time has elapsed unplug the computer and power it off. quickly place the laptop in a upright position close the screen let it sit for one minute power on the device. walla it powers on this not a fix it is conformation that the laptop in question has a AMD chip which confirms the motherboard malfuntioned .buy a new laptop and steer clear of kn-owned defective products .
Posted on Dec 05, 2014
JonwVBFL
  • 56 Answers
SOURCE: My HP Pavillion laptop g61 wont turn on or off.
I had trouble looking up that model on the HP page, but you should check this page and see if this model is affected by this NVidia litigation. If it is, you can get it fixed/replaced on NVidia's dime.
http://www.nvidiasettlement.com/affectedmodels.html
Posted on Oct 15, 2010
  • 6771 Answers
SOURCE: blinking white amber light above power cord
The power supply is the issue, or the DC jack in the laptop has developed bad connections, or ram issue. Remove 1 stick of ram and power on, if no! remove second one, and replace the first, power up, if no! test the power supply for proper voltage, if okay! it is a DC jack or motherboard problem.
Posted on Mar 10, 2012
  • 219 Answers
SOURCE: HP Compaq 615 doesnot start up
Hello Shekhar,
this condition means a general system board failure. I am affraid a repair is called for.
Posted on Jun 16, 2012
  • 11 Answers
SOURCE: hp probook 4530 ac connected indicator flashing. will not power up
Remove the battery, Plug in the AC charger. Push and hold the Power on button for 45secs. If this doens't reset. The fault is most likely the System/Motherboard. If the unit is under warranty, contact HP and arrange a repair.
Posted on Sep 01, 2012
  • 9 Answers
SOURCE: caps lock and number lock light flash but black screen no image
Check the link below:
Troubleshooting LED Blink Codes or Beep Codes During Startup or Boot
Posted on Oct 01, 2012
Scanner error 12 shows
HP LaserJet M1005 MFP - Scanner Errors 6 and 12 Solution ISSUE: The scan head may not be in the correct starting position.
Updated firmware is available to resolve the issue.
SOLUTION: Upgrade to newer firmware (version20120831 or newer) available on hp.com Support & Drivers.
Select Drivers & Software, enter the product name/number, select operating system and locate the firmware download.
Nov 01, 2014 | Office Equipment & Supplies
My Hp Pavilion dv9831cl laptop quit working and won't power on, even with a full charge or plugged in. I press the start button, it lights for about a second then shuts off. Any suggestions? If I
Laptops use shared RAM, part of the main RAM is allocated as video RAM.
If the RAM is faulty then this could be the problem, get the RAM tested at your friendly computer repair shop.
Apr 06, 2012 | HP Pavilion dv9823cl Notebook
HP Elitebook 8460p Mute Light Button Problem
I have this problem. Google again, there is a firmware update available.
Feb 27, 2012 | HEWLETT-PACKARD Hewlett Packard HP...
I need Sound driver HP Pavilion DV5234US 15.4" Entertainment Notebook Laptop PC Notebook for windows 7 ultimate
Sorry to said but there are no drivers for your notebook for Windows 7. I suggest you to download from this link previous drivers and use these drivers at your notebook in compatibility mode. This means that before the drivers installation, right click on the installation file, choose properties - compatibility and check compatibility with the version of the drivers you download. For example if you download the drivers for Vista check the Vista compatibility. Note that the Vista drivers are available for 64bit also.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Nov 03, 2010 | HP Pavilion DV5234US Notebook Laptop
Audio driver.....because our HP Pavilion laptop has no sound
you download the driver from the internet by using google
Nov 02, 2009 | HP Pavilion dv5020us Notebook
HP Pavillion dv5000 laptop will not load windows.
I had this problem, because I have had my HP Pavillion Dv 9000 laptop replaced 3 times. There is a recall on those laptops. The mother board is no good. HP fixes the problem at no cost to you even if it is out of warranty. There is also a freeware and software BIOS update that was just released. And if your screen ever cracks there is a recall on that as well with the left display hindge. My solution: Call HP at 800-474-6836 they are available 24/7 365. Make sure you have your notebook Model number and serial number ready.
Mar 18, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000 laptop
This can be a Hardware issue.
Try the steps below :
1. Disconnect the AC Adapter.
2. Remove the Battery.
Note : Please see that there are no external devices or cables connected to the Notebook.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
If the Notebook starts normally, the issue is resolved...
However, if the issue persists, I recommend you to try removing and resating the Memory(RAM) of the Notebook by following the instructions available in the Manual which can be accessed from the link below :
http://h10032.www1.hp.com/ctg/Manual/c01035677.pdf
Find the required instructions to remove and reseate the memory starting from page number 128 of 278 in the Manual.
If the issue persists, it can be a Hardware issue for sure.
However, HP had identified some hardware issues with some Notebooks.
Get the Product Number of the Notebook which can be located form the bottom of the Notebook indicated with P/N and check if it is listed in the list available in the link below :
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&dlc=en&docname=c01300427#c01300427
You can get the Notebook repaired for free if it is purchased and currently available in US or Canada.
Find more information about this from the link below :
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c01087277&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Hope this helps...
Aug 27, 2008 | HP Pavilion dv6000z Notebook
MY HP PAvilion F1903 19 " gone black blank
Problem is generally dry solder joints around the inverter transformer on the inverter PCB.
Feb 16, 2008 | HP Pavilion F1703 17" LCD Monitor
HEWLETT-PACKARD HP G61-429WM Notebook Logo
100 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
