Question about Ricoh Aficio SP C410DN Laser Printer
How do I fix the error code sc270
I don't know what this error is
    Champion:
  • Ricoh Expert
  • 208 Answers
That is for the laser diode shutter. Either the sensor is bad that detects it opening and closing or the motor that moves is bad.
Posted on Dec 14, 2014
2 Suggested Answers
  • 903 Answers
SOURCE: i have ricoh laser printer
sc270 is an error with the shutter on the laser unit. Turn the machine completely off and then back on -- if the error doesn't clear, the shutter sensor or motor will likely need to be replaced.
Posted on Mar 06, 2011
122 error sc270
Are you sure it's 270 as that error is not in the service manual
Nov 08, 2013 | Kyocera FS-1118MFP Laser Printer
Driver for iphone4 code 28
Important: Device Manager error codes are exclusive to Device Manager. If you see the Code 28 error elsewhere in Windows, chances are it's a system error code which you should not troubleshoot as a Device Manager issue. Cause of the Code 28 Error A Code 28 error is caused by a missing driver for that particular piece of hardware. There are any number of reasons that a driver might not be installed for a device but your troubleshooting of the problem will be the same no matter the root cause.
Error Code 28 Troubleshooting
  1. Restart your computer if you haven't done so already.
    There is always the slim chance that the Code 28 error you're seeing in Device Manager was caused by a fluke with Device Manager or in your BIOS. If that's the case, a reboot might fix the Code 28.
  2. Did you install a device or make a change in Device Manager just before you noticed the Code 28? If so, it's very possible that the change you made caused the Code 28 error.
    Undo the change, restart your PC, and then check again for the Code 28 error.
    Depending on the changes you made, some solutions might include:
  3. Update the drivers for the device. Installing the latest manufacturer supplied drivers for a device with the Code 28 error is the most likely solution to the problem.
    Important: Make sure you install the drivers for the correct operating system. For example, if you're using Windows 7 32-bit, install the drivers designed for that specific version of Windows. Many Code 28 errors are caused by attempting to install the wrong drivers for a device.
  4. Install the latest Windows service pack. Microsoft regularly releases service packs and other patches for their operating systems, one of which may contain a fix for the cause of the Code 28 error.
    Note: I do know that certain service packs for Windows Vista and Windows 2000 have contained specific fixes for some instances of the Code 28 error in Device Manager.
  5. Replace the hardware. As a last resort, you may need to replace the hardware that has the Code 28 error.
    It's also possible that the device is not compatible with this version of Windows. You can check the Windows HCL to be sure.
    Note: If you still think there is still a software/operating system component to this Code 28 error, you could try a repair install of Windows. If that doesn't work, try a clean install of Windows. I don't recommend doing either of those more drastic options before you try replacing the hardware, but you may have to if you're out of other options.
Please let me know if you've fixed a Code 28 error using a method that I don't have above. I'd like to keep this page as updated as possible.
Jan 08, 2012 | Microsoft XP Computers & Internet
The drivers for this device are not installed. (Code 28) There is no driver selected for the device information set or element.
Resolution
    • Remove or reconfigure the newly installed device.
    • Roll back the driver to the version prior to your update.
    • Use System Restore to undo recent Device Manager changes.
Applies To The Code 28 error could apply to any hardware device in Device Manager but most Code 28 errors seem to affect USB devices and sound cards.
Any of Microsoft's operating systems could experience a Code 28 Device Manager error including Windows 7, Windows Vista, Windows XP, and more.
Still Having Code 28 Issues in Device Manager? Let a community of computer support enthusiasts help out! Post the details of your problem in the PC Support Forum. Be sure to let us know that the exact error you're receiving is the Code 28 error in Device Manager. Also, please let us know what steps, if any, you've already taken to try to fix the problem.
----------------------------------------------let me know if this helps--------------------------------------------
Jun 20, 2011 | Computers & Internet
I get a p0402 error code on my 2001 ford ranger , what do i have to do to fix this error
The code most likely means one or more of the following:
-The DPFE (differential pressure) sensor is faulty and needs replaced
-There is a blockage in the EGR (most likely carbon buildup)
-The EGR valve is faulty
-The EGR may not be opening due to a lack of vacuum
Jun 13, 2011 | Ford Ranger Cars & Trucks
I have ricoh laser printer aficio sp c420dn showing error code SC270
Feb 16, 2011 | Ricoh Aficio SP C410DN Laser Printer
Maytag neptune top loader model fav6800aww has an error code od
rlbishop720,
See this post Left Hand Lid Lock Troubleshooting . I discuss Left Hand Lid Lock troubleshooting for error codes OD,OP FL, FO all related to Left Hand Lid Lock issues. I also provide a link to purchase a replacement Left Hand Lid Lock if you don’t want to deal with a DIY fix.
Let me know if I can help…..Rich
Mar 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Error code:81000306 i cannot sign in my msn
To fix this :-
Click start
- Type: cmd (but don’t hit Enter)
- Right-click cmd.exe when it appears under Applications
- Click Run As Administrator
- Type the following: netsh int tcp set global autotuninglevel=disabled
- Press enter
Then just sign into WLM; you don’t even have to reboot.
Thanks.
Jun 04, 2009 | Computers & Internet
Bizhub C350 Malfunction Code C-0510
I have this malfunction code, C-11A3, coming up on my Konica/Minolta Bizhub 350 copier/printer. Anyone know what it is? I don't use the techs, because they charge much I don't pay for the service anymore-seems like most things should be able to be fixed by the owner. I needed help for this code
Mar 21, 2009 | Konica Minolta bizhub C250 All-In-One...
Ricoh 420 SC270 error
i want to solve this problem of sc 122 code in my photocopy want can i do to remove this code. because i can copy the A3 papers even to resize A3 to A4
Jul 17, 2008 | Ricoh Office Equipment & Supplies
Ricoh Aficio  SP C410DN Laser Printer Logo
88 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
