Question about Janome MB4 Four Needle Embroidery Machine
Tengo problemas con maquina de bordar janome mb4, me distorciona el bordado. I have problems with mb4 janome embroidery machine, embroidery distorts.
I saw that no embers stuck embroidery and shopping engines (x, y) work well.
  • 72 Answers
If your embroidery is distorted be sure you are using the right stabilizer for the fabric you are doing the embroidery on and enough for the density of the design.
I hope that helps.
Posted on Dec 05, 2014
  • 8 Answers
SOURCE: Janome Customizer 10000
There are different programs for 350E. I think, you was buy program different.
Posted on Jan 11, 2009
  • 255 Answers
SOURCE: SE ME EXTRAVÍO LA DOCUMENTACION DE LA MAQUINA
Hay sitios on line donde se puede comprar documentacion para maquinas de coser. Trata primero Janome (www.janome.com). Otro sitio que tiene mucha informacion es http://www.sewingmanuals.com/.
Creo que New Home manufactura la maquinas Janome, asi que busca bajo los dos nombres.
Buena suerte!
Posted on Jan 08, 2010
hazelgrace
  • 340 Answers
SOURCE: no puedo enhebrar mi maquina
Muchas maquinas de coser si enhebrar de las misma manera.
Si ves el link, encontraras un manual por el maquina Janome 3128. En el manual hay dibujos de como enhebrar una maquina de coser. Espero que este ti ayuda.
http://www.janome.com/documents/File/ManualFile/3128.pdf
Posted on Sep 13, 2010
  • 233 Answers
SOURCE: Lost power cord for Janome
Try https://www.sewshop.com/#/Cords___Controls-8-4020.html. They have Janome power cords. The one fits the Memory Craft. Most of the manufacturer's use the same power cord for most of their machines.
Posted on May 12, 2011
  • 1564 Answers
SOURCE: janome mb4 restarts in different place after stop to replace broken needle
My machine is a bit different than yours but there is a way to back up your Janome 10 stitches at a time. Here is a thread that I initiated at the janome embroidery forum that should help you. Digimad included a detailed help for me. It should direct you to get you going again. Do join the forum the gals there are generally a great bunch and very helpful.
http://content.janome.com/fusetalk/forum/messageview.cfm?catid=7&threadid=4317
Posted on Aug 25, 2012
My Bernini 830 would not recognize the embroidery attachment. I re-attached many times, but it doesn't work.
I assume you mean a Bernina 830. If you have removed the slide-on table, I have two possible solutions. I've seen this with a couple of Viking embroidery attachment units. (I am also assuming it's not a hoop issue.)
You could have corrosion on the pins that send the signals between the embroidery attachment and the sewing machine. Remove the embroidery attachment and turn off the sewing machine. Unplug the sewing machine. Spray the pins with an electronic contact cleaner; one example is here: http://www.homedepot.com/p/CRC-QD-11-oz-Contact-Cleaner-02130-6/202262505 . Push the embroidery attachment into the sewing machine by lifting up the far side and then sliding it into the port. Remove the embroidery attachment. Repeat this a few times. (The friction of the insertion and removal will remove any dirt or corrosion.) Plug in the sewing machine and turn it on. Try connecting the embroidery attachment. If it works, remember to clean the contacts the next time the embroidery attachment isn't recognized.
Once I helped someone with two sewing/embroidery machines with an unrecognized embroidery attachment. In that case, the person swapped which embroidery unit went with which machine. The contacts were not the same and didn't mate. Once the correct machine and embroidery unit were paired, the embroidery unit was recognized instantly.
I hope this helps. If it doesn't, you may need to talk to your Bernina repair technician at your local shop.
Aug 19, 2017 | Sewing Machines
Elba 8600 st/no how to reset it?
Reload the design you are trying to sew. Needle breaks can trigger circuit protection and affect the design being sewn from being saved in machine's memory properly..
Cheers,
Embroidery Services
San Diego, CA
Jul 03, 2016 | Elna Xplore 8600 Computerized Sewing...
While sawing the embroidery holder moves as well, looks like its not falling into its place correctly after embroidery, how can I fix it? Also I've self checked the machine but cant get the zi
YOUR MACHINE USES A PULSE MOTOR (SMALL MOTOR) THAT CAUSES THE NEEDLE ARM TO MOVE. IF THE MOTOR IS A PROBLEM THEN YOUR ZIGZAG STITCH AMONG OTHER STITCHES WON'T WORK. YOUR HOOP I'M NOT SURE BUT IT SOUNDS LIKE YOUR HOLDER ISN'T LOCKING WHEN YOU PUSH THE HOOPS ON. LOOK INSIDE THE HOLE WHERE YOU PUSH THE HOOP AND TOUCH ON EACH SIDE AND PLACE PRESSURE TO SEE IF THEY BOUNCE BACK. ANYWAY, YOU WILL PROBABLY NEED TO GO TO YOUR LOCAL REPAIR SHOP ON BOTH OF THESE PROBLEMS.
Nov 17, 2014 | Janome Sewing Machines
Janome
Sounds like your embroidery unit may have a bad motor or broken drive belt. Get that unit into a repair shop.
Cheers,
Kelly
San Diego, CA
Jul 30, 2014 | Janome Memorycraft 9700 Computerized...
Embroidery unit on Brother pc8500d will not work
Hi Sharon,
That was my first "Convertible machine" I had the Baby Lock version. Exactly the same in every way, except for the name badge.
Make sure you have the "data door" open (revealed after the tool tray free arm section is removed.) and the "Feed Dog" Switch is "down for embroidery". If any of the connection tabs/pins on the "embroidery attachment" are missing or bent/broken off. the embroidery arm will not work properly.
With this old of a machine, look on EBay for external parts and things you need instead of seeking repair. Timing adjustments, and other machine maintenance can be done by most repair shops with a technician that repairs convertible embroidery/sew machines.
Put your machine name and model number in a search on youtube.com you will find a wealth of information there for your machine.
Cheers,
Kelly
San Diego, CA
Embroidery Services
May 18, 2014 | Brother PC8500D
Husqvarna topaz 20 touch screen beeps after I load embroidery file and then will not respond to touch
These are very complicated machines. Look for a shop that will help you know it need repair. If you are not following the correct steps to get the machine to sew, it may not need a repair, but operational errors are being made? I work with a shop that will diagnose for no charge. look for a better repair shop.
Cheers,
Embroidery Services
San Diego, CA
Sep 14, 2017 | Husqvarna Sewing Machines
Brother PE770 Hoop size programming stuck on small hoop option
Your machine would be able to perform 5 X 8 embroideries. The hoop size on this machine is recognized by the machine itself, depending of the embroidery file size. So it the embroidery is small, it will indicate that the small hoop is needed.
But U can use the large hoop, position the embroidery where U want then perform another embroidery on the sams hoop.
TRICK : the embroidery size exceeds the hoop? reduce it in X and or Y using this function on the machine
Jun 10, 2012 | Brother PE770 Computerized Sewing Machine
Babylock Ellure Embroidery Unit Malfunction
You need to make sure that the embroidery arm is able to move freely be sure that it has no obstructions like a wall behind your sewing table or fabric that may be stacked nearby. If all is clear you probably have thread wrapped somewhere inside the embroidery unit it only take a little bit to jam up the works. You can try to take off the cover by flipping the unit over and removing the screws to the embroidery arm. I would take it to the shop where you bought it they should be able to help you for free if it is new. If you have the original packaging you can send the machine to Steve's at www.stevessewandvac.com just send them an email they can help.
Jul 27, 2008 | Baby Lock Ellure
Machine embroidery
You should always use proper Bobbin Thread for embroidery - not a bobbin wound from regular dressmaking thread. You are right, the special bobbin thread is thinner so that the embroidery thread will be pulled to the underside and you get a nice shiny embroidery on top with no bobbin showing through. Wind yourself 6 or more bobbins at a time of bobbin thread to always have some on hand, or buy the pre-wound L size ones.
All embroidery machines - no matter what brand - recommend using bobbin thread for embroidery. It is readily available at all sewing stores, probably even Spotlight would carry some. If you get stuck for a supply, try overlocker thread.
Dec 04, 2007 | Husqvarna Designer I
Janome MB4 Four Needle Embroidery Machine Logo
142 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
