Question about John Deere Garden
Have any farmer experience fire issues with the John Deere 6115d?
This tractor caught on fire and was destroyed
SOURCE: gas tamk removal john deere 115
I had the same thing happen. I got the tank out, but it wasn't easy. Take out the bolts out that hold the rear end on. Take off the two springs that support the seat. Take out the battery and the battery tray. Take out the 6 bolts that hold the black cowling and the front of the green platform to the frame. This will allow you to lift the seat platform far enough off the rear end to allow the tank to be pulled out through the side. You also have to remove the metal bracket which holds the front of the tank and has caused the tank to leak in the first place. New tank is $56.00 not installed. I used a soldering gun and melted the plastic back together. I think it will hold quit a while. I know this is a little sketchy, but It worked for me.
Posted on Jun 02, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
mowerman1857
  • 389 Answers
SOURCE: John Deere LA175 lawn tractor front wheel bushings
Remove the tire and wheel from the spindle. Take a long punch or similar item and reach in the center of the wheel hub where the spindle goes. Locate the space in between the inner and outer bushing and tap the edge of the old bushing until it comes out. Now go in from the other side and do the same with the other bushing. This one will be a little easier to do since you don't have to hunt for the center space. Put the new bushings back in the same way just be sure you drive them in STRAIGHT
Posted on Sep 18, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a John deere 317 tractor that does not start.
We will be testing for voltage to the points, coil, engine to tractor wiring harness, ignition switch
Tools needed:
volt meter to read 12 volts, or test light
1) with the points open: is there voltage at the connection wire at the points
If yes; adjust points to .020" and try to crank engine and check for spark
*** you may want to determine if condensor is connected to this wire also
if no
2) check point side (neg or - ) of coil for voltage
if yes, engine should start
if no
3) check for voltage at the + side of coil
If yes, coil is bad
if no
4) check wire connector from engine to frame wiring harness
if yes; engine should start
if no
5) check wiring on the back of ignition switch
if no
6) check that ignition switch RED or BATTERY supply wire has voltage
if yes; switch is bad
if no
7) check supply wire and circuit breaker connected to the battery side of the solenoid
if no; circuit breaker could be at fault or wire connector at battery supply
Posted on Nov 08, 2009
John Deere LT 155, why is small amounts of oil dripping into the carburator air intake thru the oil breather hose connected to the intake
could be a valve issue or timing issue. flywheel key may be sheered a little bit causing incorrect firing.
Dec 18, 2016 | John Deere Garden
I used my John Deere L110 Lawn Tractor all day yesterday. Turned the engine off, it popped. Then went to start it today and it just pops, seems like the timing is off.
throttle down your engine before turning it off . this reduces amount of fuel going into a hot engine ,just a few seconds before switching key off , should stop back firing issues.
Sep 09, 2013 | John Deere L100 Series
Can i put a 12 volt lawn tractor battery in the tractor
Wiring could be an issue when upgrading batteries. Also, if you manage to properly connect a larger voltage battery, you may (probably will) overheat and destroy the motors.
Sep 24, 2012 | Peg Perego John Deere Turf Tractor
John Deere American Farmer How downlonad
Hi
you can check it here
http://www.filestube.com/
or on torrents
Nov 26, 2010 | Global Star Software John Deere American...
Charging john deere toy tractor
you just remove the two screws on the side of the hood then lift the hood up
Jul 23, 2010 | Peg Perego John Deere Turf Tractor
I paid for john deere american farmer and it says o.s. on supported
Right click on the program, then click properties and compatibility. Choose Windows XP.
If you still get the error, try a different option instead of XP.
Mar 09, 2010 | Destineer John Deere: North American...
Water in gas tank
It's condensation if you haven't got a leek if you leave the tank full of fuel this should not happen we had this problem for years with combine harvesters and leaving them full and not empty cured the problem
Dec 25, 2008 | Destineer John Deere American Builder w/...
Garden Logo
26 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
