Question about HP ENVY 700-047c Desktop Computer Intel Core i5-3470, 12GB Memory 2TB Hard Drive
Says 16g (but only 11.5g available
It came with 12g of ram (11.5g available) I installed 16g of ram, it says 16g but only (11.5g available). It says the same whether I have 12g or 16g in it. I tried blowing out the socket and re-setting the ram but no change. Help!
  • HP Master
  • 3,287 Answers
Hi Steve,
Here are the specs for this machine:
http://h20564.www2.hp.com/hpsc/doc/public/display?docId=c03789872
You should be able to install & use 16GB (max) in that machine provided you have the memory type required and you have a 64 bit OS installed on it. HP also notes that the OS may further reduce the amount of memory on the machine. I would start by disabling the quick boot feature in most BIOS screens so that the memory can be checked and :"counted". If it goes up to 16GB, the memory is good and the OS is limiting to ~12GB. If not - there a bad chip / stick somewhere.
You should begin swapping memory sticks one at a time to determine which stick is problematic and return it for replacement.
Posted on Dec 05, 2014
How do I clear my internal phone storage?
The external memory is the 16g card you have installed.The internal memory is the storage it has the phone itself.Most of it,it has been reduced from the OS (Android). Another issue may be that whatever you download can be saved only in your internal storage ( i am not sure) check it out!
Aug 28, 2013 | Samsung Galaxy S 4G Cell Phone
Diode broke off board while installing ram. will not boot..size of know the diode is (-) that dash is the size
well (-) is not the size it notifies the negative end of diode and the model number of diode will be very tiny on it, if that is known u can replace it.
Jan 05, 2010 | ASUS Eee PC 900 16G Notebook
I have an asus dsbf-d server motherboard installed with two Intel Xeon E5410 Harpertown 2.33GHz processors and 16G ram. I have four 1 TB WD hard drives I want to set in raid 10. I want to install xp 64 bit...
http://support.asus.com/download/download.aspx?modelname=DSBF-D&SLanguage=en-us
Select Windows XP 64 from drop down box. Check for files under SATA (click the plus sign). Have you already tried the LSI MegaRAID?
Nov 25, 2009 | ASUS DSBF-D/SAS Motherboard
I asked around and installed an electric fan with wiring because my old factory fan broke. The fan had one blue and one black 16G braided wire coming directly from the fan. I attached the black (ground) to...
A 96 GC should have a regular belt driven fan. 16 ga wires are not big enough to power any type of fan motor, Are you sure they are not 14ga?. If the factory fan broke, just replace it. Try hooking the wires directly to the battery, make sure it spins the right direction, if not, reverse the wires but make sure the fan is on the right way, you may need to flip it over. The fan should be hooked to a thermostat, you dont need the fan spinning 100% of the time.
Nov 09, 2009 | 1996 Jeep Grand Cherokee
Aftermarket electric fan wiring and switch not working
MOST ELECTRIC COOLING FANS THAT ARE AFTER MARKET USES A THERMOSTAT.THAT WHAT TURN ON FAN WHEN IT GETS A CERTAIN TEMPERATURE.YOU GO BACK PARTS PLACE.THEY WILL GET THERMOSTAT FOR FAN.IT
RAM utilisation
Can't do it with 32 bit, must install xp64 or vista 64.
Oct 30, 2008 | Computers & Internet
16g RAM on 32 bit mobo?
Well...i never heared of a 16gbram mobo and also no OS is able to support it propery and also u don't need so much memory but whatever.You could use smaller modules like 1gb or 2gb but you must know wht type of memory it uses and also what's the minimum amount of ram that can be used.
Oct 30, 2008 | ASUS P5S800-VM Motherboard
HP ENVY 700-047c Desktop Computer Intel Core i5-3470, 12GB Memory 2TB Hard Drive Logo
50 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
