Question about Building Materials
Gear @ sprocket number 41a4220a information on replacing it
Nothing yet waiting on part to show up just trying to see what I have to do
Qc 10 00a
First gear on both sides would result in the easiest gear possible.
Lets think of it like this....
Left hand in the "1" gear, you now have gears 1-7 to use on the right hand side. The right hand controls the rear gears and brake.
Once you reach gear number 7 and want to find #8, move the left hand to gear number 2. Now set the right hand back to #1. This is your 8th gear.
You essentially have 3 sets of 7 gears, with each set being harder then the previous.
Clear?
Apr 26, 2014 | Shimano Cycling
I need a sprocket assembly for my EL* 107624-02
Afternoon Happy;
The obsolete chainsaw Gods smiled on you today, but there is a catch 22. You must purchase a repair kit to get the parts you need.
Master Distributors
http://www.masterparts.net/remingtonelectricchainsaw.html
Part number 122511-01; SPECIALTY PARTS: SPROCKET GEAR (107713-01 SPROCKET GEAR, 075676 BEARING, 059606 DRIVE GEAR) (DSSP-SH); $16.99.
Are you aware RemingtonPower has ceased production? Soon eBay will be the only source for replacement parts.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 06, 2010 | Remington 16" Electric Chain Saw
The speed shown on the speedometer is not accurate on my Yamaha XT125R - -When travelling at 30MPH -The speedo shows 38MPH -When travelling at 40MPH -The speedo shows 52MPH -When travelling at 50MPH - The...
If the speedo gear is in the front wheel a different wheel would have different gear and mess up the speedo but I'm thinking the gear wouldn't mesh with the old speedo cable teeth.Check a shop manual for stock number of teeth on rear sprocket and tranny sprocket,that will tell the story.While your at it check the stock wheel size compared with what you got.Of course it could be bad speedo.There's springs in there that run needle, so?Maybe borrow one and try it out.Good luck.
Mar 25, 2010 | 2006 Yamaha XT 125 R
The sprocket snaped as garagedoor was comming down how to repair it
The sprocket and gear assembly is available at any good door service company. The part number is 41C4220A and comes with instructions.
Mar 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Cam sprocket timing for 86 Toyota 2SE engine
cam sprocket gear for nissan v6, I need left and right both, so this parts is for obtain more power of torque, were I found this parts?
I looking for that could move some degres when I decide.
thanks for u time, raymond m.
market_bros@prodigy.net.mx
Feb 21, 2010 | 1987 Toyota Camry
Craftsman Garage Door Opener Model# 13953919 not working.
Yes replace the entire assembly. The part number is 41C4220A Sprocket and Gear Assembly and is available at Sears or any good door opener service company. It comes with instructions.
Jun 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Losing power in last gear
If all other gears are doing okay then I would check with your local dealers parts department and ask the number of teeth on the counter sprocket and on the rear sprocket on a stock dtr 250. The prior owner may have mounted a larger counter sprocket and / or a smaller rear sprocket on the bike. The drive ratio may be out of range such that the engine is trying to make for a really high top speed but just doesn't have the strength to do it.
Please rate this solution. Thanks.
Mar 18, 2009 | 2005 Yamaha DT 125 X
Replaced sprocket and worm gear on chamberlain 1/2 opener
The easiest way to fix this would be to take the chain off the sproket with the door and the trolley in the down position. Next hit the wall button and pay attn. to weather the gear is turning clockwise, you want it to turn that direction, wait until the unit stops by itself, next put the chain back on and now you should be able to adjust the limits. otherwise you should call a local professional. They will usually service your door as well as fix your opener.
Feb 15, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Building Materials Logo
44 people viewed this question
Top Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
