Question about Stride Rite Clothing Accessories
Need front brake cable for strider mobility scooter
Batteries for strider full, but wont move brake appears to be on.
Hi how did u test the batteries.the only accurate way to test them is to use a BATTERY load tester ...u can buy them on E/BAY.APROX COST $35::.cheers
Jul 05, 2016 | Electric Strider Midi 4 Wheel Mobility...
I disabled the brake on the scooter. When I enabled the brake and turned on the power, the green light flashes and cannot move forward or reverse. There is plenty of power showing on the gauge.
I need to know how many flashes you are getting of the green light. i.e. 4 flashes pause 4 flashes
Also check the freewhell lever again to make sure it is in the drive position Hope this helps
May 05, 2011 | Electric Strider Mini 4 Wheel Mobility...
Is there a website to download fault codes on a days strider mobility scooter ?
www.ctmhomecare.com/PDF/.../Troubleshooting-Scooter.pdf This link will give you the fault codes for aCTM scooter but all are standard codes and should apply to your scooter also. Hope this helps
Mar 01, 2011 | Electric Strider Midi 4 Wheel Mobility...
I am looking for a manual for strider 4 mobility scooter
There is a great website for all your service needs for this scooter from Medline Industries:
http://www.striderscooterservice.com/
There is a specific service manual for the strider:
http://www.striderscooterservice.com/strider-scooter/files/TechManual.pdf
These two sources should provide all the info you need. Hope this helps.
Nov 23, 2010 | Health & Beauty
Strider cart wont go battery full has something to do with handbrake
mcdevito75, You can try to apply and release the hand brake, In any case have the hand brake checked out as the cable could be stretched.
Jun 21, 2010 | Electric Strider Maxi 4 Wheel Mobility...
Maxi strider scooter
Hi
Are you sure it 's the cable ? and not the wig wam or throttle speed pot that you operate with your thrumbs.
Regards
GeWiz.
May 03, 2009 | Electric Strider Maxi 4 Wheel Mobility...
My wifes strider chair runs a bit the stops. Then she turns off the key, turns it back on and it runs a little bit a stops. The green light stays steady until it stops then blinks..any help?
Ztarg is the Medline Industries approved service and parts distributor for the Strider and Gemini Scooters.
Their contact information can be found on their website www.striderscooterservice.com
Dec 15, 2008 | Electric Strider Midi 4 Wheel Mobility...
Clothing Accessories Logo
Top Stride Rite Clothing Accessories Experts
Da Doc
Tom Chichester
ray gallant
Are you a Stride Rite Clothing Accessory Expert? Answer questions, earn points and help others
