Question about Sony Televison & Video
My Sony kds60a2020 Is starting to take longer for picture to come on when you first turn it on
  • Sony Master
  • 10,291 Answers
Capacitors on the power board are aging and going bad. You can tell the bad ones if you see the top of the metal case is bulged instead of flat. Repair kits can be had at shopjimmy's web site.
Posted on Dec 05, 2014
How do I fix?
Probably the replacement lamp is not correctly aligned. HOWEVER, if the band is not on the bottom, but is surrounded (above and below) with good picture, the cause is in the RED color circuitry usually the 'convergence' section. This type of failure is often due to a failing electrolytic capacitor. Repair is problematic and may be in the integrated circuitry.
Jul 23, 2014 | Sylvania Osram Replacement Lamp & Housing...
How to take the tv back to original factory settings
Unplug,replug the tv back about an hours later.All the tv settings,will return back to the tv original factory settings.
Jun 10, 2011 | Sony KDS-55A2020 55" Television
Sony TV kds60a2020 replaced lamp and power lights blinks three times. Checked to make sure lamp was secure. Would light still blink if defective bulb?
have you tried making sure the lamp door is closed ... generally 3 blinks means the lamp door is not closed the door pushes a switch closed
Jun 03, 2011 | Sony KDS-60A2020 60" HDTV
Where is the thermal sensor located in a sony kds60a2020
Usually the thermal fuse is next to the bulb light, looks like an antena with 2 flexible wires and a brown or black plastic at the tip. Folow the wires from from backward. It is very cheap. about $5.00
Apr 12, 2011 | Sony KDS-60A2020 60" HDTV
My sony kds-50a2000 picture is green why? I replaced projection lamp the picture was great but now the picture is terrible everthing seems to have a yellow tinge to it and green seems to be dominant...
The problem is the optical block and nothing else but. Contact the dealer from which you purchased the set to see if you qualify for Sony's extended warranty on this very, very expensive part, which may be covered by a class action lawsuit Check here http://esupport.sony.com/US/perl/news-item.pl?news_id=367&mdl=KDS60A2020 The lawsuit covers all the KDS models. It seems that Sony continued making these rear projections even though it knew the optical block failed prematurely. When you get it fixed, go to setup and make sure the cooling fan is on HIGH and power saving is ON. Both of those features will extend your TV's life, including the optical block and the projection lamp. Further, bring a portable compressed air tank to the TV and, with a narrow nozzle, empty it into every opening in the set's back. At least once per month, check for dust settling on the rear of the stand behind the TV -- when it gets thick, get the air tank.
May 10, 2010 | Sony KDS-50A2000 50" HDTV
Sony kds-60a2020 green picture tint. Can't adjust it out. Everyone looks like their skin is green etc.
Sounds like a light engine problem.Theres 3 lcd color chips in there that create the color.One of these has gone bad.You might find a light engine at discount-merchant.com
May 08, 2010 | Sony KDS-60A2020 60" HDTV
What does techman007 mean by "Replace your lamp with phillips brand lamp. Do not use generic lamps for sony televisions." Is the XL5200 lamp for the KDS60A2020 generic? Thank you.
The XL5200 is the original lamp for your TV.
Check the info from this link as well for instructions on how to replace it. Go to page # 51.
Feb 20, 2010 | Sony KDS-60A2020 60" HDTV
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
