My 5 yr old samsung lcd tv won't turn on. We replaced the fuse but that wasn't it
    Top Expert:
  • Televison & ... Master
  • 33,294 Answers
Could be power supply failure
Posted on Dec 05, 2014
  • Dana Krupnick
    Dana Krupnick Dec 05, 2014
    How could I check?
  • 7 Answers
SOURCE: My samsung tv turns on and off repeatedly at
Mine was doing that then it quit even turning on so I replaced the 4 Capacitors today on the power supply board that had bulged up on the top 3 had split open they where on the top right corner of the board where the ribbon jumps from the power board to the main board with ones from Jameco Part Number 606521 they worked perfect but make sure you put them in with the correct polarity easy to do just keep an eye on it. Very simple repair and took me about 30 min to take itapart solder on the new ones and put it back together all for under $10.
Posted on Jul 09, 2009
JULIANFIX
  • 975 Answers
SOURCE: my tv won`t go on, maybe a fuse blew [if it has
YOU MIGHT BE ABLE TO FIX IT YOURSELF if your handy with tools , if not then to a tv repair shop , hope it helps ,AJ
Posted on Nov 19, 2009
SOURCE: power supply problem
mine did this and it was the power supply like 140 bucks from the best buy parts search
Posted on Nov 26, 2009
SOURCE: 3 year old Samsung 40 inch LCD TV will not turn on
The problem is 4 capacitors on the power supply board. Just had mine done under warranty. They (Sears) replaced the whole power board but you can get larger capacitors and just replace those for alot cheaper if not under warranty.
Posted on Jan 30, 2010
kidsasuke
  • 121 Answers
SOURCE: Have a 2 yr old 46" Sony LCD. No picture at start up.
It may just need time to warm up. Try starting it up and waiting around for the picture to show.
Posted on Jun 04, 2010
I've replaced every board on the samsung plasma and still clicks
What do you mean by clicks? Plasma televisions are hot cathode ray, there is thermal expansion that takes place due to heat.
Nov 04, 2016 | Samsung Televison & Video
My 5 yr old samsung LCD doesnt not turn on anymore. We replaced the fuse still didnt work
Check the wall poser socket first. If you've replaced the fuse, and it doesn't work. is the symptom that it does not get any power; otherwise you might heard any sound of burning the fuse, when you did switched ON the set. It will be best to contact any service technician in this case. http://electronicshelponline.blogspot.com/
Dec 05, 2014 | Televison & Video
The POP of death on my Vizio tv...now does not turn on
You will have to take it to a TV repair center. it definately sounds like a short or the board has blown.
Apr 29, 2012 | Vizio L32 32 in. LCD HDTV
I got samsung tv ln32a330j1d it won"t turn on even
You have a bad power supply.
You can get get parts for this tv at www.interliquidparts.com
Aug 28, 2011 | Samsung LN32A330 32 in. LCD TV
Daughter unplugged tv without turning it off first. Now, it won't turn back on from the remote or the monitor panel on the front of the tv. It's a Samsung 1080 LCD. Only 6 months old. I've...
hi if you have at least a basic knowledge in repairing in any electronics as my recommendations, since the problem is won't power on.first you need to open the back cover with the use of philip screw driver then start to check the power supply look for the blown fuse replaced with the same amper rated at the part. then check for any burnt or bulged capacitors. also considered the inverter ballast board if their is no burnt connectors or parts. good luck hope it will help you.
Jul 14, 2011 | Televison & Video
Tv was turning on and off feb 2011 made it 1 yr old now will not power on at all
Hi
You need to check/replace the Circuit Board or The Power Supply Capacitors are bad.Its a common issue for LCD TV.
Thanks for using Fixya.
Mar 16, 2011 | Philips 42PFL3704D LCD TV
Jun 24, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
"clouds" on 32" Samsung tv screen
My best suggestion is to replace the inverter to the lcd panel.I could look up the part number if you need.Let me know - edcarson
Feb 18, 2008 | Samsung TXM3281HF 32" TV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
