Question about Gizmo Cycling
Use the gizmo to create the box and whisker plot shown below.Then ,create a data set that matches the plot.The data set should have 10 values.Use the gizmo to check your work
Gizmos on explore learning.com
Benimur
  • 6966 Answers
SOURCE: I have a flat battery on a 2007 Honda Accord
Hi and welcome to FixYa,
To my knowledge, three things would be affected:
  • the engine management computer would reset;
  • the alarm/security/immobilizer may or may not act up;
  • the car radio would require a security code entry upon reactivation.
Good luck and Thank you for using FixYa.
Posted on Dec 06, 2008
SOURCE: want to run Gizmos and Gadgets on Vista PC
I got Gizmos and Gadgets to work on my Vista PC by copying the entire CD to C:/Windows/System32.
After that, open the "ssgwincd" folder, and inside that folder open "ssgwincd" again. Inside the second folder there will be a file called "ssgwincd.exe" right click on it and select properties. In the properties window click on the compatability tab and set the program to run in compatability mode for windows 95 and to run in 256 colors and in the 640x480 window
It should then work for you, but I would suggest putting a shortcut to the program on your desktop so you can find it easier later on.
Good Luck!
Posted on Feb 28, 2009
jimboz4
  • 305 Answers
SOURCE: Owner's manual for Peugot 407
hi, have a look here, this site should have what your looking for.....
http://www.books4cars.com/
Posted on Sep 08, 2009
  • 53 Answers
SOURCE: The Problems with The Learning Company Super
this game will not run on vista or win7 without an emulator beacause it is 16 bit software. I recommend trying dosbox.
Posted on Oct 29, 2009
How to do plot and whiskers in a casio fx-115ES calculator
This is not a graphing calculator, so you cannot perform a box and whiskers plot.
If you know how to find the Median(=Q2), the lower (Q1), and upper (Q3) quartiles, you can draw your box and whiskers plot on a piece of paper.
Jul 21, 2014 | Casio FX-115ES Scientific Calculator
Tip
Adjust the level 2 cache setting
  1. Here'show:
    1. Launch the Registry Editor (Regedit.exe).
    2. Go to HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlSession ManagerMemory Management.
    3. Double-click SecondLevelDataCache DWORD value.
    4. Using the options below, change the value in the Value Data text box to a number that matches the size of your Level 2 cache. Then click OK. Level 2 cache Value Data setting
      256 KB 0
      512 KB 200
      1024 KB 400
    5. Click OK and close the Registry Editor.
    You may need to restart the system or log out of Windows XP for the change to take effect.
on Dec 16, 2009 | Computers & Internet
How do you make a residual plot? And I don't mean finding the residual line and plotting it in a regular scatter plot. I'm talking about a residual plot with a horizontal regression line at zero and the...
The simplest way would be to create a table where each x-value has a y-value that is the residual at the corresponding x. With a 2-list data set you can plot you residual plot.
Sep 22, 2013 | Texas Instruments TI-86 Calculator
Construct both an ungrouped and a grouped frequency distribution for the data given below: 139 130 128 134 140 139 136 130 136 128 138 137 134 128 127 136 140 132 141
Sorry to disappoint you but I will just give you directions to do it yourself.
Ungrouped
First sort the data in ascending order (from lowest to highest value)
Create a two-column table
In the first column enter a data value.
In the second column enter the frequency of a data item
Count how many times one particular data value appears in the set (how many repetitions). If it appears only once, its frequency is 1; twice, frequency 2, etc.
For each single (different) data value complete the frequency column.
Grouped
For grouped data representations you create classes: A class is just an interval of values, for example between [125, 130[
For each class interval you create, count how many data values fall within the interval. For the class given as example it will encompass all values between 125 and 129, It I counted correctly its frequency is 4.
Complete the frequency table for the class.
How many classes should you create? Usually this information is given to you. If not, create a moderate number of classes (4,5) It depends on the span of the distribution (highest value- lowest value). The intervals should have equal length. Read your instructions.
Sep 02, 2012 | Office Equipment & Supplies
I am trying to do a box plot with a TI-84 Plus Silver Edition. I've entered my data values into L1, turned on Plot 1, chosen the box plot, and made sure X1 was set to L1. I keep getting ERR: INVALID DIM....
Hey. I had the exact same problem as you and all I could do was reset the settings to the default settings on the calculator. All you have to do is turn the calculator on, his 2nd (it should say mem right above it). Then click reset then RAM.
Sep 24, 2010 | Texas Instruments TI-84 Plus Silver...
How do I clear things left in the stat plot window?
To clean the slate so to speak, just reset the RAM.
  1. Press [2nd][+] to access the (MEM)ory management function
  2. Press [7:Reset]
  3. Press [1:All Ram]
  4. Press [2:Reset]
  5. Press [CLEAR] to erase the "RAM cleared" Message
Calc
Aug 02, 2010 | Texas Instruments TI-83 Plus Calculator
Window set up for box plot
Use the Zoom button and select 9:ZoomStat. Window will be restricted to your data.
Suggestion: You can use two lists. L1 for the values, and L2 for the frequency. I see many duplicate values: 6 values 23. On the same line as 23 in L1, put 6 in L2
Before entering the frequencies in L2, you may want to sort the L1 list. It would look more orderly.
Other advice (forgive me if you already know). To obtain the median, Q1, Q3 use the [TRACE] button, then use left/right arrow. Screen will display the values for Med, Q1, Q2, Minx, MaxX.
Hope it helps.
Nov 11, 2009 | Office Equipment & Supplies
Question no. 2 For the 50 observation given below. Prepare Frequency Distribution for the the class interval is 10 (lower limit starting is 0) and upper limit is 80. Also plot in graphing. 64 62 52 50 70...
64 62 52 50 70 60 55 20 25 48 35 55 55 47 64 42 36 50 30 53 51 63 58 50 60 54 33 48 40 76 61 46 65 65 15 45 58 40 64 18 33 40 64 18 33 40 48 9 38 41
Highest value observed: 76
Lowest Value: 9
Standard deviation from the ungrouped data: 15.25
Frequency:
Mean: 46.94
Standard deviation from grouped data: 15.40
Oct 23, 2009 | Microsoft Excel for PC
Trying to install office 2007 but keep getting error code 1606 cannot find network location %APPDATA%. What can I do to fix this?
To resolve this issue, follow these steps:
  1. Click Start, click Run, type Regedit.exe, and then click OK.
  2. Locate and then click the following registry subkey: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
  3. In the right pane, verify that the values are the same as the values in the following table. If each value matches the table, go to step 7. For Windows XP and for Windows Server 2003, see the following table. Collapse this tableExpand this table Value name Type Value data AppData REG_EXPAND_SZ %USERPROFILE%\Application Data Cache REG_EXPAND_SZ %USERPROFILE%\Local Settings\Temporary Internet Files Cookies REG_EXPAND_SZ %USERPROFILE%\Cookies Desktop REG_EXPAND_SZ %USERPROFILE%\Desktop Favorites REG_EXPAND_SZ %USERPROFILE%\Favorites History REG_EXPAND_SZ %USERPROFILE%\Local Settings\History LocalAppData REG_EXPAND_SZ %USERPROFILE%\Local Settings\Application Data Local Settings REG_EXPAND_SZ %USERPROFILE%\Local Settings My Pictures REG_EXPAND_SZ %USERPROFILE%\My Documents\My Pictures NetHood REG_EXPAND_SZ %USERPROFILE%\NetHood Personal REG_EXPAND_SZ %USERPROFILE%\My Documents PrintHood REG_EXPAND_SZ %USERPROFILE%\PrintHood Programs REG_EXPAND_SZ %USERPROFILE%\Start Menu\Programs Recent REG_EXPAND_SZ %USERPROFILE%\Recent SendTo REG_EXPAND_SZ %USERPROFILE%\SendTo Start Menu REG_EXPAND_SZ %USERPROFILE%\Start Menu Startup REG_EXPAND_SZ %USERPROFILE%\Start Menu\programs\Startup Templates REG_EXPAND_SZ %USERPROFILE%\TemplatesFor Windows Vista, see the following table. Collapse this tableExpand this table Value name Type Value data {374DE290-123F-4565-9164-39C4925E467B} REG_EXPAND_SZ %USERPROFILE%\Downloads AppData REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming Cache REG_EXPAND_SZ %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files Cookies REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies Desktop REG_EXPAND_SZ %USERPROFILE%\Desktop Favorites REG_EXPAND_SZ %USERPROFILE%\Favorites History REG_EXPAND_SZ %USERPROFILE%\AppData\Local\Microsoft\Windows\History LocalAppData REG_EXPAND_SZ %USERPROFILE%\AppData\Local My Pictures REG_EXPAND_SZ %USERPROFILE%\Pictures My Music REG_EXPAND_SZ %USERPROFILE%\Music My Video REG_EXPAND_SZ %USERPROFILE%\Videos NetHood REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts Personal REG_EXPAND_SZ %USERPROFILE%\PrintHood PrintHood REG_EXPAND_SZ %USERPROFILE%\Documents Programs REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs Recent REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent SendTo REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo Start Menu REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
    Startup REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup Templates REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
  4. If any Name, Type, or Value does not match the table in step 3, right-click the Value name, and then click Delete.
  5. In the left pane, right-click User Shell Folders, point to New, click Expandable String Value, type the Name value that you want from the table in step 3, and then press ENTER.
  6. Right-click the value that you created in step 5, click Modify, type the value in the Value data box for the Value name, and then click OK.
  7. Locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
  8. In the right pane, verify that the values are the same as the values in the following table. If each value matches the table, go to step 12. Collapse this tableExpand this table Value name Type Value data Common AppData REG_EXPAND_SZ %ALLUSERSPROFILE%\Application Data Common Desktop REG_EXPAND_SZ %ALLUSERSPROFILE%\Desktop Common Documents REG_EXPAND_SZ %ALLUSERSPROFILE%\Documents Common Favorites REG_EXPAND_SZ %ALLUSERSPROFILE%\Favorites Common Programs REG_EXPAND_SZ %ALLUSERSPROFILE%\Start Menu\Programs Common Start Menu REG_EXPAND_SZ %ALLUSERSPROFILE%\Start menu Common Startup REG_EXPAND_SZ %ALLUSERSPROFILE%\Start Menu\Programs\Startup Common templates REG_EXPAND_SZ %ALLUSERSPROFILE%\Templates
  9. If any Name, Type, or Value does not match the table in step 8, right-click the Value name, and then click Delete.
  10. In the left pane, right-click User Shell Folders, point to New, click Expandable String Value, type the Name value that you want from the table in step 8, and then press ENTER.
  11. Right-click the value that you created in step 10, click Modify, type the value in the Value data box for the Value name, and then click OK.
  12. Exit Registry Editor, and then restart the computer.
Sep 04, 2009 | Microsoft Windows Vista Home Premium with...
Ti-89 help
You create a program by using the program editor. Press the "APPS" key and select "Program Editor".
What type of data graph do you want? The TI-89 can plot Scatter, XYline, Box, and Histgram graphs. Use the "Plot Setup" screen to select the desired plot type.
Apr 17, 2008 | Texas Instruments TI-89 Calculator
Cycling Logo
126 people viewed this question
Top Gizmo Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Gizmo Cycling Expert? Answer questions, earn points and help others
