Question about Memorex MLT3221 32-Inch Widescreen LCD HDTV
Channel 12 (FOX) a local tv channel often loses its sound. I have to switch to another channel and then go back to 12 and the sound is back.
I have been thinking it is a problem with the tv station, but that doesn't make sense, since there is never any indication from the tv station that it is happening for all viewers.
    Top Expert:
  • Memorex Master
  • 74,136 Answers
Related to incoming signal strength. Nothing else. Electro help
Posted on Dec 05, 2014
The tv is showing a double image and I cannot get the color right! Model number 50v500
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You need to upgrade to the high definition cable box---but first try this. Hook the cable from the wall directly to the tv and autoprogram it. If Comcast is anything like charter they transmit the local Hd channels in a format that digital tuner will pick them up. Just channel up/down and check out the channels with -1 and -2's behind them. Depending on where you are----your local channels will usually show up wherever they normally do but with a -1 behind it.
EX: local Fox channel on 47---autoprogram and check 47-1
If this is enough HD for you then get a two way spitter and hook your box back up and keep using the RCA (composite) cables for the best it can produce.
hope this will help..
May 21, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Will not pick up FOX channel!
if you did get the channel you should be able to add in a digital amp (25db gain) and pull that channel back in
Jul 10, 2009 | Olevia LT32HVM 32 in. LCD Television
Same thing... suddenly will not "allow" one channel to be seen
go to tv menu, do an "autoprogram" and it will select all available channels.
You can also do an add/remove channel and manually delete the channels you know you don't have.
You can also change your tv from air to CATV (cable) On cable tv you can still get all the air channels and Fox just the numbers will be different, but you may have a better signal
Jul 10, 2009 | Olevia LT42HVi 42 in. LCD Television
Will NOT acknowledge one channel
This problem was already posted by someone else and they were having the same issue as you.. they said that they contacted FOX engineers via email and they emailed them back stating there was a problem on there end and with in the next day the channel started to show up on the Olevia television.
Seems like FOX has changed there frequencies and some television were having trouble picking them up.. depending in the area..you might want to try contacting them in regards to your problem to see what they suggest..
Jul 10, 2009 | Olevia LT27HVX 27 in. LCD Television
Local Comcast provider is switching to more digital programming
you will need the adapter and the good news is, the box is free, the downside to this is the panasonic recorder is going to need to only record on channel 3 or 4(there is a switch on the back of the comcast box) and the comcast box will need to be on the channel the program is on. I.E. Panasonic recording channel 3 or 4 from 10-11 am comcast box on channel 55 during that time.
Apr 21, 2009 | Panasonic DMRES15 DVD Recorder
Hi! I posted a few days ago about my elderly neighbors TV being disconnected from Dish and now she gets no signal on all channels. She has a TruTech Model (from back of TV) 008-09-0119. I disconnected the...
What kind of antenna is she using? If she is using an Over The Air antenna that was supplied by Dish it would be best to buy another type of antenna.
Please post back with her antenna type and the zip code you live in so I can help you further.
Lone99star
Mar 02, 2009 | TruTech PM1919BXA1 19 in. LCD TV
Cannot get local channels back after dropping cable.
Are you positive that your city has not done the Digital Conversion? Some Cities are doing it early before the February deadline. Also make sure you are tuning in to the correct channels. Meaning that if on your Cable Provider ABC was on Channel 3 that does not mean that ABC with still be on Channel 3 after you have your Cable turned off. Most of the Time the Local Stations Tag will let you know what channel its on. It will be something like "KWAS ABC 27" So on your TV you would Tune it to channel 27 to get ABC and the same fore NBC , FOX, CBS , etc...
I hope this helps Take Care =)
Dec 07, 2008 | Televison & Video
I purchased a SANYO-DP46848 42"HDTV. I have a Cable box and my cable provider (Time Warner Cable) provides free HD Channels. However.... I CANNOT PICKUP ANY HD CHANNELS ON THE NEW TV. WHY???...
I just got the same exact one, when it searches automatically the first time it doesn't look for digital channels. go to Menu>manual channel search>cable. it will look for all possible signals and will take forever probably. the free digital channels will take several seconds to switch channel to channel, but they're there! They will show up on your screen as "DC 91-2" or similar. you can switch back to regular cable channels with the input button, you just cycle through all the inputs. hope that helps.
May 18, 2008 | Televison & Video
Channel changing by itself.
I will tell you that westinghouse is the worst company among other brands. If you have warranty, return it and buy a sony or panasonic with a little extra money. It will help you later from buying another TV that is also as crappy as westinghouse's.
Oct 01, 2007 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Memorex MLT3221 32-Inch Widescreen LCD HDTV Logo
57 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Radames Pagan
Radames Pagan
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
