Question about Hardware & Accessories
How do I program my living solutions 2 outlet digital timer
  • Features: F = Power Off, 0 = Power On, (1-9) = On at dusk and Off (1) to (9) hours later, C = ON at dusk and OFF at dawn.
Posted on Dec 06, 2015
Where can I find a instructions to program a Utilitech Digital 2 Outlet Timer??
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 26, 2017 | Hardware & Accessories
Utilitech 2 outlet timer - 0155671
No.
Each outlet has same on-off programming.
Utilitec does not make 2-channel timer.... and neither does any other consumer timer company... unless you buy a box timer like Intermatic ET 1100 or 1800 series etc 2-4-6-8-12 channel timers.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET-series
To have 2 different programs from same outlet, then buy 2 bar timers that both fit same outlet, and then program each to suit need.
http://waterheatertimer.org/Woods-timers-and-manuals.html#bar
Many bar timers are 24-hour instead of 7-day.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 22, 2013 | Hardware & Accessories
Lost instruction for operation of woods indoor digital 24 hour timer (59203)
1) Copy following link for possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
2) Don't forget to reset timer to clear traces of prior programming.
Timer has internal rechargeable battery that eventually gives out, rendering timer useless.
Timer has 1 year limited warranty through Coleman.
3) Suggested replacement timer: Woods 59009, 59008, 59007.
Two prong and 3-prong outlets, rated for CFL LED incandescent etc
http://waterheatertimer.org/Woods-timers-and-manuals.html#50009
4) Or buy timer locally for ez return if timer does not work.
5) Jan 2013: Best brands for warranty support are probably Woods, Intermatic, GE, Tork, Sylvania, Leviton.
Promotional-grade timers from First Alert, Timex, Brinks, Stanley-Westinghouse, Utilitec etc may not have clear on-line warranty support.
Jan 07, 2013 | Woods Indoor 24 Hour Digital Timer (59203)
I need help programing a outdoor 2 outlet digital timer for my xmas lights
Copy following link to identify typical outdoor timers across several brands, with operation manuals for each:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
Nov 11, 2012 | Hardware & Accessories
How to use the TM 111D
1) To use the timer:
Make sure outlet has power.
Check outlet with circuit analyzer to make sure polarity issues do not affect timer operation.
Plug timer into outlet for 1 hour until battery is charged.
Some timers have internal battery that do not need to be charged.
After battery is charged, unplug timer to set programs.
Set program(s).
Turn lamp ON and make sure bulb is good.
Leave lamp turned ON
Plug lamp into timer.
Then plug timer into outlet.
2) To program the timer, open following links for possible instruction manuals:
http://waterheatertimer.org/pdf/How-to-program-Timex-TE111.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#Timex
Take a moment and rate answer:
Sep 02, 2011 | Timex EASY TO SET TIMER BY TIMEX
Are you able to share instructions for a Utilitech indoor digital 2-outlet timer? Item #0155671
Open following links:
1) Basic written instructions:
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
2) Instruction pdf manual for identical Woods 59377 timer showing programming plus how to set countdown and random feature, summer-winter changeover, load ratings.
http://waterheatertimer.org/pdf/Woods-59377.pdf
3) More resources
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
Aug 28, 2011 | Hardware & Accessories
I put the timer on my lamp and it stays on even if it's not the time that I set, and then it turns off when the time is up... Why does it stay on? And not go according to the timer?
For digital timer:
1) Timer is defective
2) Conflicting programming so timer does not perform as expected
3) Timer not set to correct mode.
4) Program 'off' is set correctly, but program 'on' is not set or 'on' time conflicts with other programming.
5) Current time not set correctly
6) Polarity on outlet is reversed or noise on the line. Check outlet with circuit analyzer.
7) Combination of factors listed above
Jun 26, 2011 | Woods Indoor 24 Hour Digital Timer (59203)
I have the timer set, all 7 cycles to come on at 6am go off at 6pm. set and checked. put mode on auto but light did not come on. it only came on when set on the on mode. please help, thank you
You are having problem programming zilla digital power strip timer.
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
Either timer is defective, or programming has conflicts that cause timer to ignore programming, or blue-yellow outlets are not understood, or combination of these problems.
Zilla yellow outlets are for daytime hours.
Blue outlets for nighttime.
The instruction manual does NOT specify what hours are for daytime. 6 am to 6 pm? Or 12 am to 12pm?
The zilla analog timer divides day and night at 12 and 12.
If digital timer is also 12 and 12, then you cannot set ON at 5:59am and OFF at 5:59pm without fudging the current time setting. For example offset current time by exactly 6 hours.
Add a comment for more free help
Upvote the help.
Jun 10, 2011 | RTO Zilla 24/7 Digital Timer Power Center
I have intermatic TN311 MODEL TIMER IDK HOW 2 WORK I WANT IT TO COME ON AND OFF FOR 15 MIN EVERY HOUR FOR 12 ORS A DAY IS THAT POSSIBLE AND HOW
Open following link to identify TM311 timer:
http://www.amazon.com/Intermatic-TN311C-Heavy-Grounded-Timer/dp/B00002N5FO
1) First of all, you would need more turquoise 107TN222 ON and red 107TN221 OFF trippers.
2) BUT big problem is that TN311 time dial is divided into half-hour segments, so minimum on-off is probably 1 hour since it takes 2 trippers for on-off cycle, and width of 2 trippers is same width as 1 hour.
3) Open following link for plug-in timers with 15 minute segments shows Woods 49664 & Stanley 31192 & Sylvania SA110
http://waterheatertimer.org/Woods-timers-and-manuals.html#49664
4) Notice the 49664 dial, that each hour is represented by 4 segments. This says timer on-off period is 15 minutes.
To set this timer, you would pull up all segments around the dial, and then push down 1 segment for each hour that you want timer to turn on for 15 minutes.
5) TN311 has 3 prong grounded outlet, Woods 49664 has 2-prong outlet.
6) Stanley 31192 timer and Sylvania SA110 have 3-prong grounded outlets and 15 minute intervals.
7) You cannot accomplish 15 minutes intervals for 12 periods a day with programmable digital timer.
Most digital timers allow 1 minute program times, but are limited to 6 or 7 programs, and not the 12 separate on-off periods needed for your project.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Mar 18, 2011 | Hardware & Accessories
I've lost the instructions for my Holiday Living #10243 6-outlet outdoor yard sake with digital easy set timer. How do I program the yard stake? thanks!
I think the Holiday Living yard stake is made by Woods.
GE sells identical 6-outlet yard stake for which I have a manual with clear instructions and images:
http://waterheatertimer.org/pdf/GE-15107-outdoor-timer-manual.pdf
Add a comment to help me identify your timer so others will be helped also.
If manual shown above is incorrect, open link below to view general list of yard stakes with manuals:
http://waterheatertimer.org/Woods-timers-and-manuals.html#yard-stake
Dec 11, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
Hardware & Accessories Logo
272 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
