Question about Refrigerators
Water leaking than freezing on floor of lower draw under ice maker in subzero 700tf freezer
Chipping away ice from draw
    Habit-Forming:
  • 102 Answers
If cubes are very large the ice maker may be overfilling and need the fill adjusted to allow less water into the maker. Otherwise check the fill tube (runs from the back wall to ice maker) for loose connections or cracked tubing. (In this instance the cubes would be smaller than usual.) If neither of these is the source, then look up to the highest point of ice (water flows downhill) for the origin. Suspect a stopped up defrost drain. Thaw and clear ice, then clear drain tube (DO NOT use a wire for this) with warm water and a turkey baster. Once water is flowing through tube and into drain pan under the unit the problem should be solved.
Posted on Dec 06, 2014
SOURCE: Sub-Zero 550 water leak and freezing
I think the tube is clogged with gunk.  Had the same problem and it recurs every 2-3 years.  Blow the tube out with compressed air. from inside the refrigerator at the drain port.  Insert the air compressor wand in the port and blow in the compressed air.
Posted on Oct 28, 2007
aborcass
  • 2651 Answers
SOURCE: Water freezing on the tray section under the freezer drawer.
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 15, 2008
  • 72 Answers
SOURCE: Viking freezer leaking
you have a clogged drain, it is either clogged with ice or some kind of debris, thaw the freezer out and push a length of weed trimmer line down the drain. The drain is accessible by removing the back wall of the inside of the freezer. If there is no clog then the drain may be freezing up, if that is the case, take a piece of 14 gauge romex wire and loop it several times around the heating element at the bottom of the evaporator and push a few inches of it into the drain, this will get hot and transfer heat when it goes into a defrost cycle which is where the water is coming from in the first place
Posted on Jun 17, 2009
  • 102 Answers
SOURCE: Subzero model #561, freezer is warm, water leak
Check to see if the freezer fan is running. Push in the two switches at the top. The light should go out and if the freezer is powered on the fan should come on. The icemaker runs on temperature so no cold means no ice. Check for ice build up around the evaporator. Could be a defrost issue or a sealed system problem. As for the water, is it the floor of the unit or the floor of the house? Is the drippan in place or sitting on the floor? Also check the condenser fan motor. If this is all greek to you, you should probably call a factory authorized servicer.
Posted on Aug 05, 2009
  • 358 Answers
SOURCE: Leaking water and ice build-up in freezer
There's a drain hole in the freezer side behind the bottom drawer in the back wall that must be clogh ; put hot water into it untill melted the ice and keep pouring water to clean the drain (don't worry , the water goes to an evaporative tray) .Keep the drain clean by putting every 3/4 months half a cup of clorox or bleach.
Posted on Sep 28, 2009
Water freezing on floor of lower draw under ice maker
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Dec 05, 2014 | Refrigerators
Water leaking inside refrig. and then freezing in lower bins
your drain tube is blocked with a ice dam and there is ice under the freezer floor. Removing the rear panel and floor will give you access to removing the ice and clearing the drain.
Eric
Apr 03, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker is not making ice
Subzero ice makers arent all cut and dry. You could have an intermittent issue with either the ice maker itself, or the solenoid valve. SZs also often utilize a door switch which prevents the ice maker from operating if the door or the basket which the ice bucket sits in are not closed or in the proper position. If you have had other what would seem minor problems, that you have lived with, they can inadvertently affect different things. Most sub zero ice makers you can start manually by rotating the ejector comb clockwise as you look at the front of the icemaker, when the icemaker completes its cycle, do you get water to the ice maker, and do you get enough water, usually 140-150 ccs. If the ice maker continues rotating on its own after your initial start up, and receives the proper amount of water, either you have a cooling problem, a door or something is not in the correct closed position, you have a bad switch, or the ice maker is bad. If you receive little or no water at end of cycle, you have a bad valve.
Mar 25, 2010 | Sub-Zero 15.3 cu. ft. / 433 liter Upright...
My subzero 650 ice maker drips water w/o making ice. Makes a mess with ice build up. I had to turn off water lined to stop the ice maker from dripping. Turning off the ice maker switch did not stop the ice...
Good day,
No, a new water valve should solve that problem. The diaphram in the valve is not completely closing.
Very common problem.
Thank you for using FixYa
Dec 24, 2009 | Sub-Zero 650 / O Bottom Freezer...
We have a side by side refrigerator with ice maker that leaks water on to the floor.The water also runs into the freezer part and freezes under the bottom bin. It will not make ice but the ice maker...
Could be one of several things.
The cold water reservoir in the refrigerator could have a leak. Usually located on the back wall behind the drawers.
The ice maker may not be operating properly either, or the hose leading to it may be leaking.
Or the ice maker mold may be cracked.
Or the ice maker fill tube has gotten misaligned with the ice maker.
Let me know what you find, and I can give you more direction.
All assumes the ice maker is acting as you describe. There are situations where the drain tube under the freezer coil will clog, preventing water from properly draining from the defrost cycle.
Dec 16, 2009 | Coffee Makers & Espresso Machines
Ice in the bin on subzero 632 freezer is in clumps
if the ice maker leaking it's easy to replace, or may be just a water supply tube has been moved to the side
Oct 03, 2009 | Sub-Zero 632 / S
GE side by side leaks water from icemaker tube
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Feb 03, 2009 | Sub-Zero 561 / F
Sub zero 532: noise increasing.
We have the same SubZero unit and the water leak is the ice maker line or the pan that catches condensation. If you unscrew the panel at the bottom, you will be able to take the pan out and see if the water is from there. If it is from the ice maker line (which was plastic on ours), you should fix this right away as we didn't and we ended up having a $10,000 flood that ruined our hardwood floors. Also, the increased motor noise happened to us as well, but when we had the motor replaced, it is not much quieter.
Nov 15, 2008 | Sub-Zero 632 / S
Admiral HMG 62163 water leaking internally & freezing in lower basket
good attempt, its actually a clogged drain thats backing up and your drain water is not able to leave refrig so it falls to bottom of freezer floor and eventually out the door. romve the items from the freezer and take the lower back wall off form inside, directly under the evaporator under all that ice there is a drain hole, youll need to clear that hole of iec( pouring boiling water down until you get a free flow of water then you can reassemble uint problem solved
Oct 25, 2008 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
73 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
