What size screw is used to attach the stand back on the TV ... was on the wall and now need to put the stand back on but lost the screws
  • 3,904 Answers
I believe they are a 4 mm. Each TV is slightly off but you are in the right area at 4.
Posted on Dec 05, 2014
Can I buy screws to fix base onto my umc tv
Yes The screws that you took off the back of the tv mount on wall brackects mounted on the back of your TV should be the same size
6mm
Oct 23, 2014 | Televison & Video
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Insignia TV stand screws
Had same problem with Insignia TV...#12 - 24 x 1/2" machine screws...found at Home Depot in bagged items (can't use longer because some of the holes don't go all the way thru)
May 20, 2009 | Insignia LCDTV26 26 in. Television
Lost screws for stand on Vizio VU42L
If you pay for shipping I will send you my screws. Maybe a buck or two will cover it in an envelope. I just removed them last night as the TV is being junked for the parts. Email me.
MBSimonds AT aol DOT com
Mar 26, 2009 | Vizio VU42L 42 in. LCD TV
Tv stand screws
Check the kitchen drawer next to the fridge for the screws !!
When you get new screws, use lengths 1/2".. any longer and you might hit something inside.
Don't know why this is posted under IS-LCDTV26.. I would pull a screw from my 26" and measure it, but it's most likely different than your 42"
Sep 01, 2008 | Insignia LCDTV26 26 in. Television
PROTRON STAND
Is that a problem? Check the hole size and choose a screw with a head that is bigger than the hole size. Typically select a minimum of 4mm diameter screw.
May 03, 2008 | Protron PLTV-37 37 in. LCD Television
Polaroid TV
You are correct. Polaroid does not make the screws available. You will have to obtain locally, per Polaroid.
Mar 05, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Televison & Video Logo
134 people viewed this question
Top Televison & Video Experts
