Question about Garden
How do I pull the rope out of my winch - Garden
  • 3,904 Answers
There is a release lever on one of the sides. It is usually pretty stiff to get open but it does. Once you disengage the clutch with that lever it will free spin off. Remember to re-engage the clutch when you are ready to real it in.
Posted on Dec 05, 2014
8500lb. motomaster winch- pulling up dock when winch all of a sudden goes into reverse?? Could this be the hand-held or the winch itself? Runs off a marine battery with a battery tender
it could be either one will need to test the switch with a meter if it got hot use of power will heat up unit the switch can malfunction or the power circuit in the winch did the same --moisture also plays havoc controls check also that no water seepage from cable interfered with power
Aug 16, 2016 | Cars & Trucks
John Deere 2012 648g3 skidder winch will let out, when you try to winch in it will roll slack out of cable, but winch won't lock up and pull hard. How can I fix it?
if your saying that winch will take in and let out ok but wont hold a load in tension , then your winch directional valve or the winch motor is worn out and is allowing oil to pass right thru it regardless of it not being activated as skidder winches don't have a brake like electric winches do it uses the power of the oil locked into motor to hold a load ( that's also why id never stand under a load suspended by one !!!)
Nov 15, 2015 | John Deere Garden
Having trouble with my logging winch constantly pulling in.
service the clutch section of the winch as it appears that something is broken in that section of the winch
This situation is dangerous because if something happens, the winch cannot be disconnected or reversed immediately
May 25, 2015 | Cars & Trucks
How do I replace the pull cord on snapper sr1330 riding mower
remove coil cap look at the rope pulley pull old rope forward till you get to end knot hold pully pull not out with the rest of the rope then wind pulley up till it wont go any farther back off one turn alighning the cover hole with pully hole use ascrew driver stuck between the slot on cover and pulley ten get your rope take a lighter and burn the end of the rope the take a rag pul the end of burt end of the rope shuold leave a pointed rope then take rope and stick through pully hole then the housing make the rope about 70 iches long it will be to long i no but just do it tie a knot in tend on the back of pully take lighter and heat it still it melts a very little the knot that is pull rope on through pulley hold rope remove screw driver slowly let rope wind up on pulley still it stops you will have rope sticking out reistall pulley cap then put handle on rope put handle all the way down to cap pull rope one turn push handel down to cap atie a knot in rope as close to to handel as possible heat not like the other end cut rope with 1/2 inch of rope sticking out of knot
Sep 13, 2014 | Snapper Garden
Change coolant tank
a little rope and a hand made winch to pull up proper tool you should use to get to hose and channel locks to help pull off old hose
Nov 09, 2013 | 2000 Cadillac Eldorado
I have a 2011 Sportsman 550 EPS Touring (2 up) with a glacier 2 plow set up. I have used it only this winter and already bent the blow frame, worn out the blade guides (the pads that keep the plow edge...
Your picking the blade up too high. I forget myself and have done the same thing and also broken the winch cable. You have to make a consious mental effor to not over pick the blade! The true answer is a limit switch on the winch that cuts power when the winch hits a preset height.I have searched the internet and found that such a device does NOT exist! I may build on myself, I don't think it would be hard to do. ANYWAY THE ANSWER IS TO STOP THE WINCH BEFORE IT GETS TOO HIGH AND TRYS TO WRAP THE PLOW AROUND THE WINCH!
Jan 21, 2011 | Sport & Outdoor - Others
Can not pull winch cable out had to take cover off
The clutch knob on the side needs to be loosened up. Rotate this and the shaft will be free to pull the cable out.
Nov 10, 2009 | Master Lock 5400d: Portable Select Access...
Unit will not pull up the anchor
First, put a volt meter across the winch's power terminals to verify that the voltage is not dropping several volts when comanded to run, indicating a bad cable connection somewhere. Anchor winch's pull alot of current from a battery.
For a test, use car jumper cables from a good battery to the winch to see if it runs better.
Oct 18, 2009 | Boating
518 cat skidder gearmatic winch keeps turning when put in free wheel 1985
pull the secondary clutch apart on the winch and clean with emory cloth or sand paper and u should see a change in this problem
Sep 08, 2009 | Heavy Duty Associated Equipment 6002B...
The starter pull cord has pulled off.
EASY,REMOVE TOP COVER OF ENGINE THAT HOUSES ROPE ASSY. LOOK UNDERNEATH PLASTIC PIECE,CUT THE KNOT OFF THAT COMES THROUGH HOLE AND PULL AND EXISTANT ROPE OUT. OK, GET NEW ROPE AND HANDLE TOGETHER,THE END THAT IS OPPOSITE FROM NEW PULL STRING HANDLE YOU ARE GOING TO USE. CAREFULLY WIND UP ROPE HOUSING NICE AND FIRM JUST BY WINDING IT UP WITH HAND IN AS IT SITS IN TOP COVER. WHEN YOU THINK IT HAS ENOUGH TO PULL ROPE IN FEED END OF ROPE IN HOLE AND IN CHANNEL OF ROPE HOUSING,THERE IS A SMALL HOLE TO LINE IT UP WITH,WHEN SEE THE ROPE END FEED IT THROUGH THAT HOLE NOW. MAKE TAKE ANOTHER SET OF HANDS OR A WEDGE TO STOP RETRACTING OF SPRING. PULL ROPE THROUGH AND TIE A DOUBLE KNOT AT END SO IT WONT PULL THROUGH. SLOWLY LET IT PULL ROPE IN,THEN PULL ROPE BY HANDLE FULL LENGTH TO ENSURE ALL KINKS ARE OUT AND IT PULLS BACK IN LIKE IT SHOULD.
Jul 12, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
