Question about Dryers
Lint on clothes
Looking for the lint filter
    Master:
  • 706 Answers
Make and Model please and get back to me. Usually they are right inside the door at the bottom or on top as a pull out tray.
Posted on Dec 05, 2014
Model 41798702891 Kenmore stacked washer/dryer is collecting lint inside the door and putting lint onto the clothes.
I am not much of an expert with dryers but i'll give it a stab. Should there be a filter that catches the lint so that it does not go all over the clothes? Have you got the manual. If not, see if you can find the manual online and see if there is anything mentioned about a lint filter.
Dec 14, 2013 | Kenmore 98702 Stacked Washer/Dryer
Lint filter on LG DLEX2901V sticks up in the corner and catches clothes
Look familiar? LG dryer model DLEX3250W. Lint frame does not fit the slot anymore. NOT BECAUSE OF EXTRA LINT it's because the frame is warping.
Dec 07, 2011 | LG DLEX2901V Dryer
The lint filter does not fit properly in the lint trap. The corner of the filter catches an item of clothing and twists it. I have to check it several times to clear the item away. I assume this...
We have the same model and experience the same thing. The way I fix it is to remove the filter, then with a flash light I look down into the lint trap. You will notice that lint has built up in the track where the lint filter sits. I use a wooden skewer to run along the track and lift out the lent. Hope that helps
Aug 21, 2011 | Samsung DV448AEE Electric Dryer
Ijwant to dry my cloth but when i turn on it appear check filter how i am going to fix
You should empty the lint filter. The lint filter catches all the lint from your clothes and will need cleaned occassionally. I clean my lint filter after every load. Towels usually clog the filter faster than other clothes.
Aug 07, 2010 | LG DLG5932W Gas Dryer
Prblems with Kemore washer
Clean your washing machine before your next wash load to be sure there is no lint trapped anywhere in the machine. Fill the tub about half full of water then add a couple of cups of white vinegar to the wash water. Allow it to agitate and then sit there and soak for at least an hour before you empty the machine.
Lint is small fibers from clothing that have come loose from natural wear or laundering. They can build up in washers and wreak havoc on your clothing. The dryer will remove the lint. But with clothing, like dress shirts that are air-dried, this can be a real problem; often requiring multiple washings to remove the lint. Older washers came standard with removable lint traps that could be cleaned. Some would filter the water as it recycled through the washer, while others would require the removal of the center tub support for cleaning.
Newer washers have a self cleaning system that uses a filter to trap the lint and the spin cycle to flush it away. It saves the inconvenience of having to manually clean the filter.
If you have a lint problem, here are a few tips to try:
1) Low water pressure can impede the flushing action of the washer during the spin cycle. Look for pressure variations during filling of both hot and cold water. A kinked or blocked hose can cause this. Check for sediment in the hose as well.
2) Verify that the all of the water is being pumped out of tub and that no restriction in the drain hose exists.
3) Don't wash high lint producing items like socks and towels with your dress shirts.
4) Use a name brand detergent. They have higher quality cleaners and soften the water better, which helps release the bond between lint and clothing, allowing it be flushed away.
5) Don't overload the washer. Your washer needs water and room to remove the lint.
6) Run a wash cycle with a cup of regular white vinegar added. This will help rid your washer of any accumulated lint.
A washer doesn't produce enough lint to have any effect on a septic system, so a separate washer filter is not necessary.
Add a cup of either white or cider vinegar to your washing machine along with the detergent before loading in your clothes to keep lint off.
Sort out all towels and washcloths since they create lint. Put them through a separate wash cycle to keep them from transferring lint to your clothes.
Check the labels on all your clothing to be sure you sort them correctly. Cotton clothing produces lint in the washing machine while polyester clothing picks it up. Wash them at different times to keep the lint off those that are likely to pick it up.
Turn your clothes inside out before putting them into the washing machine to keep them from collecting lint as they go through the wash cycle
Jun 18, 2010 | Kenmore 24032\24036 Top Load Washer
We have a Whirlpool top loading washing machine that leaves the clothes covered with lint after each load. Delicate clothes that have elastic bands are covered with pieces of lint on the bands that are...
Your service man is right, the lint is filtered through the filter plugs on the bottom of the tub, and backflushed out during the spin cycle. This does not do a great job of filtering out the lint that came out of the clothes. So why is there so much lint? Three reasons: 1. Clothes being beaten against the agitator, tub, each other. The Whirlpool washer has a pretty decent way of agitating the clothes without too much damage, as long as there is plenty of water for the clothes to move through. As long as you make sure your load size and water level are correct, this shouldn't cause a lot of lint. I always have a larger water level than the load size calls for. 2. Lower quality material in the clothes. We definitely see this a lot, especially in the cheaper towels, rugs, sweaters, ect. Some of these have such cheaply made fibers, that they put out a lot of lint. 3. Laundry soaps. Most soaps are very caustic detergents and eat the fibers right out of the linens. There are some brands of washers that still use a type of metal in them that this soap eats right up, so in a few years the machine is junk. All of the washer manufacturers went to plastic outer tubs, as the soap was literally eating holes in the outer tubs in 2 to 3 years on some brands. This is one of the reasons we have so much of the micro lint that is so fine, it goes right through your dryer lint filter and causes lint build up in the venting itself. Years ago, at our shop in Hawaii, we tested naturopathic soaps for 12 years before we settled on the Melaleuca brand for our laundry soaps. Ph neutral, cleans the clothes better than any brand we have tested before or since, does not leave the sludge in the outer tub that most brands do, does not leave a hard aggregate in the tubs like some other brands do, is cheap and does not cause the allergys, athsma, skin rashes, ect. that most of the caustic brands are doing. We have used it for over 10 years now and see very little lint in our Whirlpool washer. Look it up online, join it, and buy the soap directly from the company. It sounds like you have done everything else correctly to the washer, that you could have. I am impressed, most people could not have done what you did. Hope this helps. Good Luck, Appliance Specialists
Jan 22, 2010 | Washing Machines
you did not give me a mod # of your washer .... so i will go through the history of the lint filter 1955-1964 the lint filter was on the right side under the lid , twist knob and pull screen out 1965-1986 lint filter was self cleaning mounted under the washer 1987 -today there is no lint filters any more ..... lint filters where used when people hung the clothes out on the line .... today most people use a DRYER that has the lint filter in it .... i hope this helpes ....... if you are going to rate this please rate this 3 or 4 stars , that will keep me in the paid answer department . thanks
Apr 01, 2009 | Washing Machines
GE top load washer w/no lint trap leaves excessive lint
Most US-sold washers made after the mid 1980s don't have lint filters. The manufacturers weasel-word around it by saying that the lint "goes down the drain", leading people to optimistically assume that there is a self-cleaning filter in there somewhere. There usually isn't and whatever lint doesn't go down the drain is filtered by your cloths (but whatever does might clog your septic system). As a result of this scam, it's much harder to hang-dry or iron-dry clothes that haven't been hand washed. And, if you think spending $2000 on a pair of matched "front-load" style machines will solve this, you might be wrong; many of those washers still have no lint filter.
Jan 08, 2009 | GE WBSR3140DW Top Load Washer
Lint filter going off after 5 minutes then shutdown
Hello folks try this if you have not gotten this resolved. Your dryers have 2 sensor systems, the first one test the clothes for moisture, the second for the heat. The 1 sensor system drops resistance when the wet clothes are put in the dryer. the shutting down after 5 minutes and lint filter light coming on could be that the dryer isn't sensing the moisture. Now for the fun part, the entire inside of the drum and paddles is the moisture sensor. Try cleaning the inside of the drum with a cleaner to remove any detergent or fabric softner residue. This is crucial if you are using fabric softner sheets as they coat the drum. Also wash the lint filter with soap and water so the water goes straight thru instead of puddling up. Remember to also clean the condenser as this can trigger this issue as well. Hope this helps
Jan 02, 2008 | Bosch Axxis WTL 5410 Electric Dryer
Dryers Logo
Top Dryers Experts
