Question about Samsung HP-T4254 42 in. Plasma Television
Is my tv compatible with a blueray player
I've tried going through the menu, but all I can get is a "not supported mode" message on the screen.
    Top Expert:
  • Samsung Master
  • 74,383 Answers
Yes.
Posted on Dec 05, 2014
SOURCE: Samsung TV Mode not supported message
check to see if the output is set to 480i. HDMI does not support 480i - http://samsungplasmatvfaq.com/index.php/Display_settings
Posted on Nov 19, 2007
  • 7 Answers
SOURCE: I hooked a Toshiba DVD player to my Samsung
Have you used a scart cable? Then use av in menu and connections.
Posted on Dec 31, 2009
  • 231 Answers
SOURCE: Mode not supported message
ok there should be be a setting in the menu probably called video source depends on what model it is, make sure you put it on hdmi,this should do it, let me know if it helps
Posted on Apr 18, 2010
SOURCE: Plasma tv showing "Mode not supported" message
YOU HDMI SWITCHER IS DEFECT OR YOUR TV IS NOT COMPATIBLE
Posted on Apr 26, 2010
manojag123
SOURCE: 'MODE NOT SUPPORTED' message appears on my TV screen
i have samsung 22' lcd series 4 tv but i connected it with the dvd player via hdmi it shows mode not supported. but the same dvd works very well on another samsung lcd of same configuratition. please help me
Posted on Jun 21, 2012
I have a sony blue ray DVD player and when I connect it via HDMI cables into either HDMI1/DVI or HDMI2, i get the message invalid format. I've tried multiple cables, multiple LG TV's, and the it...
Tries tv unplug,replug it back like about an hour later.Than tries go into the tv menu do a resetting to factory setting in every settings on the tv.Than reconnect the Blu Ray player again should work.If not the tv and Blu Ray player softwares main firmware just not compatibles.The only solution is just don't used it on this tv,because if u tries to upgrade the tv firmware or the Blu Ray firmware and u get the wrong upgradable version in the tv or Blu Ray player.That it u in deep ****,than the tv or Blu Ray player well not functions at all or have multiple orperational problems during it playing times.
Jun 18, 2011 | LG 42LC7D-UB Television
Just received a Samsung BR BD-P1500 2009 model, as a gift. No one code for the remote control work for my Panasonic Viera TC-L37D2 bought in 2010. Samsung "assistance" told me that my BR is too...
Unfortunately, Samsung tech support was accurate. Most universal remotes (and the portion of the remote programming to control other devices is the same program) only have codes for devices released 6 months or more before the remote was programmed.
However, any universal remote that is newer than the TV (by that 6 month programming period) should control both devices. Low end universal remotes may not support all of the features of either the TV or the Blu-ray player. The remotes that can be programmed via a USB connection to a computer are the fastest to set up. (Alternatives: You can use both remotes when watching a movie or get a Viera link Blu-ray player that is compatible with the TV. For the second option, you need a device with the HDAVI Control (not above Control 5) connected via a good HDMI cable)
I wish that I had better news.
May 08, 2011 | Samsung BD-P1590 Blu-Ray Player
For some reason mt blue ray player was saying 1080i and not p so i went into menu and changed to 1080p but tv is now saying mode not supported and i cant get back into the menu on the blue ray player to...
Try to make use of the yellow video cable, the cable that is part of the RCA cable and try to set the TV to AV1 as soon as the video cable is connected from your BD player to your TV. Turn on your Bd player and you can now set the TV to its correct resolution. Best thing also to reset oyur bd player back to its factory settings.
Oct 22, 2010 | Samsung BD-P1400 Blu-Ray Player
My HDMI connections aren't working. How do I
Tries unplug and replug the tv back about an hour.Let the tv reset itself back to factory setting.Now go in ur menu go to PICTURE.Go down the menu pick reset,that to reset all the funsctions in the Tuner board.This process should get all the HDMI Hub. working again,not than ur Tuner board have all the HDMI Hub. are shorted and dead.
Apr 27, 2010 | JVC LT46FN97 46 in TV
Apr 24, 2010 | Samsung PN58B860 58 in. HDTV Plasma TV
Samsung BD-up5000 stuck on slideshow
there is no present fix for this if i remember the hulk has this too the only way around this is to go into menu and turn off the on screen display messages
May 12, 2009 | Samsung BD-UP5000 Blu-ray and HD-DVD...
Unable to get home theater sound on cable tv mode
I had this problem on my own tv and it nearly drove me mad, in tv menu under sound submenu their is a setting called spdif mode, there are choices in this mode that can be made, My current tv has Auto, off and pcm. some tv's have more choices. Try playing with these settings and its possible you can get it to work with cable, your cable signal probably uses a different sound format to the blueray/dvd player. note if this works the sound might not work when you go back to blueray/dvd player so note the setting before you change it in case you need to go back to it when you change over viewing choices. good luck.
Aug 17, 2017 | Panasonic Home Theater System System
Samsung HP-T4254 42 in. Plasma Television Logo
Henry  Thomas
Henry Thomas
