Question about Electronics - Others
I have a problem with my control borad xantrex dr 2424 with a lightover led green
A problem with a light over load green
2 Suggested Answers
  • 5 Answers
SOURCE: prosine 2.5 fault 195
This internal fault code can mean so many things, but basically it more than likely has some internal parts that the smoke is no longer inside. They can be repaired however, email sunyout@gmail.com to discuss further.
Thanks, Bob
Posted on Jan 12, 2010
Xantrex freedom series inverter/charger led lights are rapidly blinking green when 50 amp shore power is on. How do I manage this?
In the easily downloadable users manual, on page 11 I've found the information. Page as png in attachement.
Oct 14, 2017 | Boating
Issues with xantrex dr series inverter
Make sure the battery connection is solid, if the 12 V collapses at the inverter -> no power. If that is OK, make sure to apply first a known good load, like a light bulb, if that still causes a problem the inverter is broken :-(
Apr 19, 2014 | Xantrex Technology Xantrex DR Series...
Power pack 300 keeps clicking and led light keeps switching from red to green, green to red when charging with a/c adapter.
It sounds like the battery is past it's useful life. Is there any possibility that the unit was activated during a charging cycle? This can damage the battery beyond warranty.
Jan 06, 2011 | Xantrex Technology Air Tools & Compressors
Why does my dr3624 only put out 98 vac, its rated at 120 vac? i'm off grid and my batteries are new 24 volt
Are you using a true-RMS voltmeter to measure the DR's output? The DR's output is modified sine wave, and a cheap average reading AC voltmeter will give you a reading of 90 volts or so. Alternately, if you have an oscilloscope, you can verify that the modified sine wave is around 170V peak to peak. It should alternate in segments of -170, 0, +170, 0... The duty cycle and peak voltages will vary with the inverter load.
- Tom, Sun Electronics International, Miami, FL
Oct 03, 2010 | Xantrex Technology DR3624 Inverter/Charger
I have a xantrex xplus 400. The power and fault led light up as soon as it is plugged in with no ac output.
If you have a load that is more than this inverter will take it will not output anything. Try just a light bulb if this does not work then the output if fried or the output fuse/breaker if it has one is blown.
Feb 16, 2010 | Xantrex Technology DC to Dual-Outlet AC...
Power light flashing HP Compaq Presario SR1230NX PC Desktop I powered the unit down; when I tried to powered it up the only reaction is a green led flashing. The led is located in the back close to the...
Sounds like the Power Supply is bad likes its not able to power on itself. Best thing to do, try a different known good power supply and attach it to the motherboard, if you get the same symptom with the machine not powering on then its a bad motherboard. If the machine does power on then you know your original power supply is bad.
May 28, 2009 | HP Compaq Presario SR1230NX (PJ518AA) PC...
Can the input voltage be changed in the field?
Yes you can. Then it would now operate on 12 volts.
May 26, 2009 | Xantrex Technology Xantrex DR Series...
Prosine 2.5 fault 195
Thanks, Bob
Oct 20, 2008 | Inverter Electronics - Others
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
