Question about Mr Heater Base Camp Mh35lp 35000-btu Propane Radiant
I have 3 MH35LP utility heaters and 2 of them light and run for about 5 minutes and then they blow themselves out and hiss propane and i have to shut them down and let cool before i light them again and they repeat the same process. the 3rd one will run for 5 minutes and just shut off and won't light again until cooled off. Any solutions?
    Top Expert:
  • Mr Heater Ba... Master
  • 6,889 Answers
Sounds like propane source too small or regulators set incorrect keeps running out
Posted on May 11, 2016
Lights while holding primer/pilot button then runs out of propane within seconds. If you wait a minute it builds up then does the same thing like the propane tank is empty but it is full.
Turn off the propane tank and disconnect the heater hose from the tank. Wait 5 minutes and reconnect the heater hose/regulator to the propane t. Turn the tank valve on very, very slowly until it's completely open again. Now, try lighting the heater. If you are using a 20lb LP grill type tank, that should solve your problem.
Hope that helped.
Feb 12, 2011 | Reddy Heater-30-55,000 BTU Variable
Heater runs for 2-3 minutes then shuts off. unplugged to reset and it runs again for less than minute then shuts off again
Clean or replace your photo cell. Make sure your air pressure is set right,Remove your nozzle and blow air thru it . To test your photocell use a muti-meter hooked to two wire and hold flashlight over the end of boot see if ohms increase if not it junk,replace it.
Feb 08, 2011 | Reddy R60A Utility Heater
I have a hayward H400 serise propane heater. I replaced the gas valve. When it goes tot turn on it takes about a minute then starts clicking to ingnite the gas. SSoem time it lights but then goes out other...
0. Check the spark ignitor conection to the board
1. Check the water by-pass valve if you have it
2. Check your gas pressure. (5-7"wc for natural gas, 9-13"wc for propane gas)
3. Clean your filter for your water system or remove it and try again
4. Check the Hi-limits on your heater
5. Replace the thermostat
May 27, 2010 | Hayward H Series Pool & Spa Heater 400k...
How do i light this gas grill, it is a charbroil quantum....it was borrowed from our friend, who is now not picking up the phone...
Checklist:
1-Make sure propane tank has propane in it.
2-Turn regulator (valve attached to propane tank) on.
3-Turn burner dials on, usually there is a "light" or "ignite" position to let the most gas flow to start. If there isn't, just turn it/them to high.
4-Listen for the hissing, if you hear some hissing from the grill, it has gas flow.
5-Turn the dials back off and give 3-5 minutes for gas to clear.
6-Turn dials back on and hit the igniter button.
That should do it! :)
Sep 22, 2009 | Grilling
The propane ignites, but shuts off after 2-3 minutes
check to make sure the thermocouple is stays in the pilot flame could be bad i think lowes has them in the water heating section
May 11, 2009 | Stainless Garden Sun Steel Propane Patio...
Wont stay running
Reddy suggests: 1. Propane supply may be inadequate 2. High surrounding air temperature causing thermal limit device to shut down heater 3. Restricted air flow 4. Damaged fan 5. Excessive dust or debris in surrounding area solutions are: 1. A) Refill tank B) Provide additional and/or larger tanks. 2. This can happen when running heater in temperatures above 85° F (29° C). Run heater in cooler temperatures 3. Check heater inlet and outlet. Remove any obstructions 4. Replace fan. 5. Clean heater. could not get manual for your exact model but if you want manual for RLP 125 then; http://12.153.20.74/manuals/113893-01C.PDF appears to be the same beast. Hope helps :)
Feb 27, 2007 | Reddy Heater RLP100 Portable Forced Air...
Mr Heater Base Camp Mh35lp 35000-btu Propane Radiant Logo
57 people viewed this question
Top Mr Heater Base Camp Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Mr Heater Base Camp Pool and Spa Expert? Answer questions, earn points and help others
