Question about Haier HLF11P 6 cu.ft. top load washer / dryer
My dryer just started making a loud sound and the drum isnt turning
    Scholar:
  • 71 Answers
Good chance the belt has broken that turns the drum. Or the rollers have given out causing the drum to lock up. See of you can turn the drum by hand freely. If you can take the back off the machine and look for the pulley on the drum and check for the belt or other broken parts. Hope this helps could be a stray sock binding the system good luck.
Posted on Dec 05, 2014
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 98 Answers
Could be the drive belt has come off or is broken or if it is gear driven, then it's possibly the gearbox has failed. New belt a piece of cake, new gearbox?, time to price it against a new dryer.
My dryer makes a loud grinding sound and won't turn?
The grinding Sound is the motor attempting to start and not being able. If you find nothing binding the drum and you can turn it by hand fairly easily you will likely need a new motor. Otherwise, find and remove what is causing the drum from not turning
Nov 14, 2015 | Dryers
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Maytag gas dryer makes loud rattling noise. Not a squeaking noise, but something between a rattle and a fast, rhythmic knocking. Tumbler works, heat works, but insane noise.
sounds like the drum isnt balanced. either make sure appliance is properly balanced on the floor or make sure you are not overfilling the tub.
May 24, 2011 | Maytag MDE8000 Dryer
Dryer makes loud humming noise but drum doesn't turn when I push start.
Check to see if the drum will turn by hand. If so, leave the door open but push the light switch button down and start the unit. Once you hear the humming sound, manually turn the drum with your hand to start. If the drum turns normally, you have a bad motor and needs to be replaced. If the drum does not turn, something is jamming the motor and needs to be disassembled and inspected.
Good luck
Oct 03, 2010 | LG DLE2514 Electric Dryer
Dryer is not working makes loud noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Jun 18, 2010 | Fisher and Paykel DEGX1 Electric Dryer
KENMORE DRYER
Hello ENRIGHT11 Welcome to Fixya
My name is Huum,
You said,
DRYER MAKES VERY LOUD NOISE WHEN RUNNING. ALTHOUGH IT HEATS UP AND BEGINS TO DRY, IT STOPS RUNNING COMPLETELY AFTER ABOUT 5 MINUTES. IF YOU WAIT AN HOUR, YOU CAN START IT AGAIN, BUT IT AGAIN SOUNDS VERY LOUD (ALMOST A RATTLING SOUND) AND THEN SHUTS OFF AFTER 5 MINUTES
Faulty Blower Wheel
If you hear a great deal of noise coming from the blower area of the dryer when it is running, then the blower wheel could be defective.
The are many different designs for blower wheels and just as many unique failure modes. Vanes (fins) can break off the wheel and bounce around in the blower breaking more pieces. The blower can break around the coupler with the shaft. This can cause the blower to spin loosely on the shaft. The blower can form cracks which cause it to vibrate, etc.
You should also not be surprised to find foreign debris in the blower. The occasional bird, rodent or squirrel has been known to bypass the out vent cover. If they crawl into the exhaust tube the first thing they come into contact with is the blower wheel.
If the blower wheel is not spinning, or if it is missing vanes, it is not moving air efficiently. As a result, heat is not removed from the heat source and it can trip the high limit switch or blow the thermal cut-off.
Worn Belt
A worn belt can stretch and/or become brittle with age. The belt can then slip on the drum or motor to cause squeaking. If this is the case, the solution is to replace the worn belt.
The belt is not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, worn drum glides or worn drum rollers depending on brand and style.
When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are economical easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Recent Customer Symptoms:
Dryer makes loud noise when turned on. Dryer works and heats up OK but makes too much noise.
Worn Drum Glides
Some dryer models are equipped with Drum Glides. The front of the dryer rests on these glides. They provide a low friction surface on which the drum spins. After time however, this glides wear down. Much like an automobile brakes, these glides make a load grinding noise when they wear thin. This griding against the drum usually leaves a bare metal stripe that is visible at the point of contact. If the glides are worn, the solution is to replace them.
The drum glides not the only items that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, a worn belt or worn drum rollers depending on brand and style.
When replacing the Drum Glides it is a good idea to also change the Drum Support Rollers, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new.
Worn Rear Drum Bearing
Some dryer models are equiped with a Rear Drum Bearing. The rear of the drum rests on this bearing. It provides a low friction surface on which the drum spins. After time however, this bearing will wear down. If the bearing is worn, the solution is to replace it.
The rear drum bearing not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum glides, a worn belt or worn drum rollers depending on brand and style.
When replacing the rear drum bearing it is a good idea to also change the drum glides, drum support rollers, drum belt, idler pulley and clips depending on make and model. All of these items are economical and easily changeable when replacing the rear drum bearing. The upside is that your dryer will operate like new.
Worn Drum Support Rollers
Some dryers such as Whirlpool/Kenmore brands are equipped with Rear Drum Support Rollers. The weight of the dryer drum rests on these rollers. They provide a low friction surface on which the drum spins when in operation. After time however, these rollers wear down. When they wear, often times they begin to elongate and form a non-round 'cam' shape. The result is that when the dryer is turned on it creates a rumble that sounds as though you are trying to dry a pair of tennis shoes. This sound is usually the drum being forced up and down on the non-round wheels. If the rollers are worn, the solution is to replace them.
When replacing the Drum Rollers it is a good idea to also change the Front Drum Glides, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new. Whirlpool
Kenmore models have a dryer maintenance kit that contains all of these items in a single kit.
Thank You For trusting us with your question
Please remember to leave a
solved rating before you leave!
Jan 21, 2009 | Kenmore 63942 Dryer
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
My kenmore dryer isnt working
if youm have a loud heavy huming noise and drum turns freely suspect motor bearings gone
Jul 31, 2008 | Kenmore 62602 Electric Dryer
Haier HLF11P 6 cu.ft. top load washer / dryer Logo
46 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
shaun taylor
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
