Question about Radio Communications
What is the Radio shack version of the K10A50D Transistor?
Http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0&_nkw=K10A50D&_sacat=0
a tenner each seems the going rate
its some sort of FET the k is usualy 2SK10A50D
but on ebay its just the short form ?? not sure im right 100%
but in the past this is the case 10 amps 50ma drain at source??
is it a big switching device motor driver perhaps ??
anyway a 10r buys it
take my advice and never go to ' radio shake ' again!!! and dont use or try use some equiv device
always use the exact device the maker put in is the best policy
or your home can burn down etc,, and your insurance will be void in some cases
Posted on Dec 05, 2014
Which transistor is alternative for transistor d2499 ?
Id try ebay or thefind.com you may get lucky and they will suggest a substitute. Radio Shack may also. How do you know the transistor is bad?
Mar 06, 2015 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Can I use a K8A60DA Transistor in place of a K10A50D?
The K10A50D has a higher Drain current flow rating, it is spec at 10a vs. the K8A60DA rating of 7.5a. The physical layout is indentical, but you run the risk of compnotent fatigue if you install the lower current rated replacement. Other dynamic characterictics of the MOSFETs' are inconsequential in the required performance.
Front view pin layout:
1: Gate
2: Drain
3: Source
Dec 05, 2014 | Televison & Video
I have a Radio Shack regulated 3 Amp power supply (13.8 V DC model 22-504). The circuit breaker keeps cutting out, even when no load is connected. When I turn it off, click the reset button, then turn it...
I assume you have a bad regulator transistor. Check for a shorted transistor out of circuit (disconnect the wires from the transistor before checking for a short). For any further help please email me at wyoed1@aol.com
"Original Radio Man"
Ed
Feb 12, 2013 | Radio Communications
Does anyone know the number of the heat mounted transistor on the power board of philips 40pfl4707 tv
Download the service manual to this set by internet. It will have all details.
Jan 16, 2013 | Philips Televison & Video
I got this midland 77-092 CB radio it first happened when i putted the antenna with has magnet base on the radio, the radio has metal casing, and it began to make a weird noise, after that got quite but...
Hi, my name is John. Welcome to FixYa. It sounds like you shot or blowed a IC FINAL. It can be ordered if your local CB shack does not have in stock. Thanks for choosing FixYa..John
Nov 20, 2010 | Midland 77-092 40-Channels Base CB Radio
Need a manual for radio shack 21-1936 walkie
The 21-1936 was made for Radio Shack by Uniden and is identical to the Uniden GMR-1038-2
The Uniden version of the manual is available HERE
Dec 26, 2009 | Radio Shack 21-1926
After broadcast squelch sticks
trace back from the squelch control to the first and second transistors and you will find one of them is bad, or the components connected to them, one transistor acts as a switch when a voltage from the automatic gain control turns the transistor on via the gate terminal.
Dec 17, 2008 | Radio Shack Pro-2052 Scanner
IR detector
An infared detector is just a transistor that is covered with clear plastic.
matching the spec on it though is hit or miss.
first be sure it is not the ir trasmitter, take it to radio shack and see if their infared re-transmitter broadcaster sees it . or aim at a digital camera
or hold near a radio though that only hears the digital part.
radio shack has some iR transistors in stock usually .
basically you can just plug one in and it may work but you may have to know how to bias (balance ) the transistor to work correctly.
there are many places to scrounge a ir receiver transistor
old tvs , learning remotes, laptops , printers ,
you can inject the output signal of the remote into the ir circuit to see if it is working but you need to add a resistor and drop the voltage a bit.
hope that helps some.
Apr 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Radio Communications Logo
106 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
