Sometimes the flame won't go on at all
Sometimes the flame works perfectly and then goes out and won't go back on.
  • 3,904 Answers
Check or replace your gas regulator. Wouldn't hurt to clean the gas tip either.
Posted on Dec 05, 2014
I have a VC Wonderfire model 2610. The pilot flame is perfect blue on both sides... however, when I hit the switch for the main burner to come on...the pilot goes out... any ideas ???
You may have moved the safety sensor or pilot flame tip. The pilot light heats a wire. The wire is the safety sensor. The wire has to be clean and in the pilot flame near the flame tip.
Jan 10, 2015 | Heating & Cooling
My electric fireplace has not been working correctly. Sometimes the flame works perfectly and then goes out and won't go back on.
You have a great question and the answer was correct you just did not have the correct fireplace for the answer. You should post the make and model. It sounds like the motor is failing but again I do not know what you have.
Dec 05, 2014 | Dryers
MY HP LED HD 23" screen goes black for few seconds and then goes back up again.
This is most likely the power inverter. It's a relatively small part but if it's not supplying power to the backlight, you won't see anything.
It needs to be replaced.
Mar 29, 2012 | Computers & Internet
My water heater won't light. The pilot light works. But, when I try to swtch the pilot to regualr, the flame goes out.
You probably have a defective thermocouple. The thermocouple sits in the flame of the pilot, and the heat generates a small electrical current conducted back to the gas valve, keeping the pilot gas line open after you switch it to the "on" position. That's why you have to manually hold the gas valve depressed (on) during lighting in the "pilot" position, allowing the thermocouple time to heat up enough to generate its current. A defective thermocouple will not generate the holding current.
Jan 06, 2012 | Heating & Cooling
The pilot won't ignite. It's a table heater that worked perfectly one day and didn't the next. Help please.
Look for dust or contaminants inside the pilot safety device. Blow it out with shop air or flush it with rust buster. If yours is electronic look for contaminated flame sensing device. Clean it with emory cloth and rock on.
Nov 16, 2011 | Endless Summer 153100 Open Flame Patio...
Dometic rm2453. Works perfectly on gas or electric or dc. But, won't stay lit driving down the highway. Flame costantly blows out. Perfectly...
Interesting! Did you remove a shield that was there before? The only time I have had a problem like that is when we took the shield coving the pilot light area off and didn't put it back on right. You might want to check and make sure that everything is in place.
Aug 17, 2011 | Dometic RM2452 Refrigerator
Heats but wont stay heated
If the flame come on to start with, but then goes out and won't come back on I would suspect you have a bad coil on the gas valve.
If you see the flame cycle on and off, but the flame does come back on again this is normal. The flame needs to cycle on and off and not be on steady or the dryer would get to hot.
If the flame is cycling ok and the cloths just don't get dry then you need to check your dryer and vent for lint build up.
Aug 02, 2011 | Roper RGX4634KQ Gas Dryer
I have a bakers pride pizza oven and the bottom oven Including the pilot light) continue to go out for no apperant reason. I have changed the thermocouple 3 times and the pilot light once. Sometimes it...
Several things to check. First be sure the pilot light flame is directly striking the thermocouple. It is a pencil sized rod that is next to the pilot light. Sometimes people reduce the size of the pilot flame to save gas. You may need to increase the pilot flame. Follow the small gas line from the pilot flame back to the gas valve. There is a screw where the small pilot gas line goes into the valve. Remove the screw and then deep in the hole is a tiny screw that can only be reached by a tiny flat blade screw driver. Turn the screw counter clockwise to increase the pilot flame. The thermocouple needs to be red hot to work properly. The second item to check is to see if there are any breezes that occasionally blow through the kitchen. Sometimes the hood fan will draw air under the ovens and actually blow the pilot flame out. Same fix, increase the flame. You may also experience low gas pressure to the appliance during heavy usage. You would need a manometer gauge to check for proper gas pressure. In short, if the oven goes out during your busiest time when everything gas powered is on, the oven may be starved for gas.
Sep 09, 2010 | Bakers Pride FC-616 Gas Single Oven
Pilot lights but when ignition pops back up the flame goes out
will either be the unitrol control box or the thermocouple, when you push down you are holding two magnets together and waiting for a small charge to be created from the probe in the flame , if this is not working you have no charge and the magnets won;t stick to allow the valve to open, change the thermo and see if that works first, its way cheaper than a new controler
Nov 25, 2008 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
