Question about Brother Office Equipment & Supplies
Brother MFC-9140CDW displays that I must slide the green tabs on the Drum units to get the printer to print as it jams. Did that -No solution
Slide the tabs and replaced the toners No fix yet.
    Novelist:
  • Brother Expert
  • 228 Answers
If the printer is jamming paper there are three things to check/clean. First make sure paper is DRY as is will hold up 16% weight in water from atmosphere. Second - clean the pickup and feed rollers at the end of the paper tray with alcohol to remove dust and oils. Third set all the drum cleaning tabs to side with the triangle. When you have done that try a print or copy. If the sheet jams pull it out backwards slowly and examine the leading edge. This will show where the jam is occuring and then you can trace the paper path to find any foreign objects (paper fragments) and remove them
Posted on Dec 07, 2014
Drum error. slide green tab in each color - Brother HL4040CN Laser Printer
Try removing all the toner carts and remove the drum unit from the printer. Using the upholstery tool on your home vacuum cleaner, clean all over the drum unit being careful not to directly touch the drum surfaces (they scratch very easily causing permanent marks to print) also vacuum out the inside of the printer. It is likely that dust is preventing correct charge build on the drum. Also make sure the green slide tabs are placed back at the home position at the side of the drum unit. Re-assemble and test.
Oct 13, 2016 | Brother HL4040CN Laser Printer
Brother MFC-7420; "Take Drum out; Slide blue tab..."
go online type in Brother MFC-7420 reset and follow details
Jan 30, 2013 | Brother MFC 7420 All-In-One Laser Printer
MFC-7840W Printer Brother, we have replaced the toner many times and the printer always shows the message on its screen: low toner, and after that shows: toner life end, what we can do, because this is the...
Open the front cover. Remove the drum and toner. Remove the toner from the drum by pressing and holding the green/blue tab on the right side then lift the toner out. Shake the toner side to side for 6 times, and on the drum unit slide the blue/green tab on the far left side from left to right for 6 times also. reinstall the toner back to the drum unit. reinstall drum and toner back to the machine. Close the front cover. The display should show the date and time.
Hope this will help.
Mar 25, 2011 | Brother MFC 7840W Printer
Prints a black streak whether I copy, or print, not dirty glass on Brother 7820N
Try cleaning the corona wire of the drum unit.
You need to open the front cover of the machine and remove the cartridge (drum and toner) On the top right there is a tab that you need to slide from left to right about 20 times, then bring back to home position
Apr 10, 2010 | Brother MFC-7820N Laser Printer
Our brother printer is saying drum error slide green tabs? What green tabs?
You need to open the printer access panel. Inside, there's the "drum", which is secured with plastic tabs.
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/000300/000016/faq000316_005.html?reg=us&c=us_ot&lang=en&prod=mfc9440cn_all
Oct 28, 2009 | Brother MFC-9440CN Laser Printer
Newly set-up Brother color laser printer displays drum error.
The slides you are moving are for the drum units, you could try using canned air to blow in the same area that the sliders slide across, if that doesn't help you may need a new drum unit..
Aug 21, 2009 | Brother DCP-9040CN Laser Printer
Brother 4070 CDW Drum Unit Error
The green tabs that you have to slide are under the color cartridges, so remove the three color cartridges and you will see three green tabs, to slide the tab across the wire you have to first open the translucent plastic wire cover, then slide the green tab across the wires and return it to it's original position, close the wire covers, replace the color cartridges, and reassemble the printer. All the Best
Jun 11, 2009 | Brother HL-4070CDW Printer
Brother Printer MFC-7420
Open the front cover and take out the toner/drum unit. On the top of the drum unit you will see a blut tab that you can slide side to side. Do this 10+ times and this should fix your issue. Make sure to put the blue tab back in the original start position which is believe is to the left on that model.
Sep 06, 2008 | Brother MFC 7420 All-In-One Laser Printer
Reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Jan 06, 2008 | Brother MFC-8860DN Printer
59 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
