Question about Vizio M3D651SV 65" Class LED Smart TV
How do I take the captions off my tv I pressed the cc button and didn't work and under the menu it doesn't give me that option
  • Vizio Master
  • 3,904 Answers
The closed caption may not be activated on your tv but it could be active on your cable/dish box. Use that remote and find the CC button. If that is the remote that you are using then find the original remote for the TV and turn it off with that one. Sometimes the remote has it named TEXT instead of CC.
Posted on Dec 05, 2014
How to turn off subtitles on a hitachi tv
This may depend on the signal source of the TV. If you are watching OTA TV (or your TV is interpreting the CC from the cable or satellite signal), then use the CC button on the remote. Alternatively, depending on your exact model Hitachi TV, try using the menu to find a Tools or Options sub-menu and then turn off the CC from there. This could be under a different menu item. If you add a comment with your model number, I'll be glad to give the exact menu steps.
If you have a set-top box (cable, satellite, digital-to-analog converter box, DVD recorder), the captions may be turned on at this source. Then you will need to disable the captions from that box. With a converter box, press the CC button on the converter's remote or enter the menus for that box.
With a Dish TV set-top box, press Menu on the Dish remote, go to Properties (item 9). Click Select and then go down to Closed Caption (item 6), and press Select again. The first item in this sub-menu lets you turn on and off the captions. Press the left button and then up or down arrow followed by Select to change the setting. For other sources, check the instructions for that device or add a comment with the specific source for a solution for that device.
I hope this helps.
(the Dish CC procedure is for the box I have to deal with; I can't guarantee that updates/model changes have not changed the procedure.)
Jul 15, 2012 | Televison & Video
Closed Caption keeps coming back on
When you turn it off are you going into the setup menu to do this?? if so after it comes back on and you go back to the menu and you see it..as "on" You will need to save your settings before you exit out of the menu
Feb 17, 2008 | Televison & Video
Philips 24PT6341 closed captioning won't turn off and there is no option in menu
There must be a button marked "CC" on your TVs remote control. Press it once. It will make the closed caption windwow off.
Jun 21, 2012 | Philips 27PT6441 27" TV
Can't turn on memorex MT2012 Closed Captioning using a universal remote
You must have its original remote control, which will have 'CC; button on it. you have to press this button once to cancel the Closed Caption option. If you can acccess the Menu of the tV by your present universal remote contro,; get into TVs Menu option, surf through, come to closed capation adjust window, and cancell [OFF] the closed caption option.
Apr 08, 2012 | Televison & Video
Can't turn off closed captioning on TV
Hello
1. Get into its setup menu.
2. Press 'UP' or 'DN' button to select the "Closed Caption" option.
3. Press ' >' or "ENTER". The closed caption menu options.
Select "CC" mode to 'Off' if it is now 'ON (Press UP or DN to hilight the option you want to OFF, and then press "Enter".
Feb 11, 2012 | Dynex DX-L42-10A 42 in. LCD TV
Don't know how to activate closed caption, and cannot find instructions
What is the TV source? For some sources (set top box), you may need to turn on the captions using the menus of the box.
Assuming you are using a source that gives captions that the TV can interpret, if you have the Proscan 26LA30Q remote, press the CC button to toggle through the caption options. Another route is to press Menu (either on the remote or the buttons on the side of the TV) then select the Feature submenu with the left/right arrows. Press Enter (menu when you use the buttons on the TV) then navigate to the Digital Closed Captions option. Here you can set the captions to on and adjust the size, style and color of the captions when they appear on-screen.
If you are using a universal remote, try the CC button. If it doesn't work, try another code for the Proscan TV on the remote. There are some codes that may not control all of the functions of the TV with the remote.
Crutchfield has the manual for the TV on the product site: http://www.crutchfield.com/S-Kaec3gBqVtM/p_68326LA30Q/Proscan-26LA30Q.html . The direct link is http://a248.e.akamai.net/pix.crutchfield.com/Manuals/683/68326LA30Q.PDF .
I hope this helps
Aug 18, 2011 | Proscan 26LA30Q 26 in. LCD Television
How do I remove the printing of the conversations on my tv
It will depend on the TV and the source. If you are using the tuner in the TV, look for a CC button on your remote. This should let you toggle the captioning off. (Some TVs have options of CC On, CC On when Muted, and CC Off.)
On some TVs this can also be reached through the On Screen Menu (press Menu on the TV or remote). Then look for a Setup, Settings or Options menu. Then look for Captions and turn them off.
If you are using a universal remote that has a Closed Caption button that doesn't work for your device, it could be a code mismatch. Check if there are other codes for your device manufacturer and try using them to get all the features of the TV controlled by the remote.
If your source is a set top box (satellite, DVD player, cable), then you may need to disable the captions through the settings of the box. (Again try the menus.)
There is an exception. If the source is one that is using Open Captions, then the Captions will remain on.
Please add a comment with the TV and source for a more specific way to turn off the captions for your system.
I hope this helps.
Aug 15, 2011 | Televison & Video
How the **** do i take off captions off my philips tv
Hello
Press CC button on the remote to display the current Closed Caption Setting.
Press the CC button Repeatedly to choose from the four Closed Caption Options [CC OFF,CC 1, CC 2, CC MUTE].
When finished press the Status/Exit button to remove the Menu from the Tv screen
From the above said four Caption options just select as your need. OK.
Nov 12, 2010 | Philips 32PT6441/37 32" TV
Cannot turn CC ON/OFF via remotes
Try this combination.
1) Start with the cable box turned on and TV on tuned to the cable box.
2) Press the POWER button for the cable box and then quickly press the MENU button.
3) This should bring up the user setting menu. Use the arrow keys on remote to go to Closed Caption and press right arrow button this should bring up the closed caption menu.
4) Press the OK button and this should either turn CC on or off.
5) Once Closed Caption is turned off press LEFT ARROW button to return to User Settings Menu.
6) Press the POWER button to turn the Cable box back on and the Closed Caption should be gone....
Good Luck.....
Jan 17, 2010 | Vizio VW32L 32 in. LCD HDTV
LG LCD TV Model 42LB5D. The closed caption option is greyed out. Help please.
redrover 11-13-2007, 01:03 PM Well I stumbled onto the solution to my problem, finally, but no thanks to any of the tech at my cable
Nov 13, 2007 | LG 37LP1D 37 in. LCD Television
Vizio M3D651SV 65" Class LED Smart TV Logo
95 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
