Question about Whirlpool duet Washing Machines
Ok im getting th f21 error on my duet sport I have read all the post and followed it to the letter. There wasn't anything blocking my filter and the impeller turns fine but I'm still getting this message. Any ideas?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 70 Answers
Sadly u may have a bad control board? its not communicating with the hardware of the appliance? not sure what else it may be?
Posted on Dec 05, 2014
SOURCE: Duet sport with an error code
I have a Whirlpool Duet and the washed load would stop and give me a F-21 error. I tipped the washer back a little and removed the three screws on the front bottom cover. There is a large white drain value, turn and open the drain (make sure you have a pan or something to catch the water and any junk inside) to remove the water. Attached to the drain is a black hose with an expanded section, squeeze this to find any loose socks, under clothes etc. I acually found three socks, a battery, a pair of tweezers and a few coins. This F-21 error is a drainage problem, don't call the repair center and pay for a serviceman, it is easy to fix yourself. I hope this helps!!
Posted on Apr 28, 2008
SOURCE: Whirlpool Duet Sport Front loading washer and dryer with error code
An easy Fix. Take off the kick panel, 3 screws 1/4 inch. Make sure you have a shop vac ready or a lot of towels as there will be some water. Always disconnect power to washer and dryer, and turn off water to washer. Your filter most likely is clogged with change, screws, lint, and other household stuff that we leave in our pockets! Unscrew the cap on the filter, easy to find, since you have the kick panel off! Take everything out of the filter. Take your shop vac and **** out remaining stuff in hose. Also, **** up any water that has leaked in and around the washer. Screw the cap back on hand tight, put the kick panel back on, turn your water back on, plug it in and there you go! Maybe takes an hour and saves you a repair bill. If you are not comfortable with this procedure then call a maintenance person that is qualified. 775f844.jpg
Posted on Jan 06, 2009
  • 662 Answers
SOURCE: Duet Sport Whirlpool front loading washer is
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
Posted on May 17, 2010
Macmarkus
  • 2605 Answers
SOURCE: Whirlpool Duet washer gives F21 error at
Hello, Welcome to FixYa. Yes the "F21" on your model of washer indicates the machine has detected a fault or obstruction in the drain process, hence it cannot spin correctly either. Chances are the pump is being obstructed by debris or some other foreign object. Here`s how to check it and clean it... **Turn off the breaker at the service panel or unplug the washer from the wall socket...safety first** 1) locate the screws in front at the very bottom of the panel below the door and pull the panel down and forward until it is off. They will be either 1/4" hex head or #20 torx head screws. 2) You will immediately see the drain pump in front of you with a large removeable filter. ( this is were a shop vac and towels come in handy, also the use of the removed panel as a catch pan is beneficial...but you may still get wet ) 3) Turn it counter-clockwise should allow you to remove it and inspect it and clean it out. Make a good thorough inspection inside the pump as well not just the removeable filter. 4) Re-insert the filter and before placing the panel back run a test rinse/drain cycle to inspect for leaks and to varify the unit drains and spins now. ( If the problem still exist`s the "F21" will re-appear. If so you`ll need to check the drain hose, hose from pump to tub for other obstructions ). 5) If all appears OK after your efforts, well your efforts paid off...pat yourself on the back. You just saved yourself potentially a hundred bucks ! Now You should be good to go. Re-attach the lower panel and you`re back in business. Let me know how it goes and if you require further assistance. Thanks for choosing FixYa. Please take a moment to rate the solution provided for you here today. Good luck. macmarkus :)
Posted on Aug 05, 2010
tunde007
  • 2382 Answers
SOURCE: F21 clogged line on a new Duet Sport less than a
Hi, regarding the F21 Error on the Front End Whirlpool Duet, I was able to resolve the problem with the instructions from here, just want to stress cleaning out the filter by removing the front panel. Very easy and the error code is now gone. (screws are underneath front panel at bottom, remove stacker drawer for easy access, remove screws, pull panel off, remove the filter cap, turn to the left and pull out-that's where you will locate the clog.
Posted on Oct 02, 2010
F21 clogged line on a new Duet Sport less than a year old???
Oct 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool washer duet sport is not draining water out and displays error code f-21
Hi
Thanks for using FixYa. Error F21 indicates long drain, this error occurs when the drain time exceeds 8 minutes. To resolve this check the drain hose and make sure it is not kinked with any foreign particles; also clean the drain pump filter for any clogs. Also check if the pump is running fine. If still the issue is not resolved after all this then you might have to replace the pump. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does f21 on washer mean?
Hi, this advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F21” error code.
“F21” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
  1. First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
  2. Check the drain hose to make sure it is not kinked or clogged.
  3. Check the electrical connections to the pump and ensure the pump is running.
  4. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Take care
May 31, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Duet GHW9150P Front Load Washer: Whirlpool Duet Washer - Error F21 (What is this) ...
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out. Door locked? Press "end of cycle" for 3 seconds, wait for 2 minutes & try the door. F-21 filter blocked.
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: how to fix a f error...
F does not come alone, it has to be followed by a number or letter. F means 'fault'. For instance F21:
I get an F21 error reading on my Duet washer. Which means it has a drain problem. But when I turned it to rinse/drain to get the water out of the clothes, it spins and drains just fine. I am wondering...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Dec 15, 2009 | Whirlpool GHW9400 Duet Washer
Washer not spinning/draining and it's showing me a code (F21)
clean the drain -here are a few postings i used to fix my Whirlpool ****-eettt (Duet)10 minutes ago. google whirlpool duet there is a 5 min video by jim that walks through the whole gig. 3 screws a twist & you're done your correct so lets fix it...take bottom acess panel of ..theres three screws,,,ok ready clean that pump filter it right in front of you twist it out always unplug first unplugged good,,now while your down there with the filter out,,check booth black hose to make sure theres no coin or hair clips while you have it open,,onthejob
Mar 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport HT front load washer keeps having F21 Error
remove the lower access panel (3 screws along the bottom of unit) behind htere you will see the pump and an access to clean the pump filter, probably filled with assorted debris. be aware when you unscrew there will be water behind it,
Nov 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Tinabell, I believe the code is the same for sport on the duets. Long drain. Usually I find this to be a clogged filter but sometimes the pump itself is bad. You should be able to find your tech sheet at http://www.servicematters.com/ or on the bottom of your machine. Click on technical reference, accept the terms, then technical library and enter your model number. You should be able to come up with the error codes. Catriver.
Jan 13, 2008 | Washing Machines
Washing Machines Logo
32 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
