Question about Century New Magnetek Pool Spa Pump Motor 1081 15 hp
Turned off the motor
Jun 14, 2015 | Hoover Washing Machines
on Mar 13, 2011 | Garden
Mar 18, 2014 | Siemens Dishwashers
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. If the belt is worn out or is loose or damaged then it will not turn the drum but make noise. so this can be an issue in your case. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Jul 13, 2011 | LG WM0642H Front Load
May 20, 2011 | Dishwashers
Jan 07, 2010 | Fellowes Manufacturing C220 (Strip-Cut)...
Dec 21, 2009 | Washing Machines
May 29, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Apr 01, 2009 | Frigidaire Dishwashers
123 people viewed this question
