Question about Hvac Direct Gas Furnace Gmh80704bna 80% 70k Btu Upflow
What to do replaced lighter ignition switch does not light
Replaced ignition switch does not light burners
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,449 Answers
Bad earth or blown bulb or blown fuse.
Posted on Dec 04, 2014
Can not get two burners to light
Before you do anything else, take a pipe cleaner or a special brush on a flexible shaft that they sell in home stores and clean out the venturi tubes on all burners. Tiny spiders like to build nests in these tubes which can keep burners from working even when you try to start them with a handheld lighter. That can be dangerous, because it will build up the level of gas in the grill.
If that doesn't solve your problem, and your grill has electronic ignition with only one igniter for all the burners, then the transfer channel at the back of the burners is blocked with soot or corroded, and the flame from the burner with the igniter can't travel to the others. Clean or repair the channel.
Some grills have an igniter on each burner. In that case the burners that don't light may have broken or blocked igniters that you'll have to replace or clean. In the meantime, use one of those butane fireplace lighters to light the balky burners.
Nov 01, 2014 | Grilling
Gas burner will not light
will burner light with a lighter "bic".
if you can switch positions with another burner to see if the burner is at fault.
There are also different starters that ignite the burners. If you have 4 of these one could be unhooked or defective.
In the warehouse insects could make a web or cocoon inside the burner. They are easy to clean.
I hope this helps.
Mar 18, 2013 | GE Kitchen Ranges
I have a Whirlpool Accubake 465 oven, model number SF368LEPB. When I select "Bake" and then press "Start", there is a sound of the flow of gas and the ignitor attempts to spark. I can...
Hello Kevin,
That sounds to me like a cracked bake igniter. One way to tell if its the igniter and but a problem with the burner is use bbq lighter and try to light the bake burner, If it does light using the bbq lighter it will be the igniter. Also ya could remove the igniter from the bake burner and see if their is a visible crack in it.
If it does turn out the igniter needs to be replaced,the part number is 9758079 thepart can be picked up from yoor local appliance parts store or online at;
apdepot.com
repairclinic.com
searspartsdirect.com
apwagner.com
midwestapplianceparts.com
Gene
Aug 19, 2011 | Kitchen Ranges
GE range electric lighter will not stop lighting
Is your range gas with electric ignition? And are the igniters constantly clicking with the burners off? If so it sounds like you may have spilled liquids into the electric switches at the burner control knobs causing them to short. This is a common problem and the best fix is to unplug the range from the power and let the range dry out for 24 to 48 hours. Sometimes using a hairdryer can speed up the drying process. If you did not spill or get any liquids into the burner ignition switches then there is a posibillity that one of the switches is defective. You would need to test each igniter switch with a continuity tester and the burner knobs in the off position(power unplugged for safety) to see which switch is defective and replace that switch.
Mar 22, 2010 | GE Kitchen Ranges
I get an ignite but my burners wont light. I have
did you try replacing the battery? it is inside the ignitor button.
Aug 04, 2009 | Ducane 30400042 (LP)
Oven will not light. burner won't even light if I try lighting it with a lighter. I thought maybe it was the igniter but am wondering if the burners go out on these. This is a problem that has been getting...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
fdfsd
Jun 29, 2009 | Magic Chef 9122 Gas Single Oven
Kitchenaid gas stove left back burner won't light. hear clicking
I have one of the kitchenaide gas ranges and if the burner cap is not set on PERFECTLY straight, the gas doesn't flow properly and will not ignite. Try lifting and replacing the cap back down on the burner and see if this solves it.
Mar 05, 2009 | KitchenAid Kitchen Ranges
Kenmore gas stove top switch harness replacement instructions
for the 4 burner if u not use coz of no igniter,use matches or lighter every time to use,if not turn the burner remove the knob & try to use hammer slowly at the top of the gas valve mostly the problem is stockcup,use oil b4 u try to turn.for the harness wire call the contact service center to buy a harness wire to replace the parts,but it so easily to replace the wire try to open the unit to see the wire size,color then gi to hardware to buy a wire same as in ur unit.tnx gerbee
Jan 27, 2009 | Dacor Preference SGM466 Gas Cooktop
Right front burner won't burn. Oven will not ignite.
Try lighting it with a bbq lighter. If no gas, then replace the valve. If it lights, replace the igniter. Hope this helps!
Dec 31, 2008 | Kitchen Ranges
Thermador Burners Won't Light
have you replaced the igniter the same as the specs needed to be installed..?
Jun 20, 2008 | Kitchen Ranges
Hvac Direct Gas Furnace Gmh80704bna 80% 70k Btu Upflow Logo
43 people viewed this question
Top Hvac Direct Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Hvac Direct Heating and Cooling Expert? Answer questions, earn points and help others
