Question about Microwave Ovens
I'm installing a GE spacemaker JVM130K but don't have the mounting templates where can I find them?
  • 937 Answers
I checked the manual and it did not provide one or mounting dimensions. If you already have the unit, reverse engineer a template... You can either do it by holding paper to the sides and marking the mounting points, or simply take the measurements for the mounting points from a good known reference - such as the front if you are looking to moun the front flush to the face of the cabinets.
Posted on Dec 04, 2014
2 Suggested Answers
SOURCE: I need an installation guide for a General Electric Model JVM130K
I have the same model and the instructions at this site on how to remove it will help you. The owner's manual is useless. Good luck!
Posted on Dec 24, 2008
How do I remove a GE spacemaker model jvm130k
I assume that it's mounted below a cabinet on the mounts supplied with the microwave. If that's the case, there are four buttons on the top of the microwave in each corner. They fit into holes in the mount then slide into depressions which hold the unit in place under the cabinet.
To release the microwave push up from the bottom then try sliding it backward first. If you are able to move it, carefully slide the whole unit until it drops through the holes and is clear of the mounts.
Be very careful because the unit is pretty heavy and you'll get its full weight when it drops through the holes.
If it doesn't move when you try to slide it rearward, try sliding it sideways in either direction. The direction you must slide it in is determined by how the mounts were installed but it should slide out fairly easily once you know which way to move it.
Dec 04, 2014 | Microwave Ovens
I have a GE OTR microwave JVM1460 spacesaver xl1400. I am trying to take it down. I unscrewed the two top bolts from inside the cabinet. I thought it should just swing down on the mounting strip, b
remove-ge-spacemaker-800x800.jpgRemove a GE Spacemaker
The GE Spacemaker series of microwave ovens are designed to be installed above an oven range, freeing up counter space in your kitchen. Some of these Spacemaker models are connected to an outside venting system to carry kitchen vapor and odors outside. Other Spacemaker models utilize a ductless system to do this. Removing a GE Spacemaker microwave oven isn't a difficult task, but, because of the size of some of the oven models, it is a two-man operation. Have a question? Get an answer from an appliance repair specialist now!
Other People Are Reading
Things You'll Need
  • Assistant
  • Sharp knife
  • Phillips screwdriver
Instructions
    • 1 Open the cabinet above where the Spacemaker microwave oven is installed. If you see a vent in the cabinet leading to the Spacemaker oven below, your Spacemaker is vented. This vent needs to be disconnected before continuing with removal. Disconnect the vent either by loosening the duct clamps or by cutting the duct tape away with a sharp knife. Pull the vent out of the top of the oven.
    • 2 Have an assistant support the oven from below. Loosen the mounting screws connected to the Spacemaker through the cabinet bottom. Loosen the screws by turning counterclockwise with the Phillips screwdriver.
    • 3 Unplug the Spacemaker from the socket in the cabinet.
    • 4 Continue loosening the screws while your assistant holds the oven in place. Once the screws are removed, have your assistant slowly lower the Spacemaker down by lowering the front face at a 45-degree angle.
    • 5 Feed the power cable for the Spacemaker through the hole in the bottom in the supporting cabinet.
    • 6 Help your assistant slowly pull the Spacemaker forward and out of the mounting brackets on the rear wall. Once the Spacemaker is cleared of the mounting cabinet and rear wall, set it down.
    • 7 Remove the mounting bracket from the rear wall by loosening the screws.
Read more : http://www.ehow.com/how_7344250_remove-ge-spacemaker.html
Nov 26, 2014 | GE Microwave Ovens
How do I install a GE Spacemaker Microwave oven?
It depends on where you want to install it. Thet usually go below the cabinetts which are over the oven.
IOt should have come with a template so that you can drill holes into the bottom of the cabinett so the holes you drill will match up with the holes in the microwave. Once done then there should be screws and fiber washers.
Good luck,
Marty
Jun 12, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Just need to know the cubic inches for the JVM130K model
Look for a label posted inside or (unfortunately) on the back or go to the GE website and input the unit and that should give you the information
Aug 31, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I need Template and installation instructions for GE Spacesaver Microwave Model JVM1630CJ02, built Jan 2005. Thank you.
You can download GE owner's manuals and installation instructions here.
If the installation instructions do not have the template, you can also find helpful exploded view diagrams and order needed parts by entering your full model number here.
Apr 29, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Need installation instructions for otr microwave please
I just pulled my ge spacemaker xl1800 out. The mounting plate installs on the wall and two 4-6 inch bolts go through the cabinet above and into the top-front of the unit. The two top mounting holes are about 8 1/2 in. from the back of the unit and about 1 1/4 in from the side. If you don't have the mounting bracket that comes with the unit, you will have to use a 2x4 or similar to support the back & bottom of the unit.
Apr 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Venting, nonventing
You should be able to find your owner's / installation manual here.
That will tell you.
OR you can contact GE customer service here.
They should even be able to recommend a compatible model or maybe even a "drop-in" replacement.
Dec 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Dec 11, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave - No lights, No fan, all else works great!
sounds like you have a bad control board.. part# WB27X801 this is located behind the touch pad..
Apr 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
129 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
