Question about JVC Televison & Video
My JVC LT-22DE72 TV quit working after viewing a dvd. All that I can get is the box in the lower right corner with HDMI Cable. What is wrong with the TV?
Unplugging overnight, used the reset, tried the auto setup
    Renaissance:
    An user who is expert in 3 categories / brands.
  • JVC Master
  • 1,449 Answers
Go to setting and select port one.
Posted on Dec 05, 2014
Need assistance repairing JVC LT-22DE72 LCD TV/DVD combo
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size
Oct 06, 2016 | JVC Televison & Video
I forget hoe to connect my jvc dvd digital theater to my television. I own a Philips 32" lcd tv. How do I do this. I also have a digital box that it has to go through.
can you post me the model of your dvd theater, I can look up the instructions for you. also the model of your philips tv would be helpful so I can find out what connections both devices have, for best results.
Sep 21, 2008 | JVC Televison & Video
Can someone please help me get my laptop working through HDMI cable onto TV on a sony VAIO VGN-FW23G. I need to know the process to do this
1. Check the computer for changing output (some computers use <F5>, <F8>, depending on which brand they are. I believe Sony uses <Function><F7> or <F7>).
2. Check what channel the HDMI port is on (e.g. AV1, HDMI1, HDMI2, etc.) - you need to know this if your TV doesn't automatically switch to the new input.
3. Plug the HDMI cable into the TV HDMI cable-in port.
4. Plug the HDMI cable into the laptop HDMI cable-out port.
5. Turn on the computer.
6. Press the <Function><F7> simultaneously ONCE. The screen should flicker and show up on TV.
7. Sometimes you may have to go to "Display Preferences" and select Dual Monitors or external monitor if your computer doesn't do it automatically. Repeat Step 6 after.
** You may have to adjust Display Resolution to 1024 x 768 or lower in order for the TV to work. After it works at a lower display (800 x 600, for example), you can adjust the resolution to the maximum the TV can accept.
Oct 26, 2012 | Fujitsu Computers & Internet
My HDMI connections aren't working. How do I
Tries unplug and replug the tv back about an hour.Let the tv reset itself back to factory setting.Now go in ur menu go to PICTURE.Go down the menu pick reset,that to reset all the funsctions in the Tuner board.This process should get all the HDMI Hub. working again,not than ur Tuner board have all the HDMI Hub. are shorted and dead.
Apr 27, 2010 | JVC LT46FN97 46 in TV
My system doesn't work when i'm watching t.v.? It only works while playing dvd's..
"Doesn't work". Do you mean no TV audio at the TV? No TV audio from the receiver? No Video? Both?
MOST IMPORTANT: Is this a new setup or did the problem appear after working for awhile?
I'm going to guess it's a new installation with no audio while watching TV.
Generally, most TV watching originates with a cable box. There will probably be some sort of analog or digital audio output on the cable box. Connect it to the Aux In or Optical Digital In on the receiver as applicable. Select the appropriate input when watching TV.
The video from the cable box will depend on the box, too, but it appears this unit will only accept Composite or S-Video In. If your cable box has a higher quality connection (Component or HDMI), I'd run it directly to the TV for the best video but still use the digital audio feed to the JVC. Let the specialized parts of the chain deal with their specialties - audio or video.
Of course, if your TV has only one HDMI, you will have to choose which source uses it. HDTV would get my vote for it as it needs the best conenction for maximum enjoyment. If the TV has Component (3-wire) Video inputs, I'd use that from the receiver for DVD viewing. I have both myself and see no difference with DVD video between HDMI and component video.
If you lack the manual that speaks to all of this, go to retrevo.com, register and download it for free. It’s a combination JVC TH-C40 C50 and C60 manual.
Feb 02, 2010 | JVC TH-C50 System
I have a JVC LT-37X776, I have bought a blu ray player and it does not seem to recognise it on HDMI channel works through component but kind of defeats the point of buying a hd players if you are not...
go back to the shop wher u got ur HDMI cable and find out if this is the right one for ur player and tv......
not all cables are the same......even they look like it and work on different components
Nov 20, 2009 | Televison & Video
JVC LCD TV (LT-42X688) input panel not working!
1. This TV has setting for the HDMI input that allows you to select the HDMI Audio or Analog(red/white wire) audio. Make sure this is correct
2. Most cable boxes are DVI not HDMI. If DVI then you actually do need to use those Red/white cables. If HDMI, refer back to #1.
3. The cable box has a setting to select the Audio output, HDMI (digital) or Analog(red/white cables). Just like #1, this has to be set.
4. Contact your cable company to help you set up the box correctly. JVC can probably help you check the TV
Mar 05, 2009 | JVC LT-42X688 42 in. LCD HDTV
JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Jan 12, 2009 | JVC AV-36D303 36" TV
Setting up Unit
I called the JVC tech service rep. I went from the Cable box to the JVC unit with a Digital Optical Cable, from dvd/vcr player to jvc unit with a Composite Cable and Audio Cables. From cable box to tv with hdmi cable and from jvc unit to tv with componet cables and cable box to dvd/vcr with Audio/ Video and S-Video cables. This allows me to have the cable TV access and Surround sound in all mode. I have HD and Digital surround sound in three diiferent modes. Everything is working great.
Thanks for the opportunity for help just the same.
Sincerely, cthomas249
Sep 25, 2008 | JVC THD-50 System
Televison & Video Logo
57 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
