How do I Get an acces code - Televison & Video
  • 937 Answers
All for one, RCA, etc universal remote manufacturers have web pages and instructions for their various remotes that will guide you through the process.
Posted on Dec 04, 2014
Skoda fabia 04 plate ive replaced after market stereo with the original skoda symphony one i put the code in and it works however everytime i restart the var it goes into safe mode
You may have the 'backup' supply line switched with the ACC/IGN supply line.Backup has permanent 12V supply. ACC line only have 12v after you turn the key to position 1 or ACC.
Jul 20, 2014 | Cars & Trucks
Can't get acces to 6 code from epix for ps3
what code i have that game u don't need a code
Jul 24, 2013 | Video Game Consoles & Games
How do I get the check engine codes? 2003 Durango
There's two ways to retrieve the code. 1. Put the key in the ignition and turn the key to the "ACC" position, then back to "Off", then ACC, and Off, then ACC. (Off, ACC, Off, ACC, Off, ACC) You don't have to do it fast, just hold each position for about 1 second. On the final "ACC" position, the trouble code should flash in the digital odometer. (P#####) When you have the code, you can Google it and you'll see what the code means. 2. Use your scan tool (Or use Autozone's) and plug into the OBDII port under the dashboard and pull the code. They should have a book that tells you what the code means.
Oct 23, 2010 | 2003 Dodge Durango
I lost the manual for Schlage FE595-CAM-ACC and I do not know How to change the code for Schlage FE595-CAM-ACC . Are there any downloadable instructions for it online?
Go to this page for downloadable instructions and videos:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Oct 15, 2010 | Schlage FE595-CAM-ACC FE595-CAM-716-ACC...
2000 Plymouth Voyager OBD II light came on and stays on. What could be the cause?
From http://www.allpar.com/fix/codes.html :
  • On most cars, the codes will read out if the engine light is on - all you have to do is put the key into the RUN position.
  • Normally, to get codes, you put the key on OFF and then rapidly do OFF-ON-OFF-ON-OFF-ON (on some cars you have to do four or five, not three, OFF-ON cycles). On our test 2002 car, the key did not go back to unlock, so it was ACC-ON-ACC-ON-ACC-ON.
  • The codes are usually the same for Chryslers.
    http://www.ptcruizer.com/computer-codes.html
    Dec 07, 2009 | 2002 Dodge Grand Caravan
    What do it do to fix ''maintenance required Code: CA''
    The service acces code C-0-0-C,or C - interupt key -0-interupt key.Acces the list of commands maintenance preset counter setting and set to a new value,or maintenance counter clear.
    Aug 01, 2009 | Sharp Office Equipment & Supplies
    4 digit acces code
    First, enter the tech rep mode:
    moz-screenshot.jpgPress the Utility key, then the meter count button on the touchpad.
    Enter "Stop - 0 - 0 - Stop - 0 - 1" on the keypad. You will enter the tech rep mode.
    Select "Administrator # Input." Note this number, or change it to something you can remember.
    Now, go back to the Utility screen and select "Admin. Management." Enter the code you just learned, select "Copy Track Mode," and change it to "Off." Exit the mode and you're good to go.
    Alternatively, you can select "Copy Track Data," and note the access codes (or enter new ones).
    Nov 26, 2008 | Konica Minolta DiALTA Di200 Copier
    PT Cruiser radio
    If you have the right code for radio, you just be waiting (acc on) so long time that you can enter the code.
    If you turn acc "off" the counter is starts at beginning in next time when you turn acc "on".
    I had once same problem, so I took the radio from car, connected to 12V power supply over night. Next morning I enter code and radio was ok.
    Aug 13, 2008 | 2001 Chrysler PT Cruiser
    Televison & Video Logo
    Top Televison & Video Experts
