Question about Maytag MSD2542VE Side by Side Refrigerator
The 2 doors on my Maytag SXS aren't even in the front when they close. The refig side sticks out. The doors are otherwise level and even in all respects. I adjusted top & bottom hin
Adjusted top & bottom hinges on refrigerator door
  • Maytag Master
  • 744 Answers
Hello Joe;
My name is Peter. I am a retired field service refrigeration technician.
This was your first time setting the gap between the doors. So, I will share with you the various ways to adjust the doors gap.
1.) On the bottom of some doors there are adjustment screws for pitching the door left or right to set the gap. This was a good design idea, but there is not locking nut to hold the setting. Opening and closing the door will remove the setting. So, if you have these adjust screws, we will forget them.
2.) Lets try this: Adjust the front leveling bolts. Loosen the top of the door hinges. If the gap is smaller at the top, lower the leveling bolt up on the left hand side. Turn the bolt counter clockwise to raise. Pound on the doors to free them to adjust. If the gap is smaller on the bottom, on the right jacking screw, raise the jack bolt by turning the jack bolt clockwise. Once again, pound on the door to free for the adjustment. Then tighten to top door hinges.
3.) OK, This did not set the gap. The gap between the door is different depending on the model. Determine the gap which you would like to set. Using something solid like pieces of wood (do not use cardboard it will crush), loosen the top hinges, evenly space the wedges and tape them to the door. Now tighten the top hinges and remove the wedges.
4.) Ok, This did not set the gap. Look on the bottom of the door at the hinge. You have a matching set of grommets. These grommets interlock when the doors close to keep the doors closed. These are high wear components. The doors rest on these components. One grommet set may be more warn than the other affecting the door gap
Posted on Dec 05, 2014
Testimonial: "Thank you, Peter. You went to a lot of trouble and gave a very detailed & clear explanation, however, the gap between the doors is not the problem. I guess I wasn't clear. The problem is, when both doors are shut, the door on the refer side sticks out slightly, meaning it doesn't close as tightly (I guess), although it seals. The seal just isn't as compressed as it is on the freezer side. I know how to adjust the gap, level the doors, and raise the front a tad to make the doors close better, so none of those are the problem. You did mention the black rubber cams on the bottom hinge, which I noticed when I had the hinge off. I lubricated that, as it looked dry to me. But you think it may be worn, and not holding the door as tightly as when the machine was new? I can certainly order new cams & put those in, to see if that helps. There are 2-upper & lower, though I suspect they are identical, just one is upside-down. Why don't they make these out of neoprene or something more durable?"
Door not closing
The fridge should be slightly high in the front not level.
Jan 06, 2014 | Maytag MSD2732GR Side by Side Refrigerator
When I close my side x side frig the freezer door pops open
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Oct 17, 2012 | Kenmore Side by Side Refrigerator
Freezer door does'nt shut all the way
If you notice one side of your Maytag side-by-side refrigerator is significantly higher than the other, you might want to raise or lower one of the doors. The refrigerator door is configured at the factory to be slightly higher than the freezer door. The weight of items on the door shelves sometimes cause the doors to sag slightly inward. Making a small adjustment to the freezer door leveling screws will correct minor amounts of sagging.
Things You'll Need3/8-inch hex head screwdriver 1
Position the refrigerator in the place you plan to keep it, and make sure the refrigerator is level front to back and side to side with a spirit level.
  • 2 Remove the base grille, located below the doors, by pulling from the sides. The leveling screws will be visible when the grille is removed.
  • Read more: How to Adjust the Maytag Freezer Door ' eHow.com http://www.ehow.com/how_12111048_adjust-maytag-freezer-door.html#ixzz1txsYiGQa
    Read more: How to Adjust the Maytag Freezer Door ' eHow.com http://www.ehow.com/how_12111048_adjust-maytag-freezer-door.html#ixzz1txrg7UOa
    May 04, 2012 | Maytag MFI2568AE Side by Side French Door...
    Our maytag bottom freezer was left open on a crack and it thawed and then froze up... We emptied it and shut it down to thaw out. we dried it too, but the freezer is hard opening and closing . any...
    HI,
    The rails got water in them and froze. The only way to correct this is to remove them, allow to dry completely, like 1 or 2 days. Re install them and it should be fine. But the down side it the door won't stay closed during this process. You can order new rails but your rails aren't defective. It your option to elect which one of these you wish to do. If you are under warranty, have them replaced with new ones and keep the old ones.
    I hope this helps
    Aug 17, 2011 | Maytag Refrigerators
    I have a GE side by side. The freezer door will not stay sealed or closed anymore. I have to tape it shut. What can I do?
    make sure unit is level side to side and front to back if still problem check door seals first for and ice build up, ripped or debris if good how much product on door is something sticking out if all good--than need to adjust hinges with help loosen top hinge screws and with some holding door shut loosen lower hinge with door level and closed retighten door hinges try door if still problem readjust
    Feb 01, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
    Latch Hooks Not Working
    This is a VERY common problem, and the fix can sometimes involve replacing the door.
    The following site should have the latch/gasket assembly: http://www.repairclinic.com
    AFAIK, the top latch can only be replaced with the entire door gasket assembly, but it's not too difficult to do.
    A google search on 'GE refrigerator latch' will find you thousands of other (former) GE customers who have had this problem.
    Oct 23, 2009 | Refrigerators
    Frozen code
    did you change circuit board ???? youll need to reprogram the refig, there should be a paper that came with the new part( if indeed youdid cahngeit) if not there should be underthe right front corner of refig tapedup under behind the toe grill a tech sheet in which they should explain "programming your refrig"
    Jan 26, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
    Refrigerator door not closing tightly
    HI. thanks for your question. sometimes you put a lot of heavy jars in the door shelves . so i would raise the front of the fridge to help it close better. thanks
    Oct 15, 2008 | GE Monogram ZISx420DR 42-inch Side by Side...
    Leveling refrigerator
    you might lower the front ones to get it level thats the only sloution i can come up with
    Aug 04, 2008 | Maytag MSD2656G Side by Side Refrigerator
    Freezer door pops open.
    normal operation actually, gaskets are designed to seal door closed not to hold them closed, first off check the items on the shelves make sure nothing stick to far out preventing good closing.next the refrig should be tilted slightly back. to aid in the doors swinging closed( the should close automatically form 45 degrees.)ok for them to "pop" open so long as they close back shut. this works on top freezers and bottomr freezer refigs, sidex sides use a differnet system of closing, if htats the case look into replacing door closures(cams) located under hte door assy
    Mar 04, 2008 | Refrigerators
    Maytag MSD2542VE Side by Side Refrigerator Logo
    154 people viewed this question
    Top Maytag Refrigerators Experts
    John Tripp
    John Tripp
    Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
