Question about Tacsew Sewing Machines
Can a Tacsew get fix if the motor lock up?
When I plug it in for the very first time my son push the petal down and it started to move but then the wheel stopped and it won't move now. Can it be fix or can I do it myself? Thank you
  • Anonymous Dec 04, 2014
    if the flywheel on the motor spins then why is the machine not moving and the motor atleast complaining i think the spool case is jammed up and the wheel the belt supplies is cracked also check the reverse lever is not set in the middle
Sounds like the spool case is jammed up
take the spool case out
check the drive belt is ok
in some you just need to remove the case
and tighten a screw on the drive sproket inside
you can find the plastic spleen holder on the drive wheel has stripped
or cracked so the motor will run and nothing moves
your post is too sparce on info
like does the motor run at all?????
usual problem is the motor runs no drive
because the drive belt is broken or a plastic is cracked
Posted on Dec 04, 2014
Testimonial: "Simeon I did lift the machine up and found out that the wheel on the motor does spin. Bit the wheel on the machine meaning the hand wheel is still lock up. The belt looks good and there is very little oil I it cause this sewing machine came from 3000 miles away."
My daughter's brand new, right out of the box Janome 2212 machine is not working. The foot pedal is not engaging the motor so the needle doesn't move up and down. The wheel is pushed in as it
Sorry, but gotta ask is it plugged in and turned on? Check before you answer. (I ask this because it happened to me, set up, ready to go, and no power. After an hour and the machine was in pieces, My son asked if i plugged it in and I snapped "YES, DUH" not seeing him twirling he plug in his hand...he informed me that you must be 10% smarter than anything you operate or eat....at which point he was happy to inform me, the machine was 11% smarter. If it is plugged in and turned on, is the plug to the foot pedal plugged all the way in? Is the machine on? If you get zero reaction, no movement or sound of any kind, the foot pedal my be faulty, it can happen. Take it back to the dealer and they should replace the entire machine or the foot pedal. Good luck and happy sewing.
Jan 10, 2013 | Janome 2212 Sewing Machine
Is there a way to slow down the motor on a Tacsew blindhemmer machie
try adjusting the foot pedal, there are jam nuts under the foot pedal
to make it go slower or faster.
Sep 27, 2012 | Tacsew T500
I have a babylock 1556 and when I press the foot petal the belt turns, but it won't move the needle up and down. I took off the back so I could watch and see what was going on. I can see the belt...
On the side of the 'knob', look for another wheel that tightens against that, so it engages, that's what it sounds like. When that second wheel is loose, it won't run, it just spins. From the photo I can find of the unit, it looks like that second wheel is below it, but I can't be certain. Let me know how you make out. Please rate and comment, thank you,
Joe
Sep 04, 2011 | Baby Lock BL1556
Husqvarna Emerald 203 sewing machine. LCD panel and light are on, 120volts to machine, petal was checked with multimeter and is ok. Front panel will not respond to any button being pushed nor will motor...
Not a solution, sorry but needing one too.
I've had this same problem, twice. The first time, a fuse was replaced and since it's under warranty, dealer paid for it.
Tomorrow I'll be picking it up for the second time, and this time I had to shell out $89!!
Does anyone know where that fuse is? Don't want to go spending more hard earned $$
Jan 03, 2011 | Husqvarna Sewing Machines
Whenever I press the petal, I can hear the machine but the needle doesn't go up and down. I try to turn the hand wheel, but it won't turn counterclockwise. I have no idea what to do!
Hi - The bobbin holder (on top) has two positions. Back (toward the wheel) and forward (toward the head). Try moving the bobbin holder forward. Moving it forward will cause the motor to engage. Good Luck.
Aug 18, 2010 | Singer 3116 Simple
How do you slow down the running speed? Is there a reestat for this machine? The motor is a Tacsew Clutch Motor, Model RM1878-1L, 1/2 hp, Sr. # HMC 04051325
Techsews are industrial sewing machines. Check out http://shop.raphaelsewing.com, especially their web blog. It's full of great information on Techsew machines.
Jan 26, 2010 | Tacsew Sewing Machines
Bernina 1630 needle will not move go side to side.
If you can pull the needle bar down manually and it springs back up, the basting clutch is stuck. By someone who knows how, it's a very easy fix. I would guide you here, but I don't know how to explain it. Plus, you have to be very careful not to damage the spring loaded clutch.
Jan 02, 2010 | Tacsew 950
REX blind stitch hemming machine motor quite hot. Locking the sti
When you tighten the belt it is a problem if it isn't adjusted right. You need to loosen the belt again. When you are pushing on the foot control the motor will begin to run. At the same time you can adjust the belt by carefully moving the motor. You will notice the motor speed will change as you do this. Stop adjusting the motor belt when you hear the motor speed at it's highest speed. Tighten down. Now, give it a try.
Feb 27, 2017 | Tacsew T500
Tacsew lu-563 sewing machine
Generally going to have to be addressing the drive motor, either substituting a lower speed clutch motor for the existing one, ie if you have 3000 rpm motor, then going to a 1725 rpm motor. Alternatively, selling the clutch motor and buying a servo motor instead, which should be available with a variable maximum speed control. The Sewquiet 4000 can select different speed ranges with the flick of a switch. If you already have a servo motor and it does not have a variable max speed, then switching the drive pulley on the servo motor to a smaller size should help
A more convoluted solution would be building a support under the table for a layshaft with different pulley sizes so that the motor could drive one pulley and then a smaller pulley on the shaft would drive the sewing machine. Not a bolt on solution but pretty cheap to do if you are good at fabricating.
Apr 07, 2008 | Tacsew Sewing Machines
Sewing Machines Logo
59 people viewed this question
Top Tacsew Sewing Machines Experts
Rommel Balcita
Shehu Pro
Shehu Pro
Nick Olsen
Are you a Tacsew Sewing Machine Expert? Answer questions, earn points and help others
