Question about Garden
How to adjust the shift leaver on a 2554 Husqvarna?
Nothing
  • 937 Answers
Here is the manual:
http://www.husqvarna.com/ddoc/HUSO/HUSO2012_NAen/HUSO2012_NAen_LGT2554_532431918R3.pdf
On some units, getting the deck adjusted properly will take care of the shift handle. There is a good procedure in the manual for deck adjustment.
Posted on Dec 04, 2014
Diagram for 25 horse 54 inch drive belt for husquvarna
PDF]OM, LGT 2554, 96043006100, 2008-12, Ride Mower
www.husqvarna.com/.../HUSO2008_USen_O0802072...
Husqvarna GroupLGT2554. Owner's Manual / 96043006100 / 2008-12. 03002 ..... mower blade drive belts in the Service and Adjustments sec tion of this manual. Verify that the .
Aug 25, 2015 | Garden
My Husqvarna LGT 2554 deck hung up on high spot mowing. Turned off deck & mower pushed by hand. Engaged deck,started to mow, wound to stop. Belts fine. Pull up on knob to engage, you get nothing.
The engine runs but the blades do not engage? Make sure the wire connecting the electric clutch is still plugged in. If all is connected and the belt is really fine, there is a problem with either the electric clutch or PTO switch.
May 21, 2015 | Husqvarna Garden
Why does my 2554 mower bog down when going uphill?
possibly fuel filter or governor needs adjusted
May 08, 2015 | Husqvarna Garden
I have a Husqvarna 2554 lawn mower that is suppose to go 5.5 mph but only goes 3mph
Probably need to have someone adjust the linkage / cable for the shifter. Sounds like it may not be going into the highest gear available.
Dec 04, 2014 | Husqvarna Garden
Can't find the fuse on a Husqvarna 2554
It should be located under the hood around by the r/h side of the duel tank
Jun 09, 2013 | Garden
Reverse has got real slow, forward is slowing down to.
yea i know i did the trick i bought 2554 huq i have a lever shift i cut the platic on the reverse tp make it longer and it go much faster. now for floor pedal need make a bracket higher on pedal should make go down further and faster too.
Jul 30, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
More pronounced when cold. Shifts hard and winds out before shifting. Ist shift at approx. 35mph, with second shift at approx. 45mph, 3rd shift almost immediate after second. Is the point of shifting...
I would check your kick down leaver on the transmission. Make sure it is working freely. Sometimes the kick down leaver and the shifter leaver will bind together and cause the kick down leaver to get stuck. Sometimes when this happens you can feel hard spots in the shifter or hard spots in the gas pedel. or the gas pedel will be super easy to push. Block all the wheels front and back turn the key on. DO NOT START IT put it in drive then go under it and make sure the kick down leaver is moving freely. The reason it has to be in drive when you do this is because it may move freely in park but not when its in drive. The kick down leaver should move back and forth almost effortlessly. If it don't that is your problem. Get some WD40 lube it up and move it back and forth till it move back and forth easily. It would help to put some spray greese on it after its free to prevent it from happening again. If this is not you problem there is a band in the transmission that can cause this too. The tabs on the band where you make the adjustment on it will sometime bend apart over time causing the band to be out of adjustment. To fix this you will have to pull the pan and valve body bend the tabs back and readjust the band. Good Luck 4 thumbs up is appreciated if this helps.
Dec 02, 2010 | 1992 Dodge Dakota
It does not downshift properly. When stepping down on the shifter it goes all the way down like nothing is attached to it. Shifting up is fine.
If you find you try to shift down and then try again to go to the next gear down and it works, you will need to adjust the gear shift leaver up a little. The way the gearbox is designed won't allow the shift to run loose unless it will not select anything in which case it has broken the shifter drum = expensive. Try adjusting the shifter leaver, it sounds more likely to problem.
Nov 01, 2009 | 2007 Suzuki Boulevard
Garden Logo
51 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
