Question about Kobo eReader
I have a Kobo Touch and it is over a year old. it is asking me to charge my ereader but nothing is happening. I have changed cords, hit the reset button and all that is happening the blue and green light are flashing. It just won't charge. Have seem to have had problems with small things in the past, but I fear that this has been a faulty product from the start
Http://help.overdrive.com/customer/portal/articles/1481584-how-to-perform-a-factory-reset-on-a-kobo-ereader
here you go
try too follow this guide if no good you may need to replace the internal power cell it may be exhausted
Posted on Dec 04, 2014
My Kobo Aura is not recharging. The charging unit seems "dead". Can the charger be replaced?
it can
Kobo Aura / Aura HD compatible Advanced Rapid Wall AC Charger ...
https://www.amazon.ca/Kobo-compatible-Advanced-Rapid-Charger/.../B00GNB08JS
Gomadic Powerful High Wattage wall charger for home or travel use. Customized circuit design is based on the latest in power regulation and is tailored to the ...
Kobo Aura One Charger, BoxWave® [Wall Charger Direct] Wall Plug ...
https://www.amazon.ca/Kobo-Charger-BoxWave®-Direct-Touch/dp/B01MA3NLF8 Pwr+ 6.7 Ft 2A AC Adapter Rapid Charger for Kobo VOX eReader; Kobo Arc 7 10 HD; Kobo Touch Glo Mini Aura Hd Ebook Tablet.... ... HQRP Micro USB Charger / AC Adapter for Kobo Arc / Arc 7 / Arc 7HD / Arc 10HD / Mini / Glo / Touch / Aura / Aura HD / Vox.... ... Pwr+ 6.7 Ft 2A AC Adapter Rapid ...
Kobo eReader Glo USB Cable - Micro USB: Amazon.ca: Cell Phones ...
https://www.amazon.ca/Kobo-eReader-Glo-USB-Cable/dp/B00AXZVE48 Rating: 4.7 - ‎11 reviews
Kobo eReader Glo USB Cable - Micro USB: Amazon.ca: Cell Phones & Accessories. ... Cable for Kobo eReader Kobo Mini, Kobo Touch, Kobo Aura & Aura HD... ... Pwr+ 6.7 Ft 2A AC Adapter Rapid Charger for Kobo VOX eReader; Kobo Arc ...
Chargers & Cables - Electronics: 146 products available ' chapters ...
https://www.chapters.indigo.ca/en-ca/electronics/chargers-cables/500151-cat.html Results 1 - 24 of 146 - Shop Online at Chapters.Indigo.ca for a wide selection of chargers & cables products, 146 items available. Enjoy free shipping on orders ...
kobo aura charger Google Search
Sep 24, 2017 | Tablets & eReaders
Kobo frozen. Willl not respond to touching button
Performing a basic reset A basic reset will force your eReader to restart properly. In many cases, this is enough to restore your eReader to normal.
  1. If possible, turn off your eReader.
  2. Locate the small hole on the bottom of your eReader.
  3. Unfold a paperclip and slide an end into the hole.
  4. Press gently until you feel a click. Your eReader should restart.
Performing a factory reset If a basic reset doesn't work, you can perform a factory reset to restore your eReader to its original settings. After a factory reset, you'll have to set up and sync your eReader again.
If you perform a factory reset on your eReader, you'll:
  • Remove all books from your eReader. Any books you purchased from Kobo can be re-downloaded from the Kobo Cloud after a factory reset.
  • Lose any bookmarks and annotations you made in your books since you last synced your eReader.
  • Sign out of your account on your eReader.
  • Reset all of your settings and preferences.
  • Return your eReader to its original settings.
  1. If possible, back up any books or documents that you added to your eReader using Adobe Digital Editions, or that you manually added using your computer. You do not need to back up any books you bought from Kobo. Any books you purchased from Kobo can be re-downloaded from the Kobo Cloud after a factory reset.
  2. Go to your Home screen.
  3. Tap the ios-menu.svg Menu icon at the top of the screen.
    The Quick Settings panel will appear.
  4. Tap Settings.
  5. Tap Device information.
  6. Tap Factory Reset under Advanced.
  7. Performing a factory reset If a basic reset doesn't work, you can perform a factory reset to restore your eReader to its original settings. After a factory reset, you'll have to set up and sync your eReader again.
    4. Tap Settings.
kobo com help Resetting your Kobo Glo HD
Jun 30, 2016 | Kobo eReader
My kobo is frozen on starting sync won't turn on or off
Note: If your Kobo device has been physically damaged, it is no longer covered by Kobo's limited warranty. On a Kobo eReader, a physically damaged screen will look like it's been shattered, or you may see vertical or horizontal lines on the screen with a frozen image. If you haven't dropped or damaged your Kobo eReader, but are experiencing issues, try the steps below in the order suggested.
  • Turn your eReader off and then on again.
  • If your screen is frozen, slide the power button to the right and hold it for 10 seconds. Your eReader should turn off.
  • Turn your eReader off and charge it for at least four hours. Note: Your computer should be turned on while you are charging your Kobo eReader.
  • If your eReader isn't charging, try using a different Micro USB cable or a different USB port on your computer. Note: If your eReader's battery is completely drained it can take up to 15 minutes before it reacts to being plugged into power.
  • If you're having trouble while reading a book on your Kobo Aura H2O, Kobo Aura, Kobo Aura HD, Kobo Glo, or Kobo Mini: tap the centre of the screen to bring up the Reading Menu, tap the > Home icon to return to your Home screen, then open your book again.
  • If you're having trouble while reading a book on your Kobo Touch: press the Home button and open your book again.
  • Try a basic reset.
  • If you're still having issues, consider a factory reset.
  • If you're unable to reset your device, please contact Kobo Customer Care
Mar 14, 2015 | Kobo 6" eReader Touch Edition
Kobo plugged into computer but nothing happens when I press connect
Do you have the proper device driver installed on the computer?
:Other info I found online, but have not looked into:
Open the Hardware and Devices troubleshooter
http://windows.microsoft.com/en-us/windows7/Open-the-Hardware-and-Devices-troubleshooter
In addition you can also check if the device manufacturer have driver for the device.
For additional help, please see:
Kobo Help Forums/Frequently Asked Questions - Kobo eReader
http://kobo.zendesk.com/forums/165796-frequently-asked-questions-kobo-ereader
Need help with your Kobo eReader?
http://koboereader.com/FAQ
Feb 24, 2015 | Kobo 6" eReader Touch Edition
My Kobo glo, after charging it, went to very small print, and the words don't fit on the page. How can I reset it?
On my kobo, I have to touch the middle of the screen to get the toolbar to pop up at the bott of the screen. You should the find the usual icon.
Oct 22, 2014 | KOBO, INC Kobo Glo
My kobo wont turn charge and turn on
Broken psu connector or moethboard junk it its not cost effective to repair.
Aug 20, 2014 | Kobo Arc
Kobo help
Clean water, I hope, otherwise chances are much worse. DON'T turn it on. Pat it dry as much as possible, then completely bury it in a sealed jar of uncooked rice for maybe 3 days. After that, try turning it on. If nothing, try charging for several hours. If still nothing, sorry!
Aug 11, 2014 | Kobo 6" eReader Touch Edition
Is there a battery you can replace on the literati ereader only had sinceDec..been charged but will not turn on..hit reset did nothing?please help spent alot of money on Kobo books.
MY e-reader would not turn on either. I charged it overnight and tried the reset. I called the company and he told me that it sounds like the battery and it cannot be replaced due to the fact it is sealed. My loss! I can recover the books I bought from Kobo though.
Feb 20, 2011 | Sharper Image Literati Reader 16375680042...
Kobo eReader Logo
90 people viewed this question
Top Kobo Retail Supplies Experts
Phillip Hicks
Phillip Hicks
Patrick Tinashe...
_-__-___-_
_-__-___-_
Are you a Kobo Retail Supply Expert? Answer questions, earn points and help others
