Question about Refrigerators
I have a FrigidaireGallery Model FRS22XGCD. My freezer is NOT MAKING ICE. I do have and ice makers arm in the right position. Door water and ice does work. Do you have any ideas for me?
  • Refrigerators Master
  • 744 Answers
Hello;
My name is Peter. I am a retired field service refrigeration technician.
Ok, I am going to give you a series of things to check.
1.) Reach into the back of your ice maker. You have a fill cup and a full tube. Are they filled with ice? If so you have a frozen fill tube. You must remove the ice maker and with a hair dryer clear the tube.
To remove the ice maker:
I have a FrigidaireGallery Model FRS22XGCD.  My fr - 25307572-yj1egbw3hyxzt0qos4ym0wwk-1-0.jpg
On the left hand side there are two screws on top - loosen them. On the bottom there is one screw - remove it. There is a conduit connector in the rear - squeeze the tabs to release. Now, lift the ice maker up and pull away from the wall. If the ice maker does not lift out, loosen the top screws a little more.
2.) reach into your ice maker mold (tray) are their any ice cubes jamming the unit? Clear and lift your lever arm up and then down.
3.) Were you getting small ice cubes? And then no ice cubes? This could be a ice maker solenoid valve problem.
This component cost $165.00. You can get It for about 40% less on the internet. Part number 215197400. Purchase locally, Cost $55.00.
4.) You will need a multi-meter to check the solenoid valve. Unplug the unit. remove the bottom cover. You have a duel solenoid valve assembly. On the right bottom is your solenoid assembly. The plastic tubing running up the wall is for your ice maker. With a multi-meter set to the lowest Ohms, disconnect the two contacts on the ice maker solenoid. On the solenoid, use your meter leads on each contact. You should get a reading of '0'. if it is good. Anything other than '0' is bad.
5.) Within your ice maker you may have a bad thermostat.
This component is $62.00.
If your ice maker solenoid valve is good, rather than try to repair your ice maker, you can purchase a ice maker locally for $110.00, or go on line and purchase one for $45.00.
Your ice maker part number is FRS22XGCD0
Posted on Dec 05, 2014
    Scholar:
  • 155 Answers
I'm a bit confused by the question - are you getting ice from the door? If so, then your ice maker is working.
If the ice maker is not making ice, and the water is on to the solenoid at the refrigerator, look at the water feed going into the ice maker from the solenoid. You should be able to remove the hose going into the ice maker from the outside rear of the refrigerator. Verify the tube that goes from the pipe to the fill tray of the ice maker is open. Sometimes, water will leak through, and this tube will fill with ice, blocking water to the ice maker. On some units, you can remove the tube - if you can, remove it, and run it under some water from a faucet. The ice should eventually fall out. Put everything back together and let the ice maker cycle a few times. (Several hours) That should take care of the immediate problem. If this continues to happen, then the solenoid valve that feeds water to the ice maker is leaking and needs changed. You will know if the solenoid valve is leaking through when the pipe is off - it would be a slow, constant drip, even when the pipe is held up to the same level as the fill tube on the ice maker.
Freezer wont make ice cubes
This is not difficult to troubleshoot.
  • When the arm is up the ice maker is off
  • When the bucket is full the arm is up the maker is off.
  • If the ice maker has a on/off button in off the ice maker is off
  • If the ice maker internal heater fails the cubes will not release and the white plastic ejector arms will be rotated CCW and pressing against the ice in the tray, Normal position for ejector arms is vertical.
  • If water solenoid has failed or water supply not available the ice maker will cycle. The ice tray will be empty,(hard to see if ice tray is empty). Check and replace water fill solenoid.
  • If ice in tray and ejector arms vertical several possibilities.
    • Freezer not cold enough to trip thermostat in ice maker to initiate release cycle.
    • Check freezer temperature <10 Fahrenheit thermostat in ice maker failure
    • Ice maker motor failure,
    • Internal ice maker electrical connections rotary switch failure,
    The best way to check the operation is to manually lock the arm up into the off retention position. Wait a minimum of one hour. Open door and release arm down. Observe the operation of the ice maker. Is after a minute or so the ejector arm does not rotate then it is likely the ice maker has failed internally. If the ejector turns and no ice than you can assume either the water supply is off external from the refrigerator or more likely the water solenoid located behind the bottom back cover has failed. It is also possible that the hose that connects the solenoid to the ice maker has frozen right where it enters the freezer just above the ice maker. You should see ice built up at the entrance where the water fills the tray if this has occurred.
Ice Maker Repair
Dec 22, 2015 | GE Monogram Side by Side Refrigerator
Ice maker not working
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jul 06, 2008 | Refrigerators
Ice maker not getting water on new refrigerator
Check if the unit has a cold water dispenser that it will fill a cup. If so than problem is with Ice Maker. If not than problem is with water supply to unit.
If water to machine works make sure that the arm on the ice maker is in the down position. If it is up it will disable the ice making unit. Cycle the am a few times to insure that the switch connected to the arm has not gotten stuck in the off position.
On some ice makers there is a separate switch to disable the Ice maker usually right on the ice-maker not easily missed.
It is possible that the water feed tube into the Ice Maker has become frozen where it enters into the back of the freezer at the top. You can look through to see where the water fills into the cube tray. If ice is present it would be an indication that the feed tube has become frozen If suspected the safest way to fix would be to turn off the unit and allow for a manual defrost.
Next check the operation of the ice maker. Locate the arm in the up position prohibiting the ice maker from cycling. Wait three hours or more. Open freezer door and return the arm into the down position. After a few minutes you should observe the ice fingers rotating to release the cubes into the tray. If the fingers do not rotate I would suspect the ice maker or the connecting electrical circuit. Remember after dropping the arm the Ice Maker has to warm up to melt the ice cubes from the tray before the fingers are told to rotate,
If the fingers rotate then I would expect that the water supply solenoid has failed inside of the unit near to the location the the water supply is made. Replacing this part needs to be done by a qualified experienced technician.
Nov 15, 2015 | Refrigerators
Samsung refrig model rf26xaebp stopped making ice but i still bet water thru the door
The solonoid valve for the ice maker may be faulty or the icemaker may be froze up. Try thawing out the icemaker with a hair dryer. If thats doesn't fix the problem you may have to replace the soloniod or ice maker control. Be sure the arm above thre the ice bin is in the down position. Hope this helps.
Dec 30, 2013 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
There is a tub that goes through the back of the freezer wall into the ice maker. Sometimes this tube will freeze shut and needs to be thawed out.
The water fill tube will freeze shut from low water pressure. Ether from a bad water valve or low pressure to the refrigerator itself.
Pull the refrigerator out and remove the tube from the back wall to check it.
Also note that,
Sounds like the thermistor is bad in the ice maker itself, and there are 3 more micro switches, and some other things in there too, just easier too replace ice maker than parts for it.
If it turns out to be the ice maker, look on the tag in the ref. side, which list the model number and serial number. look @ bottom of that tag, it will give you a model number for the ice maker kit you need.
Good luck and hope this helpout......
Jul 30, 2010 | LG LFX25971ST Bottom Freezer French Door...
My maytag is model MFD2560HES serial number
does the water dispenser work OK ? if yes , a try this : pour 3/4 of a cup of water into the ice maker, right into where the ejection fingers are. also , take all of the ice out of the ice bin. then , give the freezer time to freeze the water you have poured into the ice maker and see if the ice maker ejects the ice into the bin. if it does, it might reset itself and refill the unit and work normally.
Mar 17, 2010 | Refrigerators
Jenn-Air bottom freezer ice maker not working
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
Sep 07, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Ice maker quit making ice
There are repair instructions available for this particular ice maker at www.AnyoneCanFixIt.com Specifically, you should locate it at www.anyonecanfixit.com/household.htm
Aug 24, 2009 | Maytag MFD2560HES Bottom Freezer French...
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
Jen aire ice maker not working
change filter and defrost water lines if frozen
Dec 10, 2007 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Refrigerators Logo
97 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
