Question about Sanyo DP42841 42 in. LCD HDTV
Where can I find a replacement remote control?
Remote that came with the television began to refuse to turn on/off at times. We changed batteries. Still had same results. Bought an RCA remote control and it is giving us the same trouble. Also, with the RCA remote control we sometimes did not get the channel we asked for.
  • 682 Answers
Some times you can find universal/compatible and original remotes on eBay. It's worth trying the USA uk and Germany sites etc separately as these don't always show in searches.
Posted on Dec 05, 2014
Where can I find a Sanyo tv remote control replacement
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Dec 04, 2014 | Sanyo Televison & Video
Not able to turn tv on with remote
First try changing the batteries.
Next make sure when you press function on the remote control the red light on the remote displays under tv
Next try a remote reset:
You have to unplug the television after turning it off. Take the batteries out of the remote control. Point the remote toward the remote sensor (bottom right hand corner of the television set). Press the power button on the remote control and hold it down for 30 full seconds. Next press and release every button on the remote control. Next plug the tv back in and power it on from the power button on the television itself. Replace the batteries. Adjust the volume using the remote control. If that works the problem is solved. If it doesn't work you may need a software update, a new remote control, or repair to the sensor on your television.
To see if your remote control is working look at it through the viewscreen of a digital camera. The digital camera must be turned on and ready to take a picture. Next press a channel button on the remote control. Do you see a bluish white light? If so the remote control is ok.
Aug 24, 2010 | Sharp AQUOS LC-32D43U 32 in. LCD...
The TV does not respond to the remote control. I have replaced the batteries in the remote control
May 01, 2010 | Sharp LC-32SB24U 32 in. LCD TV
Remote will not operate volume or turn set off or on how do i solve
Try replacing batterys. If that doesn´t works, open remote and replace LED lamp. If still refuses to work, throw it out.
Nov 22, 2009 | Televison & Video
My 20 year old liftmaster model 1040 or 1050 opens on its own. I changed the remote code 3 times and replaced the wall switch. Any ideas? I even went around the neighborhood to see if my remote worked on...
Look at the LED light next to theSMART/LEARN button on rear of the motor unit. You may need to removea light lens cover in order to see it. If the light is flashingrapidly this means you have a stuck button on one of your remotecontrols. Take the batteries out of each remote control. When youremove the batteries from the bad remote, the light will stopflashing. This remote needs to be replaced.
If one of your neighbors remotecontrols is inadvertently programmed into your receiver, you doorwill open when their remote is activated. If this happens you willneed to clear out your receiver and reprogram your remote controls.Press and hold the smart/learn button for 6 seconds or until you seethe small LED light near the button turn itself off. If the abovesteps have been followed and the symptoms continue, there may be anelectronic short in either the wall control button or the receiverlogic board. In this case, remove the wall control wires fromterminals 1 and 2 on the motor unit. Should the symptoms persistafter the wires are removed, replace the receiver logic board. If thesymptoms stop with the wall control wires removed from the motorunit, replace the wall control button, and the wires leading to thewall control button.
Oct 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Tv turns off when it feels like it
There are 4 possibilities.
1. weak remote batteries
2. failing remote button pad
3. failing infra-red LED in remote
4. failing infra-red receiver in TV.
First, try another fresh set of batteries.
Next, replace the remote, third, have a TV shop look at it.
May 12, 2009 | Mitsubishi VS-45609 TV
Remote Control does not work
http://www.dynexproducts.com/pc-704-23-dynex-42-720p-flat-panel-plasma-hdtv.aspx This is the Dynex customer support web page for your television. You can contact them through the e- mail customer service and get the remote control repaired or replaced. This product comes with a one year warranty.The customer support telephone number is 1-877-467-4289. You can call them for help getting your remote control repaired or replaced. If you decide not to have the remote repaired or replaced, ask them what is the best universal remote replacement you can buy for you television. They should be able to help you either get the remote control repaired or replaced. They can also tell you what other remote controls will best match up with your television. I hope this information helps you with your problem with the remote control. Thank you for using FixYa and have a nice day!
Apr 05, 2009 | RCA DIRECTV Satellite Remote Control
TIVO Remote Control Problem
A similar problem happend to me. Buying a new remote fixed it - for about three weeks.
Maybe your new one will work longer.
Mar 06, 2008 | Tivo DirectTV Remote Remote Control
Vizio 50 inch plasma -- remote not working
You can also try to take out the batteries and push all of the buttons with the batteries out of the remote. Then put the batteries back in and push the power button on the remote. If this doesnt work press the two TV buttons at the same time and the remote should be fine.
Sep 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Sanyo DP42841 42 in. LCD HDTV Logo
50 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
