Question about Socket Home Security
How do I stop the constant buzzing on my Byron 776
Tried door bell plugged into wall socket and tested - no buzzing - but when connected back to door bell transformer keeps buzzing
5 Suggested Answers
  • 864 Answers
SOURCE: Button Press (Not Remote) Normal Door Bell Makes Slight Buzz Only
The electromagnet that causes the bell clapper to move when the circuit is closed by pushing the button is failing. Replace the bell unit.
Posted on Jul 08, 2009
SOURCE: We have a Byron SX-85
Sorry but I've got same problem. Keep having to replace batteries in door unit. Expensive!
Posted on Jan 18, 2011
  • 188 Answers
SOURCE: will my wireless bell push work with another manufacturers door chimes?
Doubtful they are compatible. If they are set by dip switches and you set them the same bot doesn't work-not compatible.
Posted on Jul 17, 2012
emissionwiz
  • 76164 Answers
SOURCE: My Byron by103 wireless door bell makes a beeping noise when the power plug is put in the wall socket
Don't pull the power plug out. That beep is to alert you the system has no power.
Posted on Jul 12, 2017
Jul 12, 2017 | Socket Home Security
Byron door bell not working
and that surprises you
battery push button at door
has to have a straight line within 50 mtrs
meaning no walls furniture or insulation material to bounce off or anything that will weaken the beam
to reach the wireless remote
Apr 28, 2017 | Home Security
Our Byron plug in door bell keeps not ringing out when you push the doorbell.
check the batteries if it has batteries and the connections and the distances
Nov 16, 2016 | Cars & Trucks
Plug in byron sx83 stops working,when you take it out the socket then replace it works for a short whill then stops again
I have a different problem with the same model.
Firstly, I think the reason yours stops working is because when you first plug-in / switch-on the power, for the first 10-seconds, the bell is in 'programme' mode. Press the button to connect with the bell and it is then programmed. Sorted. However, if you unplug, have a power-cut, etc. then the button is no longer connected to the bell and needs to be programmed again.
FYI - when in programme mode almost any remote (which is what the button is) can be programmed to ring the bell (e.g. television remote)... so ensure you don't press any other buttons within the 10-seconds 'programme' mode!
My problem is, even after I programme my button to connect, it stops working after a short while. Please let me know if this is happening with yours and if you ahve any solutions.
Thanks,
Jason
Jul 05, 2012 | Cars & Trucks
Hi, when using the gain control on my amp I get a buzz and an 'osilating' sound. I've tried several guitars and leads but still the same problem, any suggestions?
Hi.
If the amp is working, then most of the time the buzz is given by a bad grounding. Test the amp using different wall sockets, and possibly test it in a different home (there may be an earthing problem with the home network). If the problem goes away, then it was the wall socket or the home power network. If the buzzing is still there the problem is with the amp. Check the earth connection at power cord and psu and test the amplifier's PSU components. Check also the audio connections inside the amp (the back of the female jack input sockets). A small contact in there will result in a loud buzz.
Aug 09, 2011 | Fender G-DEC Junior Modeling Guitar...
The door open bell is constantly ringing - shen no door is open - causing a drain on the battery
You need to determine which side is causing the problem and test that door switch ( usually on the door jamb, either hinge or latch side deoe4nding on model) Find the door stitch and push in on the switch fully by hand. Does the bell stop? if not, then your door switch is likely faulty and you'll need to replace it - a quick fix would be to dismount switch from vehicle and unplug. At this point, if the switch is bad the bell should stop. Make sure to tape the plug ends so they cannot short out against the body. I would also recommend tying a small string to the end before you cover the connection and securing the other end to the hinge ( tie it on or tape it) so you can retrieve the wires to reconnect the new door switch.
Hope this helps!!
Nov 29, 2010 | 2003 Hyundai Tiburon
Lost instructions for Byron SX1 wirefree door chime.
i have a byron sx1 door bell and its picking up someone elses help
Aug 24, 2010 | Bell Cocoon Child Carrier
Jul 07, 2009 | Desa International White Wireless Plug In...
Home Security Logo
Top Socket Home Security Experts
ray gallant
carl blood sr
Are you a Socket Home Security Expert? Answer questions, earn points and help others
