Question about Refrigerators
Buzzes when getting water and intermittly
Buzzes when you are getting water and intermitenly
When playing solitaire, my Lenovo intermittently buzzes or vibrates. Up to 8 to 10 times. Then stops for a few minutes and starts again. Very annoying. Ho do I shut this off!
Hi there the only equipment in a laptop capable of this is the CPU fan. I would suggest getting it cleaned out first or probably the fan is damaged creating vibration which will need to be replaced.
Nov 08, 2016 | Computers & Internet
Washer buzzes and won't agitate or spin. Only will fill with water.
Almost certainly with that sound, the motor start capacitor has failed. It will be located either behind the control panel, or underneath next to the motor.
Dec 17, 2013 | Maytag Parts Washing Machines
2005 Ultra Classic ,Speedo Cuts Out Which In Turn Cuts Out Cruise Control, And Turn Signals Wont Shut Off,And At Idle Bike Engin Will Stall,But Will Start Up . This Is An Intermiten Problem
I believe the turn sigs, speedo and cruise are all controlled in part at least by a module under the fairing. It may need replacement or it could just be a loose wire. Sounds more like a loose wire plug or bundle, if intermittent.
Jun 10, 2010 | 2005 Harley Davidson FLHTCUI Electra Glide...
99 corsica-cuts off intermitenly-(with in 5 min.running) of crank
try another relay if still same then bring out voltmeter/start checking wires
Mar 19, 2010 | 1999 Chevrolet Cavalier
Washer won't drain the water
mine was my pump,quite easy to fix yourself
Nov 03, 2009 | Washing Machines
I just got water in my waverunner XLT1200. I filled it up and left the dock with the gascap off! I slowed down while trying to put the cap back on, I estimate that about a cup or more went into the gas...
Bite the bullet and drain the gas tank...its not as bad as it sounds water will sink to bottom of fuel tank and likely get sucked up into carbs even if only intermitenly... change your fuel filter and spray the fuel lines as clean a possible...
Jul 16, 2009 | Yamaha 12V Air Pump
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
